Question about Samsung Televison & Video
42 samsung rear projection
Tv blew smoke comeing from it and oily fluid
  • 52 Answers
Sound like one of the crt guns are bad best to replace all three.
Posted on Nov 14, 2009
Oily liquid drip from TV
Busted electrolytic capacitor inside. Contact any service technician. Never switch ON the TV; until the fault is rectified.
Nov 06, 2014 | Toshiba REGZA Televison & Video
I have a Samsung HL56A650 DLP TV. The Standby/Temp and the Timer lights are blinking. It will turn on and then shut off. When it comes on the picture is fine but it only stays on for a few seconds. There...
Check ballast supply board that drives lamp and is attached directly with lamp, ballast supply board can cause of this problem, would be cause of smoke while tv shows picture for moment.
Mar 19, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hi, my tv hc-p4241w was ok but one day, the picture in the screen become wide and then I saw smoke from the rear panel. I switched off the TV, and I found that the C407 have exploded, there's a Diode...
Look to see if any coolant fluid has leaked from any of the CRT's. This is a common cause of multiple component failures in these models. Look real close at the CRT mounting bracket, the wires coming from the CRT's and look at the particle board below to see if you can see any staining or puffed up wood particles. My experience with the Samsung bds is when you have a multiple compoment failure due to fluid leakage it is best to replace the boards instead of component level repair because other components will fail at a later time. Coolant fluid is real hard to spot since it is ultra clear. Hope this helps.
Jul 13, 2009 | Samsung HC-P4241W 42" Rear Projection...
How do I do a factory reset?
With the tv off, press on the remote Mute,1,8,2,Power
This enters the service menu.
The factory reset option is in there.
Aug 06, 2008 | Samsung HCN4226W 42" Rear Projection...
Power circuit board needs to be replaced
Samsung parts
http://www.partstore.com/Part/Samsung/Samsung/
Jan 29, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung rear projection tv
It probably is see if you can align the convergence manually or auto if available, you can order just the convergence ic's or the convergence amp board, whichever you prefer. check pricing and availability. also check Blue crt for faded picture, usually dirty crt fluid, makes picture dark and discoloured. If it is you may need to replace the blue crt also. this gets a little expensive, again check pricing hope this gets you started RFT
Jan 06, 2008 | Samsung HCM4215W 42" Rear Projection...
Bulbs blown in samsung sp42w5hfx
Its hard to tell without actually knowing where the smoke came from. I doubt that any of the CRT's (bulbs as you say) caused the issue.
Nov 27, 2007 | Samsung HCM422W 42" Rear Projection...
Cant play My ipod on my Samsung TV
not detecting the side inputs?....try plugging the ipod into the audio input 1 and select video 1 on the input...if you hear sound...your ok
Apr 23, 2007 | Samsung HCM422W 42" Rear Projection...
Open Questions:
Televison & Video Logo
37 people viewed this question
Henry  Thomas
Henry Thomas
