Yes, you do need to use USB for rockband drums for wii, but i don't know how to sync the drums, if they're wireless, if it's a wired set, just plug it in the back of the console, i know how to sync a wireless guitar, on the part you plug into the wii, there should be a tiny white button, and the guitar should have a white button on it, push both buttons at the same time (make sure that thee guitar has batteries and the other is in the wii), if done correctly you should be able to play, if the wireless drums work like that too, than i hope this info helped.
Are you pressing the sync buttons on the component and then pressing the sync button on the console?It is under the large door on the front of the console.First press the guitar sync,then it should give you a couple of seconds to press the console sync.If the light goes to constant blue,it is synched.Do the same for the other component.Good luck and rock on!
first of all you should make sure you have fresh batteries and then try the special resynch via the red dot like button on the inside of the controller (press it at the same time as the one in sd card slot) if that doesnt work try just moving closer to the wii at far distance the controller signal gets weak. if its not that then its a hardware issue
When starting up Rock Band, make sure that no more than one Wiimote is activated (two if you are using one for a bass/guitar). If any are, they will over ride the drums and guitar in priority.
Make sure that only the drums, wireless guitar, microphone (controlled by the Wiimote) and 2nd guitar (whether the fender type with built in wireless OR, but NOT AND, a 2nd guitar that uses a Wiimote).
If more than the max number of wiimotes are turned on when you power up the game, reset your console, and wait to start Rockband until the other wiimotes no longer show a light.
For me it was the white box that connects to the back of the wii. I tried everything from changing batteries in the guitar, to pressing white button on guitar, to restarting while holding white button down to screaming at the wii. Then I bought a new rockband guitar at best buy and the new guitar did not work until I swapped the white box (dongle?) that connects to the back of the Wii. One is for the drums and the other is for the guitars and mic. Hope this helps.
try pressing the button on the usb reciever, also you can try and sync it directly to the wii. press the sync button on the guitar, then the sync button on the wii, then the button on the guitar again. I myself have not tried this myself
