45" mitsubishi TV with gray/black "water stains" on screen
I have a 45" mitsubishi rear projection TV and my 2 year old sprayed it down with febreze the first time which caused a grayish black half circle marking at the very bottom of the screen. The second time she dumped a mountain dew on it and it caused more grayish black markings. Is there any way to remove these markings? I'm guessing that the first layer of the screen needs to be lifted to clean under there because when I lightly push on the grayish black areas it seems a though there is a thin film over the actual screen. My guess is that the liquids got trapped between layer 1 and layer 2. Am I on the right path here? Can this be fixed? PLEASE tell me YES!
  • Rpasos Feb 27, 2008
    I have a similar problem with my kid that sprayed windex on my screen and a gray/black 'water stain' is on the corner and bottom of screen. did you manage to get an answer or solution to your problem? Does anyone have a solution? thanks.
  • Anonymous Apr 08, 2009
    Man I need help my 3 year old sprayed our big screen with water ,trying to help mommy clean. I tried to take a blow dryer to it and nothing working, I'm really praying it will dry up on it's own.
    Top Expert:
  • Televison & ... Master
  • 24,347 Answers
If the plastic screen has not been damaged by chemical properties in the liquids, the screen does not separate. Time will tell.
Posted on Apr 04, 2017
2 Suggested Answers
  • 58 Answers
SOURCE: Mitsubishi TV Screen Water Stain Problem
You can use warm water and a soft cloth to try and clean it, but it will probably leave some evidence that liquid existed between the two layers at some point. Mitsubishi will deal screens directly to their customers if you ask nice enough and are willing to install yourself.
Posted on Jul 05, 2010
Jul 05, 2010 | Mitsubishi WD-62525 62" Rear Projection...
WD-52525 52 in. Rear Projection HDTV Television: My grandson sprayed water on the screen and it got...
Only if it is the protective front screen that the issue is with. the only way to take the protective screen out is to open the tv. A service tech can do this for you however it will not be a cheap fix.
May 07, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Black line on hitachi projection tv
sounds like the water has went under the rim and dried there the line will never disapear
Jul 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Cleanng the projection mirror
remove the speaker grill, you will see the screws holding the front screen, remove the screws and the connectors going to it and slide the screen up and off.
Sep 18, 2008 | Mitsubishi VS-45603 45" Rear Projection...
Black opaque line or bar
if its is viewable when off then yes its water or oil.between the screens.these screen don't normally come off from the front.
they have to be access from the rear.
could be big job.
only way to tell is to remove the rear cover.
Apr 13, 2008 | Hitachi 51F500 51" Rear Projection...
Cleaning black front panel
Depending on what type of screen you TV has, many have plastic frenel screens that react to certain cleaners such as ammonia and alchohol based. These compounds can permanently damage the screen causing a cloudy area where it was sprayed. Unfortunately nothing can be done except to replace the screen.
Mar 14, 2008 | Sony KP-51HW40 51" Rear Projection...
TV screen jumps and rolls, sometimes won't stay on
Try Re-soldering the vertical yoke connection and the vertical output IC. Thats a common problem in that model.
Feb 26, 2008 | Mitsubishi VS-45607 45" Rear Projection...
TV Screen
There should be 2 to 4 screws, depending on the model, to take out on the bottom of the screen assembly, then you lift the entire screen up and pull it out towards you. Good Luck
Aug 15, 2007 | GE 46GW945 46" Rear Projection Television
Green or black and white retangle checks no piture
. Check for proper seating of connector DB between the DM PCB and Signal PCB. 2. Suspect the FMT PCB part # 930B924002
Jul 26, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
351 people viewed this question
Top Televison & Video Experts
