Question about Whirlpool GEW9250 Electric Dryer
E-2 error code on whirlpool duet dryer
Every now and again I get an e-2 error code at the end of the normal drying cycle. the clothes are all drying fine but is there something looming on the horizon?
  • 2 more comments
  • nseaton Feb 26, 2008
    I am getting a P6 on mine. I have tried to check the thermal fuse, but I can't tell if it is blown and I can't remove the wires to just replce it.
  • Anonymous May 20, 2008
    I do have the same E2 error code on my whirlpool duet "gas" dryer. The dryer starts, runs for about a minute then shuts off with the E2 error code. Would this also be the same as the electric dryer fix?
  • Anonymous Mar 18, 2014
    timed cycle increases even when clothes are almost dry
  • Anonymous Mar 28, 2014
    Dryer keeps running but clothes are not drying and code 69 appears
  • 770 Answers
“E2” flashes if the thermistor has shorted.
The thermistor monitors the exhaust temperature
and cycles the high-limit thermostat on
and off to maintain the desired temperature.
1. Turn the dryer off but keep the electrical
supply connected.
2. Make sure that the dryer is empty and that
the lint screen is clean.
3. Close the dryer door.
4. Select Heavy Duty, Timed Dry, More Time
or Less Time, End of Cycle Signal (Louder)
and Start.
5. If error codes E1 or E2 flash on the display
after 1 minute and the dryer turns off,
the thermistor, or the wire harness, is either
shorted or open. Check the wire connections
at the thermistor or the machine
control electronics board. If wiring checks
okay, replace the thermistor.
6. If the dryer seems to operate normally, remove
the exhaust vent and start the dryer.
7. Select the desired temperature cycle to be
tested, and select 20 minutes of Timed Dry
heat using the More Time or Less Time
pushbuttons.
Posted on Feb 25, 2008
  • Gary Davd
    Gary Davd Feb 29, 2008
    a P6 is not an e2 code ilooked for a 9200 model there is no p6 fault plz check model number again and fault code...
    Tig-ger did you fix the problem??
How knows what the heck was going on I swear that is what it said and I am positive about the model number. After I changed the thermal fuse it showed an E6 and when you pushed temp. it was an E7. After all that it was the door switch. I finally found a service manual and it helped alot more than the tech sheet. Thanks guys for all your help. I get kinda lost without my hubby!
Posted on Mar 01, 2008
Whirlpool duet sport gas dryer is not heating to dry clothes.Sounds like the flame lights at first but clothes are cold at end of cycle.
Scott, We apologize for what you are experiencing with your Dryer not heating. We would recommend service. If you would like for us to schedule service for you, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
May 30, 2017 | Whirlpool Dryers
My whirlpool duet dryer will not allow a normal cycle, it swicthes to delicate or bulky items
The control board is failing... I would use it until it will not dry clothes at all, then get it rebuilt for a fraction of what a new control costs. CoreCentric Solutions Reverse Logistics Core Collection and Recovery...
This place rebuilds controls and offers a one year warranty for about 130 bucks
May 22, 2016 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool gas dryer doesn't dry
Make sure vent hose in back of dryer is not blocked or stopped up.
Mar 16, 2014 | Whirlpool WGD94HEXR Duet Steam Dryer gas
Whirlpool duet dryer
Run the dryer for 2-5 minutes. Check to see if it has heat inside. If not, you have an internal problem.
If heat is generated, check your dryer lint trap. It must be clean before every dry cycle to dry properly and efficently. If the trap is clean and heat is generated, check the tubes behind the dryer for disposing of the lint.
Oct 15, 2013 | Dryers
Error code pf
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Error code E6 on a Whirlpool Duet Dryer
Whirlpool Duet electric dryer only dries clothes on heavy duty selection. what is wrong?
Dec 16, 2009 | Whirlpool Dryers
Alarm sound while drying
It sounds like you have it on the "wrinkle free cycle". (I can't remember what the cycle is actually called with out looking it up.) It will tumble your cloths and then alarms to tell you to take them out before they wrinkle. If you don't take them out, it will tumble them again and alarm again, etc.
Apr 13, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
MY CONTROLS ARE LOCKED
Press and hold the End of Cycle button for 3 seconds.
Jun 05, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GEW9250 Electric Dryer Logo
3,989 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
