Fuse Help me find the fuse on my TV!!!
  • 5,568 Answers
You may not get a sensible answer unless make and model number are supplied.
Posted on Feb 25, 2008
Lecy blew tv wouldn't come back on change fuse in plug still no light on tv does 42" lg hd tv have a fuse internal.
Yes, TV's have an internal fuse on the power supply. All too often though more damage is caused besides a blown fuse or the fuse doesn't serve the purpose and the power supply is damaged. You can check and replace the fuse as necessary. If you need a replacement power supply, here is a list of vendors below. Have your TV model ready to help you find the part you need.
www.tristatemodule.com
Nov 04, 2013 | LG 42LC2D 42 in. LCD HDTV
Keep blowing the main fuse.
To which circuit section did you replaced the fuse? Main power retulator? Just understand, the fuses are used to protect the circuit and TV from any short circuit or over voltage. Without any one of these, no fuse will blow up. If it was due to over voltage, the set should work after a fuse replacement. But here, the fuse blow up again, means, there is some thing shorted component/s. Check which component is shorted, and replace it, before replacing an other fuse. One more thing to say is, never insert a fuse other than specified. The voltage and ampere specification to fuse, will be marked at the circuit board, very near to the fuse clamp. Insert a fuse of same rating only. Using other fuse, rated higher ampere rating, might make things worse.
May 27, 2013 | Mitsubishi WD-73827 73" HDTV DLP TV
Emerson CR202EM9 is just dead. Tried to reset like discribed in the troubleshooting with no help. Is there a fuse or something that could effect power?
Hello
Surely there is a fuse inside it. Its rating will differ according to your househlod voltage. If it is 220VAC, the fuse for a 20" TV will be of about 3.5Amps, and if it is 110VAC, the fuse will be about 6Amps. Before replaceing the fuse, you just check for any short circuit inside the power supply reguator section of your TV. Without any reason fuse won't get burned. Just keep this in mind and open your Tv, and check the entire regulator section with the help of a multimeter, set in Ohms range, for any short is there or not. If there shows any short, get it repaired first and put the new fuse, otherwise the fuse you are going to insert will also get burned. Check it with patience. If you wants furthermore assistance, get me through Fixya. OK.
Dec 12, 2010 | Emerson CR202EM9 TV
Tv dead power through on/off switch
yes there is a fuse.that is located on the main board.and that fuse is mostly blown and needs to be replaced. you can get new fuse at  www.radioshack.com at the rate of $2.
May 05, 2009 | Televison & Video
Blown fuse on panasonic tv
Maybe the horizontal output IC are on short circuit.
Nov 04, 2008 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Unknowing fuse
In most cases on the board under the fuse the rating will be listed IE: 4A, 5A etc.
Jul 17, 2008 | GE 27GT616 27" TV
TV will not work
Hello dnjmartz,
Your friend is correct there is a fuse in your televisions's power supply. Now I do not however suggest that you open the TV set and try to find it, because it's not like the old days where the fuse was located in or around about the same area in most TVs . The fuse in this case might be towards the middle of the set or on the power supply board in any location so finding the fuse will be the biggest chore. However here are some simple instructions of how you might be able to find the fuse.
1. unplug the TV
2 take the back off of the tv
3. using a flashlight look for a component that looks like two round metallic cylinders separated by a glass cylinder.
4. remove the fuse from the fuse holder
5. visually inspect the fuse for internal burning (black soot)
6. if possible test the fuse with an ohmmeter should read 0 ohms
7. Replace the fuse with one of the same voltage and current rating (check for replacement fuses at radio shack or some place like that)
8. After the fuse is replaced try to turn on the TV before putting the back on "BE VERY CAREFUL DANGEROUS VOLTAGES ARE PRESENT"
9. If the TV comes on you are read to turn the TV off and put the back of the TV back on.
10 If the TV does not come back on you will have to get the set looked at by a qualified TV technician since if the TV does not come on it may be the result of a power supply malfunction.
I hope this helps,
Thank you,
Shuttle83
Jul 14, 2008 | Orion1934 19" TV
RCA big screen tv
whenever fuse blows every time it is the indication of short circuit in tv. so please do not put fuse unless you know the cause of blowing fuse. these are the reasons of blowing fuse. 1 main filter cap.short. 2 rectifier diode short. 3 swithing transistor short 4 horizontal output transistor short 5 caps & diodes connected to flyback transformer short. 6 print short. 7 at last if every thing ok then flyback transformer defective. hope this will help. if you are not a tech person call skilled tech to fix it. good luck
Sep 24, 2007 | RCA P60828 TV
TV Fuse
Most of the time the manuafactirers put the fuse around where the line cord comes into the back of the TV set. are you sure the fuse is bad? Are you thinking the fuse is bad because the TV set will not come on?
Mar 26, 2007 | Durabrand DWT2405 24" TV
Televison & Video Logo
Top Televison & Video Experts
