I have a Vizio 50" HDM Plasma TV. Had it for approx. 2 years, when I turned on the TV, a very loud "pop" sound was heard and the screen went black. The TV was powered off an on, after a couple of tries, the TV turned on again but the image was unclear (lacking colors and poor resolution). After approx 1 hr of watching, the screen image was deteriorating and now I can only see vertical "strips" that are white in color. Is it worth fixing?
  • 3 more comments
  • andronicoc Feb 25, 2008
    Thanks for the reply, it has nothing to do with the outside wiring, even without any input signals the TV still shows the same, I can't see anything including the menu screen, etc.
    I opened the back of the TV to see any burned out or leakeage in any components, and could not visually see anything. One Board has a couple of LEDs that are green all the time, another board has a blinking green LED.
    - AC
    If I can get some guidance and I think I can try to extract and replace boards.
    I am out of Warranty and I live in Southern California (Orange County)
    I believe that the Model number is P50HDM, but as far as the part I want, I have no idea... That is the reason I am asking for assistance, because I don't know where is the source of this problem.
    So, just to verify, the first step is to get the control board replaced. P/N 00040000010. I will take a look in the back of the TV once I get home and see how difficult it is to extract this board. Is there anything else to do or expect at this moment?
    Do you have any idea how much this PCBA costs (ball park range? Any further help in getting this part is appreciated. Keep me posted,
    - AC
    Genius:
  • 3,422 Answers
HI,
I want you to check the cable box if all the wires are attached properly because sometimes it causes disturbance and vertical lines occur.
Here are few troubleshooting steps you can try:
ONE: Disconnect the power cord for 4 hours. Then when you power it back up the internal soft codes will automatically reset to factory defaults.
TWO: The whacking test is to just bang or smack the set with your hand on the back, side, top, etc., to see if there are loose connections or cold solder joints inside that are acting up. If so, the banging should knock them back to normal and the set should restore. You might have to use some creative banging and some have had to put a book or magazine under one corner to torque the chassis enough to get it to work reliably.
If the problem still persists you have to get it repaired the repair can cost anything between $200-300.
Goodluck..
Posted on Feb 25, 2008
  • 1 more comment
  • Priya darshan Feb 25, 2008
    If you feel that you can repair it by urself then go ahead please follow IB4G2008's advice and if you need any parts i can help you with that.If not i suggest you to go for a repair.
    Can you tell me what is the model no. and the name of the part you want.
    I have searched for the parts everywhere.They are not available online.Please contact on the no. which IB4G2008 has given you to get the part or better get the service done from them.
    Genius:
  • 3,587 Answers
Sounds like the video control card is history
  • 10 more comments
  • Patrick Michaels
    Patrick Michaels Feb 25, 2008
    depends on whether you wish to dig into the back of this device, and replace one or two boards, and based on their availability, too
    what's your technical skills level?
  • Patrick Michaels
    you are in for at least the control board, and possibly the power supply, even though having any signal suggests that power supply is fine..you'll see a load of options here soon, so choose your solution based on what YOU are willing and capable of doing yourself.
  • Patrick Michaels
    btw, I repair those here on Hawaii
  • Patrick Michaels
    ok..well..then, if you have power to main control board, then you are most likely looking at a replacement of that for certain...again, what is your comfort level with the technical aspects?
  • Patrick Michaels
    ok..that's not too big of a deal..you'll need to get a replacement board first, though...what part of the world are you in? and I'm assuming that the unit is NOT under warranty, correct?
  • Patrick Michaels
    the actual replacement is not that difficult, really..just need to have right tools, and patience..and Do NOT mix the hardware,
  • Patrick Michaels
    ok..SoCal..no worries..now to find you some parts..coolguy? you got some traction on parts in SoCal for this fellow?
  • Patrick Michaels
    good news is that the tech support folks are right in Irvine, CA, so you might get some help there, too.
  • Patrick Michaels
  • Patrick Michaels
    on phone with tech folks at Vizio now..
    will need a serial number, perhaps
  • Patrick Michaels
    00040000010 is system board, from Vance/Baldwin, who's Vizio's spare parts folks..
    800 432 8542 is number..ext 2...sounds like they are in Texas..
  • Patrick Michaels
    Patrick Michaels Feb 26, 2008
    make sure of your model number, and then go here. enter model number, and you will find as much as you can imagine.
    click here to continue
    you may be asked to register..use Guest option.
    I'm sure you now have enough to proceed, and decide which expert was the most help, eh?
My Vizio p50hdtv herd spark, and TV went black, no picture no sound
Check and replace the main power regulator board as card basis. It has damaged.
Oct 11, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
I have a 50 inch plasma vizio tv. I was watching it then i heard a pop the screen went black and i still had sounds yesterday but today no sound, I called vizio tech support they told me it was the gas...
when you here a loud pop its usually the sustainer boards. Have you checked the fuses on the sustainer boards first to see if they are still good. There is a IC chip under the heatsink and when it gets extremely hot it gives. Also check you power supply board to make sure you don't see any swollen capacitors, leaky or bulged out from the top. Let me know if that helps at all.
Oct 26, 2010 | Vizio P50HDTV20A 50 in. Plasma HDTV
I have a Vizio P50 HDM and while watching it last evening I heard a loud pop and the picture went into a very noisy/distorted condition. Sound is OK. Any ideas?
That loud pop is your Y and Z sustainer. Normally it goes out completly but yours is still half working. Not usally fixable yourself, because you may need to flash the control board f/w , which is proprietary and can't be aquired unless you work for them,
Jul 08, 2009 | V, Inc. Vizio P50HD Plasma Television
Picture went out on TV
you need to change the sustainer boards and TV will be good as new.
Apr 05, 2009 | V, Inc. Vizio P4 Plasma Television
Big POP no sound no picture
if you could see light orange or green is has power is probably teh Y and Z board
Aug 22, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
3 loud pops and picture faded away
ours was off all day and it pop 2 times and now no picture at all.
Jun 01, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Vizio P50DHTV20A 50in.
Call for warranty service! This can be a power supply failure.
Jerry G.
Apr 30, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Had loud pop and then no picture on the vizio 50in. plasma
TV was on with no picture problem. Left the room and when I returned the picture was very dim. Turned system off and turned back on. Picture didn't change, but heard a loud pop from the back of the TV.
Mar 25, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio 50" Plasma VP50
Hello SuziCanevaro,
This may have been the sound of electrolytic capacitors exploding. I would not suggest plugging the set back in until you can have it checked by a qualified TV technician. If you are skilled in Electronics and would like to work on this yourself, you will need:
The schematic diagram, a multimeter, a signal generator, an oscilloscope, and an isolation transformer.
I hope this helps,
Thank you,
Shuttle83
Feb 23, 2008 | Vizio P4 46 in. HD-Ready Plasma Television
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
