Question about Kitchen Appliances - Others
Tefal quick cup - descaling problem
Hi we have bought one of the new Tefal 'Quick Cup' machines (heats water in 3 seconds). It has indicated it needs descaling twice - first time we followed manufacturers instructions (run a descaling programme with clear vinegar) and all was fine. Have done the same again this time, but it continues to indicate it still needs descaling, not sure what to do. Thanks
  • 2 more comments
  • gemtkd Mar 08, 2008
    We bought ours 3 days ago and it only worked for 1!! It keeps flashing a red light at the top and only serving cold water. I might have to take it back to. Can someone help?
  • Anonymous Jul 06, 2008
    Sounds like you used the ordinary cycle when you descaled your one cup. You must push hot and cold together for 5 seconds to launch the descal cycle. The unit then resets the light when complete
    Justme28
  • Anonymous Apr 02, 2009
    I purchased the Tefal quick cup for Christmas, having worked perfectly since it's now idicating the need for descaling. I've changed the filter and run the descaling programme but still the light is flasing and I'm unable to use the machine.
  • dave0w May 21, 2009
    i have the same problem, BUT....
    when you launch the descal cycle what is meant to happen, i held donw the buttons and all that happend was my red's light just stopped flashing the machine did nothing or nothing that i could see
Push red and black for 5 seconds to lunch descale then unit resets light at end oy cycle
Hampshireman
Posted on Jul 06, 2008
  • Hampshireman Jul 06, 2008
    When you fit a filter you must hold red and black buttons together until light goe out. SEE INSTRUCTIONS
    Hampshireman
Thanks for comments... no we did launch a proper descaling programme as per manufacturers instructions which took the full length of time, not an ordinary hot water cycle.
We have previously sucessfully ran the descale programme, it was the second time the unit needed descaling the problem started
In the end we took it back
thanks for trying, though
Posted on Jul 07, 2008
Tefal quick cup kettle water coming out in slow spurts,have changed filter but no improvement.
If you are in a hard water area you may need to descale the heater element. Try adding 1 cup vinegar to 3 cups water and run the machine should clear up the scale. Rinse thoroughly before use.
Sep 12, 2010 | Tefal Kitchen Appliances - Others
Just bought a tefal quick cup from john lewis and we have lost the instructions, could you tell me how to turn the blue light off on the top when you change the filter . thank you.
Follow this procedure when you change the filter:
Press the hot water button H and the ambient water button G, for at least 5 seconds.
After 5 seconds, the indicator light will go out. The appliance will then have recorded the cartridge change.
If you are happy with my response pease vote for this answer.
Thanks
Mar 05, 2010 | Tefal Kitchen Appliances - Others
Hello tefal quick cup water is no longer hot only
we had to return our first one for the same problem Gavin. Tefal (surprise surprise) claimed that nobody else had EVER had that problem. 2 years down the track though, and i've discovered that mine turns itself on at random intervals, and floods the kitchen bench. My advice - get a refund while you still can...
Mar 03, 2010 | Tefal Kitchen Appliances - Others
I need to descale my tefal quick cup but have lost the instruction book. Where can I get a copy of the instructions?
Hi. Post the link below into your browser, it takes you direct to the Tefal site wher the full instruction manual is. All you then need to do is save or print the information contained in the ten page PDF document:
http://www.tefal.co.uk/NR/rdonlyres/56C464A4-21F4-478C-A376-C40A50AE592D/0/quick_cup.pdf
Good luck, hope its what you are looking for. Let me know?......Regards ...Cornwellnet (UK)
Jul 09, 2009 | Kitchen Appliances - Others
Tefal quick cup
Press the Hot and Cold button for 3 seconds,
The red indicator light will start to blink,
Release the hot and cold buttons and while the red is still blinking, press the and hold the hold water button, Once the desired amount of hot water is reached release the hot water button.
Now press and hold the hot and cold water buttons simultaneously for about 3 seconds.
The red light will stop blinking to the end of the programming.
NB the RED LIGHT WILL BLINK FOR THE DURATION OF THE PROGRAMMING.
Repeat the process for the cup quanity selector for the cold water.
------------------------------------The end -------------------------------------------
Feb 28, 2009 | Tefal Kitchen Appliances - Others
Tefal Quick Cup
ALERT :- Tefal Quick Cup can TURN IT SELF ON. Tefal know about this but it is a potential fire hazard. Mine turned itself on and dispensed the water reservoir over my kitchen. Dread to think if I had been out shopping what could have happened. Tefal know about this problem but are not doing anything to advertise the fault!!
Jan 19, 2009 | Kitchen Appliances - Others
Tefal Quick Cup not heating water
press the hot button on off 5 times and on the 6th let it run a cup full. This will re set the temperature
Dec 15, 2008 | Kitchen Appliances - Others
New Tefal One Cup, and it has stopped heating the water, FAQ says it needs descaling, but it is only two weeks old ???
Sounds like Mfr defect. Do not recomend trying to repair since it is new and could void any warranty. Recomend returning to where you bought to get a new one.
Jun 22, 2008 | Heating & Cooling
Tefal Quick Cup not working
This is in my opinion a design problem. The wiring connects to the spiral heating element via spring loaded contacts which only have a tiny connection surface area. These gets arcing deposits on the surfaces and will periodically require scraping clean. To get access prise off the silver top assembly which is a snap fit, unclip the circuit board and pull the plastic water pipe off the top of the plastic cylindrical tank. Then remove the two star screws from the base and prise it free. The whole internal assembly can now be carefully removed intact from the kettle housing but the circuit board at the top will need to be turned vertically and guided down the main body on the way out.
Jun 04, 2008 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
3,731 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
