Question about Raymarine A65 Combo GPS Chartplotter/Fishfinder
RAYMARINE A65 COMPLETE FAILURE
Unit shutdown completely for no apparent reason and would not power back up,checked all related connections with no solution.unit turned itself back on 2 hours later,remained on and functioning for several hours only to shutdown again?
    Novelist:
  • 113 Answers
Was the engine running when it shut off? How was the voltage at the time it failed? The A65 will shut down if the voltage drops below 11.2 volts.
Another common cause would be corrosion on the plug where it plugs into the back of the display, or the terminal connectors that attach it to the boat's power supply.
It could also be a bad crimp on the terminal connectors. Make sure connectors are the right size for the wire and that they are marine grade, such as Ancor brand connectors. I also recommend heat shrink style connectors,
I have not heard of any software issues for that model so I am betting it's a wiring issue. However, there is an update available from Raymarine. There were changes made to the WAAS satellites and the update helps it recognize the new satellites. You can download it for free from Raymarine. Copy it onto a blank CF card and plug it into the card slot on your GPS. When you turn the unit on it will prompt you on how to proceed with the update. It will fix any known software gliches at the same time.
I hope this answer helps. Please reply if you have any questions about my response.
Posted on Feb 26, 2008
When i tun on my raymarine a65 ,i get gray and white lightly shaded vertical lines. what is the problem
Check cable connections, reseat all at both ends(so say the book) Now disconnect all cables, CAREFULLY open the housing, visually check internally.Perform as a surgeon would do, reseat all connections(flex cable,wiring,IC's,& the liquid crystal LCD display) clean as necessary with electronic spray cleaner & red eraser. Reassemble. Reconnect. Good Luck.(definition of 'reseat'- unplug or move unit in socket to reconnect the components leads)
Nov 02, 2015 | Raymarine A65 Chartplotter Fishfinder...
A65 unit does not indicate proper position. When alongside a buoy it shows the buoy ahead by about 50 feet. When the buoy is 50 ft behind the sail boat, the A65 shows it abeam. Even my handheld Garmin does...
You may be aware that the system is "detuned" for security reasons. With GPS, repeatability is the key. A bouy is NOT a stationary item, especially at low tide, I suggest that you test your accuracy with stationary objects. A map (chart) cannot know which way the tide is moving a bouy, only the approximate anchor location, the bouy floats and moves....
Mar 04, 2011 | Raymarine A65 GPS Receiver
MY RAYMARINE A65 CHART PLOTTER/ FISHFINDER HAS NOT BEEN WORKING , THE CHARTPLOTTER WORKS FINE , BUT THE FISH FINDER WONT PULL UP BOTTOM OR ANYTHING . I LOOKED AT THE LITTLE BOX THAT CONNECTS TO THE...
Likely your DSM25 (that little box that connects the transducer to the display) will need to be rebuilt. The red LED is saying that there is an internal fault with the unit. You would need to send the unit in for repair through Raymarine (as there really is not anyone else who can do it), and they would have to replace the main circuit card in the box. I believe that they are charging either $150 or $175 to repair those now... but likely the only way you will get that one to work again.
Jul 27, 2010 | Raymarine A65 Combo GPS...
Panasonic AG-DS550 VCR shuts itself down about 2 seconds after switched on. No error code appears in that brief interval. Toggling the power switch immediately is ineffective, but after waiting a while,...
This is a typical symptom of a power supply failure. There are some self-checks performed at power-up that are not completing correctly. Were there any symptoms before the complete failure? Often, the units start to behave strangely before complete shutdown. The power supply failure is tied to defective capacitors in most cases. These supplies are what are called "switch-mode" supplies and must oscillate to work. Defective caps will either not provide the kikcker to start the oscillation or prevent the oscillation completely. While there are other causes, this is the most common. AG units are professional decks and should be serviced by authorized service centers.
Hope this helps,
Dan
Dec 07, 2009 | Panasonic Televison & Video
Hello! Our Raymarine A65 will not start up. It starts a boot process but does not show "Raymarine A65" on the display and no chart is displayed as it usually does. Regards Odd
Probably a bad printed circuit board, just had to send mine in to have it repaired. When I hit the power button, I did hear a beep, but then nothing displayed. Mine was still under warrenty, so don't know the repair cost if yours is not.
Jul 15, 2009 | Raymarine A65 Combo GPS...
Troble2
Hi, my name is adam and i would love to graciously help you. In your description you stated you need a wiring kit. I have a link included from ebay and you can go on there and hopefully find what you need. http://shop.ebay.com/items/?_nkw=A65+Raymarine+&_sacat=0&_fromfsb=&_trksid=m270.l1313&_odkw=A65+Raymarine+fish+finder+wiring&_osacat=0
Jan 09, 2009 | Garmin 340c Fish Finder Dual Frequency...
A65 Raymarine combo gps plotter fishfinder
your local marina should be able to tell you and they most likely are a dealer for seadog or diversified which will sell your parts just give them your model or just take the unit in with you
Oct 16, 2008 | Garmin 340c Fish Finder Dual Frequency...
Raymarine A65 Shuts off Whenever it is in the mood
My A65 was constantly shutting itself off. I did the reset and the unit is working just like it should now and I have had no more problems.
Go to Setup, System Setup, then Settings Reset and press Enter. This returns all settings back to their original factory values. It should not reset your waypoints or route lists. Raymarine recommends you backup your waypoints on a separate Compact-Flash card but I didn't do that as I wrote down my all my coordinates. Hey I'm a fisherman all I care about are my fishing spots.
I'm not sure what setting it was that I changed that caused the adverse affect of the unit shutting itself off but resetting the unit did the trick. I was more careful about adjusting the display settings to my liking by doing them one at a time and waiting to see if the problem returned. It has not so far, knock on wood, and the unit is working the flawlessly now.
Aug 07, 2008 | Raymarine A65 Combo GPS...
Raymarine A-65 unable to find satalites
If you have a loose RS12 try moving it around the deck and see if it make a diffrence.There might be something knocking it out.
If it is doing a cold start it cold take up to 10 min to get a fix. Once it has a fix it will aquire the next time much quicker.RS12's are mostly rock solid and get great fixes.
Also set the time up on the A65 to what you are at ,IE, universal time minus 5 if you are on the east coast of the US.Time set up is under the units menu. Hope this helps
May 17, 2008 | Raymarine A65 Combo GPS...
Raymarine A65
When the engine starts, there is a voltage drop as the starters crank, followed by a power surge as the alternators kick in and the voltage comes back up.
Ferrites are only there to prevent RF (Radio Wave) interference from other onboard devices.
You should either:
-add an isolated battery to the boat to service only your electronics. That way it is unaffected by the starters.
-There are several devices on the market like Newmar Power's "Start-Gurad" that automatically switch electronics to backup power during engine start. They work great and the electronics don't skip a beat.
Nov 16, 2007 | Raymarine A65 Combo GPS...
Raymarine A65 Combo GPS Chartplotter/Fishfinder Logo
458 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
