Question about LG MU-42PM12X 42 in. HD-Ready Plasma Television
Half of the screen has vertical coloured lines, I was Quoted $400 to fix. Is that reasonable ? what is the problem ? I have the same problem. My screen is fine when the set is cold. After a few minutes of play the vertical lines appear on the left half only. Trying to find a solution.
  • benjie superio Jul 24, 2012
    when u on ur tv and there is a vertical line on the screen it means u want 2 check the horiz0ntal line if there is a l0ose c0nnecti0n. And als0 check the horiz0ntal i.c. U can als0 check a c0mponents beside the h0riz0ntal ic especially the capacit0rs and resist0rs if there is leaky 0r change value.
  • Anonymous Mar 18, 2014
    fine vertical lines on half of the screen
    Genius:
  • 3,422 Answers
HI,
I want you to check the cable box if all the wires are attached properly because sometimes it causes disturbance and vertical lines occur.
It may also cause by something nearby to the television that is causing a magnetic field to over power the screen. Most common it is another loudspeaker or subwoofer that is near by.
Here are few more troubleshooting steps you can try:
ONE: Disconnect the power cord for 4 hours. Then when you power it back up the internal soft codes will automatically reset to factory defaults.
TWO: The whacking test is to just bang or smack the set with your hand on the back, side, top, etc., to see if there are loose connections or cold solder joints inside that are acting up. If so, the banging should knock them back to normal and the set should restore. You might have to use some creative banging and some have had to put a book or magazine under one corner to torque the chassis enough to get it to work reliably.
If the problem still persists you have to get it repaired.
Goodluck..
Posted on Feb 25, 2008
  • 2,336 Answers
It looks like a vertical deflection failure but It could also be a power supply issue as well.
There may be some cold solder joints in the vertical deflection of your TV, may be some leaky capacitors in the power supply and vertical circuitry as well.
Depending on how much you paid for the TV, the quote seems reasonable but you need to ask them if their work is guarantee and for how long.
Get the guarantee in writing if the repair center is providing it.
    Genius:
  • 3,587 Answers
That's a really good charge, if it's done on site..and includes labor and materials..and it works, of course
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
Thin vertical colour lines on half of the screen
Hello, there is a problem with your monitors picture tube. May be it might have been damaged as a result of over power or even because of over use. Just try to change the picture tube or change your Monitor.
Nov 15, 2017 | Samsung SyncMaster 910MP 19" LCD Monitor
Panasonic TH-42PX70B plasma tv vertical very this coloured lines in band about thrd of way across screen from right hand edge what is thesolutionto fix this problem
Sounds like COF (Chip On Film) strip fault. Check this link for more details. There is illustrations [screenshots] and reasons to plasma displays. Check it out, and compare them with your TVs fault. Pull up older posts there.
Mar 07, 2013 | Televison & Video
Two inch wide vertical band spreads across half of screen
this is a problem is your scan section either letf or right scan boards are bad. if its under warranty take it back if not it needs to be serviced. you can probably do it yourself.
Jul 01, 2009 | Televison & Video
SAnyo 32" LCD: Pattern appearing on the screen after sometime
im sorry friend, your processor over heated and the Processor is toast, they will fix it and it will work for a month or 2 then it will **** out on you again. so best to get another one. i know this problem all to well
the reason the processor over heated is becasue the fan cut out, prolly seased up.
May 02, 2009 | Sanyo DP32648 32 in. LCD TV
Screen problems
You are experiencing the decay of the LCD panel itself. The screen will need replaced and is in the neighborhood of $300-$400.
Jan 10, 2009 | HP Compaq nx9030 Notebook
Panasonic th37px60
Just taken mine in for repair and was told this. "After checks to Switching and Data flow to PDP, Suspect the Plasma display panel to be at fault
which also may well have caused damage to the buffer and logic boards."
I am presently trying to get currys to replace it as it 18 months old.
Forgot to say was quoted £1200 to fix!!!!
May 18, 2008 | Panasonic TH37PX60 37 in. Plasma...
Vision 42 inches plasma tv
It sounds like there is a problem with the tuner inside the television. Your best bet is to send it in for service.
Jan 30, 2008 | Vision HDV-42P2 Television
Half of the screen only is functioning
ok you have defective vertical amplifier and convergence correction circuit!
Oct 21, 2007 | LG 42PC1DA 42 in. Plasma HDTV
LG MU-42PM12X 42 in. HD-Ready Plasma Television Logo
211 people viewed this question
