Question about Brother MFC 9600 All-In-One Laser Printer
Will not fax
I thought my machine needed toner.  So I just went out and bought some.  Cleared the drum and installed the new toner.  But it still is saying maintenance 7 and the lights are blinking for toner, fine and s fine. What should I do?
  • saandra Feb 25, 2008
    didn't seem to work.  What does maintenance 7 mean anyway?
  • saandra Feb 26, 2008
    I'm wondering if the thing-a-mi-jig that connect to the toner needs to be replaced.  How often should it be replaced?  I don't know if it's ever been replaced.
    Genius:
  • 3,587 Answers
Run the cleaning routine on the menu, then try a test page print job..
Posted on Feb 25, 2008
WHY OUR MACHINE Di2011 DEVELOPER AND DRUM ARE BRAND NEW. BUT STILL BRINGS PROBLEMS E.G SERVICE CALL AND MACHINE TROUBLE SHOOT.
Was the counters cleared first? for the drum and developer, has to be done because the machine uses the counters to tell the copier what voltages to apply to certain assemblies. If not done causes codes and image problems. That is also how the copier has a new drum and developer, after the drum and developer where replaced was Toner Density procedure run. And no prints copies or faxes where received after the developer was replaced and running the Toner Density procedure, and any did get ne developer and start again. Must disconnect network cable and fax cable before changing developer also.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 01, 2014 | Konica Minolta Bizhub c203 Copier
I have a samsuns SF515 fax machine after changing the toner cartridge the message still appears "toner Empty" I have tried several new cartridges with the same issue.
if you have changed the drum/toner unit then the machine should have a fuse on top of the drum unit.I have come across some cartridges that don't have them on the unit.The fuse resets the fax so that it knows there is a new unit installed.If that does work then clear the machines memory using the control panel
Jun 14, 2010 | Samsung SF-515 Plain Paper Laser Fax
New drum
You need to open the front cover (where drum and toner is installed) and press the options button, it will ask replace drum? Press 1 for yes and close the front cover.
Apr 25, 2010 | Brother IntelliFax-2820 Laser Fax
I have a Brother fax and copy machine and have just replaced toner with a brother TN 350 cartridge and still getting message that toner is low
You didn't include the model, but here are instructions for the Fax-2820; it should work for any of the models that use the TN-350 toner:
  1. With the power on, open the front cover.
  2. Press the Options key. The display will read "Change Drum?"
  3. Press Start.
  4. Press 1 0.
  5. The display reads "Accepted" for about 2 seconds, then change to "Cover Open."
  6. Close cover. The "Replace toner" message should be cleared.
Normally, inserting a new cartridge (with the power on) will reset the toner counter, and you won't have to do any of this.
Dec 21, 2009 | Brother IntelliFax-2820 Laser Fax
Problem with Minolta Fax 3800,installed new drum, but still says change drum?
have to go into service mode to change the setting for new drum. sir did you install a new drum or the toner cartridge to different parts
Jun 25, 2009 | Minolta MF1600E Plain Paper Laser Fax
PAPER JAM
If you pull the drum out of the machine. Close front cover. is the noise still there. If it is then you have a broken fuser gear. If noise is not there remove the toner cart. from drum reinstall the drum unit in machine see if noise is there. if noise is there then it will be the drum. If not reinstall the toner try that if noise comes back then it is your toner cart.
Apr 11, 2009 | Brother IntelliFAX 4100 Laser Fax
Replaced drum fax 2820
Hi, #'s 6, 7 and 8 below explain how to reset the drum indicator.
Hope that helps...
Lbcoaster
How do I replace the drum unit?
Description:
Follow the procedure below to replace drum unit.
CautionDo NOT use flammable substances or any type of spray to clean the inside or outside of the machine. Doing this may cause a fire or electrical shock.
spray1.gif Caution
    Just after you have used the machine, some internal parts of the machine are extremely HOT! Never touch the shaded parts shown in the illustration.
  1. Open the front cover and pull out the drum unit and toner cartridge assembly.
Caution
    To prevent damage to the printer from static electricity, do not touch the electrodes shown below.
  1. Hold down the lock lever on the left and pull the toner cartridge out of the drum unit.
Note
    • Discard the used drum unit according to local regulations, keeping it separate from domestic waste. Be sure to seal the drum unit tightly so toner powder does not spill out of the unit. If you have questions, call your local waste disposal office.
    • Wait to unpack the new drum unit until immediately before installing it. Place the old drum unit into the plastic bag.
  1. Unpack the new drum unit.
  1. Reinstall the toner cartridge into the new drum unit. If you put it in properly, the lock lever will lift automatically.
all-ug-16.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Install the drum unit and toner cartridge assembly in the machine.
  1. Press Options.
  1. To confirm you are installing a new drum, press 1.
  1. When the LCD shows Accepted, close the front cover.
Related Models FAX-2820, FAX-2910, FAX-2920, MFC-7220, MFC-7225N
Aug 02, 2008 | Brother IntelliFax-2820 Laser Fax
Brother Intellifax 2800 replace drum message
the unit that you install the toner cartridge into is actually the drum on this machine.
Jun 24, 2008 | Brother IntelliFAX 2800 Laser Fax
New cartiage/not reconized
It says there is no cartridge, or does it say that the cartridge is empty?
First, you must realize there are two cartridges. A drum and a toner. If you bought a new toner, pulled out the drum and put the new toner in, you have pulled a DOH! You can't just put the toner in. You have to take your old drum cartridge, remove the toner portion and install the new toner into your old drum and then install the entire assembly back into the machine. I hope you didn't throw your drum out thinking it was all one cartridge (I've seen it happen). This is where reading the owner's manual helps.
If not, then one of the contacts must have been damaged. Remove the cartridge and look inside the machine. See if you can find any of the metal contacts on the side of the inner chamber that is bent or damaged and try to bend it back.
Check the drum and make sure none of the contacts are damaged.
If the unit is still saying Toner Empty, try this. On the left side of the toner there will be a while lever in a semi-circular notch.
Unplug the unit, use a small screwdriver or a key to push that white lever back to the front of the notch. Put the drum and toner back into the machine and plug the power back in.
Nov 29, 2007 | Brother IntelliFax-2820 Laser Fax
IntelliFAX 4750 Toner Empty
Hi, have you changed the drum anytime soon? If so did you clear the message before installing the new drum? The only other option would be to try a diffrent toner. There is not toner reset counter like there is for the drum! So I would reset the drum counter and see what happens. Good Luck
Nov 08, 2007 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother MFC 9600 All-In-One Laser Printer Logo
43 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
