Question about Nikon Coolpix 5700 Digital Camera
Viewfinder is black
When I turn on my camera and take offf the lens cap the viewfinder is black and I can't see the object that I want to take a picture of. I can see the menu and the settings. I would really like some kind of info so I can start using the camera again.
  • 2 more comments
  • cretia634 Feb 27, 2008
    Same problem. Everything seems to work fine except camera "sees" only black. The flash goes off every time I take a pic. I put in a fresh battery and reset the camera to factory settings. Nothing helped.
  • llewelyn Mar 18, 2008
    when i turn on my camera the monitor and the viewfinder is black and i cant see the images i want to take a p[icture of......
  • Anonymous Jan 28, 2009
    My screen is not a solid black but has a static haze over it. When I take a photo, the static transfers to the photo itself.
  • 2crowsons Jan 29, 2009
    I see nothing but black in the view finder or the LCD screen on my Nikon 5700.
To those of you having the problems with the black screen or a "jumbled colors" screen. There is a recall on this camera for that problem. I work for a Police Department and we bought 12 of these cameras. We have already had to send back 9 of them for this problem. Here is the link for the form dealing with the recall. They will repair it for free in about two weeks. Just follow the instructions.
http://nikonsro.com/email_images/nikonusa/service_advisory/cp_service_form.pdf
Nicholas Smith
St. Cloud Police Department, MN
Posted on Nov 19, 2008
    Novelist:
  • 100 Answers
If you're asking about the electronic viewfinder (where you put your eye to the back of the camera), that can be turned on/off via the SEL button at the button right corner of the viewfinder. In fact, the LCD screen staying on/off is selected with the same button. Press it three times to cycle through the various modes of "viewing". If the viewfinder or LCD stays off after cycling through the SEL button selections, I would say your camera needs to be serviced at a repair shop.
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
Posted on Nov 17, 2008
Why is there is no image, only a black screen with icons
You could have a setting for looking through the viewfinder only, which turns off the LCD display.
Of course, make sure your lens cap was not left on. Also there is usually a setting for looking at pictures you took. or looking through the lens. If you have no images saved, there will be nothing to see.
Set the camera back to view through lens.
May 11, 2014 | Canon Cameras
When i turn on the camera the lcd screen is black and when i turn off the lcd the viewfinder is also black, no objects are seen, menu items can be seen but no objects
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Feb 20, 2010 | Canon PowerShot S2 IS Digital Camera
Black screen on my s6500 fd
I assume you removed the lens cap...;-)
If both the viewfinder and the screen is black, it is most likely an error on the CCD. If the viewfinder is OK, but the screen is dead, the problem is probably the LCD.
Hopefully you still have warranty on the camera?
Oct 02, 2009 | Fujitsu Cameras
My Canon 300D SLR will turn on, and led display comes up saying battery is full and yet when you go to take a photo you cant see anything but black through the lens.
Obvious Questions, but you didn't supply the information.....:
1. Is the lens cap off?
2. Are you looking through the viewfinder? You will *NOT* be able to use the LCD screen as a viewfinder.
Otherwise, there is always a light path through the lens to the viewfinder, so....
1. Have you tried a different lens?
2. Have you checked the mirror is down?
May 26, 2008 | Canon Cameras
JVC Digital Video Camera GR-DVL107E
Assuming you don't see any video through the viewfinder, it could be that the CCD has died on that camcorder. It happens, though not frequently.
If the video though the viewfinder is clear, there might be some sensor on the lens ring to indicate a lens cap, or an automatic lens cap not properly disengaging when put in record mode.
Jan 20, 2008 | Video Cameras
Opaque in viewfinder, screen and picture
There is no sensible fix - new camera time.
Jun 13, 2007 | HP Photosmart 945 Digital Camera
Can't see out of viewfinder
The mirror motor is probably the problem, you'll usually hear a whirring noise like a motor spinning. It's about a $125 repair, requiring the mirror box to be removed and the mirror driving motor replaced. Pentax originally put a plastic gear on the motor shaft - the replacements have a brass gear.
Nov 25, 2006 | Pentax ZX-30 QD 35mm SLR Camera
Why is part of a picture missing?
The cause and solution may include one of the following: Something was blocking the lens when the picture was taken. Keep hands, fingers, or other objects away from the lens when taking pictures. Your eye or the picture was not centered correctly in the viewfinder or LCD. Leave space around the subject when centering the picture in the viewfinder or the LCD.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Nikon Coolpix 5700 Digital Camera Logo
117 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
