Question about LeapFrog Leapster Electronic Book: Spider-Man (30425) for PC, Mac
Leapster broken black wire.
One of the black wires inside my son's Leapster came off. Both ends. I'm
assuming one end of the wire connects to the negative terminal of the
battery on the back panel.
Can you tell me where the other end of the black wire connects to on the
PCB?
Thank you very much for your help.
  • engyah Feb 28, 2008
    Great suggestions. I was able to find the connections with an
    ohmmeter. The hint of looking for the "broken" wire strands
    was very helpful.
    Turns out, the black wire is the ground wire. I was able to ohm
    from the external power supply connector (the ground) to the
    connection point on the PCB. There, the strands were found.
    Genius:
  • 1,019 Answers
Black is usually negative Or nuetral, so your assumption would be correct.
As for the cicuit Board end or PCB Side, i,d look to see where the Red from the battery goes on to the Motherboard. Observe the Size of the Solder Spot, and the Black Should be in Close Proximity to that. To be more sure, if you desolder, the spot.
And put a magnet on the desoldered/Solder. any remnants of metal strands, from the broken Wire, will magnetise.
As solder is mainly non-conductive. Tin/Lead.
If there are no visible signs, of the Black-Wire being adjacent to the Red. Look On The Opposing side of the Board.
The Additional Hint Here, Is to gauge by the length of the Wire.
Hope This Is A Fixya For You.
Mike @ Compurepair.
Posted on Feb 25, 2008
  • Mike Waldron Feb 28, 2008
    Your Welcome Buddy Anytime.
    Remember The hints For Any Similar problems.
    Mike @ Compurepair.
Red wire loose hanging from inside front of window a/c.Its a frigidaire model #fra105ct1.the red wire is zip tied to a double black wire that goes to the front radiator of the a/c.Would ya know what it...
If its hanging out of the front, I would think that its a broken wire off one of the sensors. There are usually 2 sensors on the front. 1 measures room air temperature, (Air sensor)and the other measures the refrigerant temperature in the pipes (Pipe sensor) The air sensor has a small bulb on the end of it and is usually clipped onto the front of the coil or the front panel.. The pipe sensor has a small copper tube on the end which slides into a hole or sleeve on the side of the evaporator coil.
Jan 28, 2018 | Dehumidifiers
I gave my son a leapster explorer about a month now and it's volume just stopped working and it wont hear anything.
there are three basic reasons why the leapster explorer won't bring out sound.
1. Defective speaker
The speaker of your leapster explorer maybe defective, this can make it not bring out any sound. Disassemble the leapster explorer, check the speaker part, test the speaker with a AA battery. If you hear any sound using the battery, then it means there is nothing wrong with the speaker.
2. Loose wire connection
Disassemble the leapster explorer, check the wires connecting the speaker to the board. Check for any wire cut, or loose connection which can cause the speaker not to bring out sound. . 3. Sound IC/Card/Board
If non of the above is the cause of the problem, then it means the leapster explorer is having a defective sound ic/board/card. There is an IC on the board of the leapster explorer which is responsible for sound. If this ic has a shot, there won't be any sound. If this be the cause, I think it's high time to took the leapster explorer to a repairman because this requires skill.
I hope the above is clear. If not, please let me know for further assistance.
Regards.
Aug 10, 2011 | LeapFrog Leapster Explorer Learning Game...
Charger keeps flashing red and green and wont charge
Look at the connector end that plugs into the bike. You might have to take it apart to see the wires inside. My son has a Razor Vespa type scooter and the solder job for the wires inside the connector were not the best. It might be a broken wire, especially if it's flashing between red and green.
Hope this Helps!
Please Rate;)
Gary
May 25, 2011 | Razor MX500 Dirt Rocket
I have a Leviton 5225/702. I want to control the receptacle/outlet with the switch. I have not broken the hot tie and I have not used the brass screw. I tried 2 hook ups without success.
