DVD surface layer damaged
I have a couple of DVD's that are a few years old. They havent been played much and have been safely stored etc but the surface of these discs has developed a sticky cloudy film. When put into a player the discs skip and the picture freezes. What is the cause of the problem and is it fixable? I have heard stories about "DVD rot" but is this a genuine problem or an urban myth?
    Top Expert:
  • Televison & ... Master
  • 12,962 Answers
If surface gets "yucked" up the laser mechanism cannot see or read the data encoded on its surface. Try cleaning the surface with a wet paste made of baking soda and scrub it in good. It cleans without scratching the plastic surface coating. You have to get rid of the surface film that is causing the issue without scratching the plastic. Good luck!
Posted on Sep 02, 2017
  • 518 Answers
SOURCE: DVD Freezing / skipping
It almost has to be the discs. Try them in a friends unit.
I had a similar problem with DVD's I burned and had printed labels and put the label on the discs. It caused the disc to be out of balance. I peeled them all off (what a job) and the discs play fine now. I'm now a "magic marker" person... :)
Geno
Posted on Feb 10, 2008
SOURCE: DVD player recorder won't read or play any disc
This just worked for me. Don't know how long it will last though. I found it on this webpage
http://forum.ecoustics.com/bbs/messages/15118/130292.html
To do a reset:
On the remote control press the SETUP button,
Press the right key on the remote 3 times,
The Preference page will show up,
Press the down arrow five time to highlight
"default", hit right arrow to highlight "reset"
Press enter to reset. Turn off/on machine, etc.
Posted on Feb 14, 2008
SOURCE: JVC XV-THA5R multi-region DVD player - fault recognising a disc in and playing
I too have this same problem on my current DVD player, AND strangely enough I had the same problem on my previous player.
Previous player was made multi region and was a Sony S660 (I think that was the model number).
My current DVD player is a Denon and was £550! It is also made multi region and has the same problems! I don't get it!
Posted on Apr 23, 2008
preachw996
  • 1179 Answers
SOURCE: dvd pixilating and skipping about an hour and a half into disc
Use a dvd cleaner and then try the movies. Hope this helps.
Posted on Dec 21, 2008
  • 321 Answers
SOURCE: picture "freeze up" during playback
your laser lens is probly dirty ;/ just use a qtips and alcool and gently clean the lens if it not work proper ly may be your laser assembly going out...
hope that will help you....
Posted on Apr 20, 2010
Whats a dual layer disc mean then?
A dual layer disc is a DVD which is able to hold double the info.( http://en.wikipedia.org/wiki/DVD#Dual-layer_recording )
Dual-layer recording (sometimes also known as double-layer recording) allows DVD-R and DVD+R discs to store significantly more data-up to 8.54 gigabytes per disc, compared with 4.7 gigabytes for single-layer discs. Along with this, DVD-DLs have slower write speeds as compared to ordinary DVDs and when played on a DVD player a slight transition can sometimes be seen between the layers. DVD-R DL was developed for the DVD Forum by Pioneer Corporation; DVD+R DL was developed for the DVD+RW Alliance by Philips and Mitsubishi Kagaku Media (MKM).[23]
A dual-layer disc differs from its usual DVD counterpart by employing a second physical layer within the disc itself. The drive with dual-layer capability accesses the second layer by shining the laser through the first semitransparent layer. In some DVD players, the layer change can exhibit a noticeable pause, up to several seconds.[24] This caused some viewers to worry that their dual-layer discs were damaged or defective, with the end result that studios began listing a standard message explaining the dual-layer pausing effect on all dual-layer disc packaging.
DVD recordable discs supporting this technology are backward-compatible with some existing DVD players and DVD-ROM drives.[23] Many current DVD recorders support dual-layer technology, and the price is now comparable to that of single-layer drives, although the blank media remain more expensive. The recording speeds reached by dual-layer media are still well below those of single-layer media.
There are two modes for dual-layer orientation. With Parallel Track Path (PTP), used on DVD-ROM, both layers start at the inside diameter (ID) and end at the outside diameter (OD) with the lead-out. With Opposite Track Path (OTP), used on many Digital Video Discs, the lower layer starts at the ID and the upper layer starts at the OD, where the other layer ends; they share one lead-in and one lead-out.
Jun 16, 2011 | Nintendo Wii Console
My sims 2 double deluxe wont play .thelauncher comes on. after selecting it ,the sims plays a few notes then tuns off.
The Sims is an excellent game.!
But its a bit demanding.
Make sure your computer complies with the minimum hardware requirements like memory, video card, etc.
Also check for damages on DVD media like scratches or finger prints in the surface.
Good luck
Don't forget to rate thus answer if it helps
Aug 20, 2010 | Computers & Internet
Dvd player freezes in the middle of a movie, the player stops and freezes on a scene
It sounds as if your DVD player is having trouble switching to the 2nd layer of the Dual layer DVD. If the DVD player is older, it may not even support dual layer DVD's. If it is a more recent model (less than a few years old), then the lense may need cleaning. You can try blowing the compressed air into the slot where the DVD goes (DVD removed, tray out if it is a tray model) or an inexpensive DVD lense cleaner you can find at most retailers (Wal-Mart, Target, etc.). The second layer requires a different focus on the lense and has to penetrate a little deeper into the DVD so it will be problematic if there is any dust or foreign objects on the lense.
Feb 01, 2010 | Televison & Video
DVD plays well until it stutters midway thru and
If it only happens with one disc, try using a Disc Doctor/Skip Doctor on it. These instruments will repair scratches and depending on the disc, repair pinholes in the disc. Usually it's just polishing the surface of the disc. Some instruments totally resurface the disc by stripping off a thin layer of the disc to remove scratches and other damage. (Used game/music stores will do this).
Aug 29, 2009 | Panasonic DVD-RV31 DVD Player
"No Disc" message when trying to play DVD or music CD.
Try a "Laser Lens Cleaner" preferably one that uses fluid, run that thru the machine a couple times. You can find them at just about any retail store that sells CD's/DVD's or electronics. Next, if you have any liquid car polish, take a couple drops and spread on the surface of the disc. Use a microfiber towel to clean off. This helps clean off smudges and protects the disc from scratches. And it works great on damaged discs too! If your discs still do not play, then the unit needs to be repaired or replaced. Hope this helps
Jun 14, 2009 | Sony DAV-DZ720 Theater System
Vhs SP tapes
It sounds like the tapes may be physically damaged, wrinkled or creased. This may have been done when they were played in whatever machine you used 5 years ago. Tapes can also be damaged in storage by heat or humidity. Tapes should also be stored on end in their boxes, not flat. If these tapes were stored flat, the bottom edge might have gotten wrinkled. This can damage the control track and cause playback issues.
May 09, 2009 | Sony SLV-D380P DVD Player/VCR
Won't eject DVD and WOn't play
On the face of the DVD, look for a small hole that you can push a paper clip into. This should allow the DVD to eject. Check the DVD for dirt, dust and damage.
Jan 24, 2009 | Emerson EWL20D6 Television
Dvd pixilating and skipping about an hour and a half into disc
Dec 21, 2008 | JVC HR-XVC33U DVD Player/VCR
New DVDs won't play
What studio label? Some Newline DVDs appear to have some new protection, newer than the Sony ArcOS protection (or whatever it is called).
Jan 18, 2008 | Toshiba SD-2700 DVD Player
Won`t play or record
take it back and get a new one. Make sure you scan for a virus i use the free AVG
Oct 14, 2007 | LG GSA-2166D DVD RW Dual Layer Burner
Televison & Video Logo
141 people viewed this question
Top Televison & Video Experts
