Question about JVC Audio Players & Recorders
Eq adjustment hello; i have a jvc rx-5060b i am trying to set the eq, it is 5 band setting deq 63hz/ deq 250hz/deq 1khz/deq 4khz/deq16khz. i would like to no were these should be set near, thank you. duncan
JMuskovitz
  • 135 Answers
SOURCE: setting clock
Try this (it is from the instructions for a similar model): The URL for this manual is: http://books.jvcservice.com/download/685823823/19755.pdf
Posted on Mar 31, 2007
urbanmove
  • 5 Answers
SOURCE: zapco 18 band eq
You will need to call the manufacturer, ZAPCO - 209-577-4268, or email them at tech support robert@zapco.com , in order to purchase the part you are missing. It is possibel to hard wire the RCA parts you need and creat a homemade fix, but in all honesty it is not worth it, and it will probably introduce a lot of interference in to the quality of your signal path rendering it a bad option. Give them a call / email. If they will only sell the part to a dealer, call Car Depot @ 615 - 269-8080 and they can have the part purchased and delivered to you for a small fee. Good luck.
Posted on Feb 02, 2008
SOURCE: JVC KDG 340 Car stero
SOUNDS SETTINGS....OPRIME EL BOTON Q DICE EQ...EN LA PARTE SUPERIOR DERECHA....Y ADJUST BASS....PRIMERO OPRIMES EQ.....SELECCIONAS USER..Y LUEGO OPRIMES LOS BOTONES DE DIRECCION HACIA ARRIBA Y HACIA ABAJO..Y AHI SE LO PUEDES AJUSTAR
angel_lk2@hotmail.com
Posted on May 26, 2008
informatica
  • 1114 Answers
SOURCE: how set time jvc kd g220
Hi - You can download the manual from the link underlined in blue below:
jvc kd g220
See page 10.
Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Jul 21, 2008
XSdB
  • 80 Answers
SOURCE: best settings on a 9 band eq for rock and r&b
Provided the rest of your system is all tuned an in proper shape, and up for the wattts, the best sound to set, starting with the low end...start with is a slightly elevated above zero (about 1/4 up from zero) then slowly gradually slope it down to 1/4 below zero in middle and then back up to 1/4 above at the high end.
The result is a gently curved V type shape.
Now, knock down the highest 2 or 3 freq bands a few clicks till they are just above zero. (1/8).
This is the curve you would shoot for with a real-time analyzer for SQ, punch and clarity.
Posted on Jun 12, 2009
Can a ten band equalizer be used on a JVC rx-8030v 6.1?
Yes.
Use the Tape/MD or the one next to it (lower)
Aug 12, 2012 | JVC RX-8030V Receiver
My head unit resets settings when key is taken out
Do you have the yellow wire going to a constant 12v power source? The yellow wire controls the memory of the radio and needs to have 12v going to it at all times, even when the key is taken out of the ignition.
Jun 28, 2012 | Pioneer DEQ-9200 3-Band Car Equalizer
How do you set a 9 band eq for maximum performance
start by all slider in middle position and adjust your 1k and 5k while you are speaking in mic untill you get better sound quality the other slider will be adjusted due to speaker sound type.
Sep 24, 2009 | Audio Technica Audio Players & Recorders
I can't figure out how to adjust the bass on the JVC KD-HDR30.
Hello hawk713, Like with many other JVC receivers, adjusting the bass is done from the "EQ" (equalizer) mode for one or all of 6 presets: ROCK, CLASSIC, JAZZ, HIP HOP, POPS, and USER. To adjust it, select the desired preset mode, use the left/right rocker (on volume control) to scroll to the desired frequency, 60, 150, 400, 1K, 2.4K, 6K, and 15K, and then turn the volume control up/down to set a level from -5 to +5. 60 and 150 adjusts the bass, 400, 1K, and 2.4K adjusts the midrange, and 6K and 15K adjusts the treble. Then you select whichever EQ setting sounds best with the particular music you're playing. Hope this helps.
Jun 06, 2009 | JVC KD-HDR30 CD Player
My pioneer deq-9200 equilizer keeps resetting to default settings whenever i start my engine. What's going on here?
The EQ has two power wires on the back like a head unit. One is constant power, and the other one is ignition/switched power. This normally happens when the installer takes the switched power and applies it to both power leads going into the EQ or head unit. The EQ needs the constant power line run to a 12V source that never turns off. The constant power line is normally yellow, and the switched power line is normally red.
May 19, 2009 | Pioneer DEQ-9200 3-Band Car Equalizer
Equalizer setting help
try to use the preset equalizer settings after which you can come back to the parametric equalizer and adjust to your own taste. no problem if you don't connect the subwoofer just make sure you set the hi-pass filter to off so that you will hear the full range to your speakers. but, I advice you to put a subwoofer. There is more dynamics to the lower freqs too. don't adjust the source level if there is no problem. take note the EQ of your head unit is a parametric equalizer. hope this helps while you read about parametric EQs.
Apr 20, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
EQ settings
This setting is a blast,I adapted it from the 10 band "perfect" itunes eq setting. don' t be shy , give it a try...
80hz = (2) or 7
220hz = (0) or 5
470hz = (-1) or 4
1khz = -(-2) or 3
2.2khz= (0) or 5
4.7khz =(2) or 7
12khz= (4) or 9
I have this on my LG tv, however if you need more oomph! to it, simply stick to the same pattern between the two sets above and move each slider up accordingly.
Sep 26, 2008 | Car Audio & Video
Mar 17, 2008 | Audio Players & Recorders
XBOX 360 to JVC RX 5060b
does your reciver have video ins and outs monitor out u have to send master video out from jvc to tv 1st u know im open for chat
Jan 06, 2008 | Audio Players & Recorders
Cannot Set the Treble & Bass
I have an Alpine 9887 you have a different eq than just trebel and bass the only way to get you bass an trebel setings are to install the imprint stoftware now if thats the route you go it tunes your radio to what it thinks it should sound like it's for sound quality not for alot of bass been there done that I have the software but you need to take it to a good alpine dealer to have it installed good luck
Jan 05, 2008 | Alpine CDA-9887 CD Player
42 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