Assuming you have a tie on only one side, you should not use either screw on that side of the unit. Connect your hot wire to the screw on the other side of the unit on the end closest to the switch. This should be an isolated brass screw. This will allow the hot wire to feed through the switch, then through the hot tie to the outlet end of the unit. Connect the white neutral wire to the other screw on the same side that you connected the hot wire. This should be an isolated silver screw toward the outlet end of the unit. Connect your ground wire to the ground terminal. good luck Al K
Dec 17, 2010 | Leviton 5225WSP Switch and Outlet
The windows and driver door lock buttons stop working. but i can lock the door for passenger and backdoors from the passenger door ,but the windows won't go down
Dec, 13/09 Surprisingly, many others have reported the same problem in internet Q & A sites. It happened to me yesterday and, just as many others discovered too, the black wire inside the black cover over the harness between the door panel and the body near the door hinge was completely severed. I removed the cover from the door end and tried to push it back and out of the way to expose both ends of the black wire. It is awkward and would be difficult to work with the end of the black wire coming towards the door. So, I made a 1/2 inch **** in the covering near its end closest to the Jeep body and, using needle nose pliers, fished the black wire up and through the ****. I could then strip 1/2 inch of plastic covering the end of the wire and then twist the stripped end of a 3 inch length of flexible wire (similar to that from a lamp cord) around that black wire and solder the joined wires using a soldering iron, solder and flux. I then wrapped the soldered joint with electrical tape, pushed it back through the **** in the cover and pulled it through the cover to extend conveniently closer to the end of the broken wire coming from the door panel. I stripped the end of that black wire, similarly soldered it to the splicing wire, wrapped that joint with electrical tape and easily replaced the end of the cover over the white plastic cap on the door panel.
It was great to hear the door lock and unlock using my remote opener, to find the windows again opened, interior lights dimmed when the driver's door closed. Don't let service try to sell you new locks, switches etc without first checking for a broken wire in the harness. This do-it-myself project took less than an hour with material already on my workbench. Others have reported dealers have charged as much as $400 for time to check everything else before finding the broken wire. DH Cambridge, ON Canada
Nov 11, 2009 | 2004 Jeep Grand Cherokee
1995 Jeep Grand Cherokee power window wire broken
Your best way in is through the kick panel on the side. I generally solder an additional length of wire on and before connecting to other end, slide a piece of thin tubing (like washer fluid line) over it. After soldering the other end, slide the tubing over the repair and put a dab of silicone or other glue on the wire just before you have it all the way in position. Doing this protects the repair and the wire from further failure.Make sure you secure any extra wire inside the door where the window regulator won't grab it and tear it out.
Aug 31, 2009 | 1995 Jeep Grand Cherokee
Replacing Power Cord Kenmore Progressive Upright
That actually sounds correct, if it's the model I'm thinking of. As long as you're talking about connecting to the wires that are held in by the wire nuts you should be good to go.
-R
Oct 25, 2008 | Kenmore 23613 Progressive PowerMate Bagged...
Leapfrog Leapster doesn't read cartridges anymore?
HI my son has a LEAP frog MAKE SURE THAT THERE IS NOTHING OBSTUCTING THE CONTACTS( metal on the game and the cartdridge meet)
PLEASE RATE THIS HELP FiXYa EXPERTS HELP
Sep 01, 2008 | LeapFrog Leapster The Batman Strength in...
Installation Problem
Switches always connect to hot (black) wires. In some cases you may find a white wire with the end taped black denoting it is serving as a hot (black) wire. Or you may find a white wire connected to the switch. If that's the case, the prior electrician did not properly mark the wire and it should be marked as a black wire. Wrap the end with black electrical tape after disconnecting.
Aug 27, 2008 | Lutron CA-1PSH-LA Almond Claro Switch
Broken speaker
the only way is o replace the wires from end to end.. you may have to do some soldering inside the subwoofer and the satellite speakers
May 12, 2008 | Altec Lansing Multimedia Computer Speakers
LeapFrog Leapster Electronic Book: Spider-Man (30425) for PC, Mac Logo
178 people viewed this question
Top LeapFrog Computers & Internet Experts
Alun Cox
Michael Cummings
Level 1 Expert
Are you a LeapFrog Computer and Internet Expert? Answer questions, earn points and help others
