Question about Samsung SC-D363 Mini DV Digital Camcorder
I have vertical multicolor lines
I have these lines on my screen and I talked to a couple people about and they suggested get a head cleaner. So I did and did what the package says but now i get a buzzing noise when I close the tape compartment all the way and a flashing "D" with what looks like an eject symbol next to it and it says eject on the screen too.
  • Kmcookiv Feb 26, 2008
    I have pink fat lines across my screen as well, and the recording will not transfer - it say's recording is corrupted.
    I have tried the head cleaner as well - I did nothing. I recieved and online qoute for repair $269. I can get a new recorder before I spend that and the shipping back and forth too!! URG
  • sweetcat_18 Mar 06, 2008
    Rishabh89 I'm not using prerecorded from another camcorder I don't have another one. I hardly ever do video i use it more for the still shots nowadays. I'm thinking of justgetting rid of it. lol Thanks for trying though.
I think u are using pre recorde cassetts that were recorded on any other camcorder..
Samsung D363 supports ntsc not pal....
and the cassetts recorded on pal must have prob with ntsc based device...
all u have to do is record cassette with the same and then test playback...
Posted on Mar 06, 2008
Fix vertical lines on plasma tv
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 28, 2016 | Samsung PN50C450B1DXZA 50-inch Class...
My HP omni 100 all in one has vertical lines on pictures only, how do I fix this?
In most cases, stationary lines mean the screen is failing. If there is flickering, the LCD cable or a connection could be the problem. If the screen is normal brightness, the inverter is most likely not the cause.
It may only show up only on pictures because they are the only images with solid blocks of color.
Jun 05, 2015 | HP Computers & Internet
Multicolored lines run vertically on the screen. Is it fixable? not sure what happened. Tv was given to me. Can see the picture otherwise.
The tv could have a dead tv LCD screen panel because of it is damages by a person or an object by hitting it.Than the tv it is not worth it or repairable if it is require a new tv LCD screen panel.Will cost the same as a new tv,if tv require a new tv LCD screen panel replacement.The LCD screen panel tv that have multicolored lines run vertically on the LCD screen panel and people given it to u and said not thing.The tv probally have a dead tv LCD screen panel already,Sorry tv like this,it is a garbage tv now,it only can be used as a salvages tv only for it electronic circuitries boards only.
May 08, 2011 | Televison & Video
Left 1/4 of the screen is black( vertical) the remaining has multicolor lines running vertically
This is an issue with your LCD cable that hooks your LCD to your motherboard.
You can try this site for the part.
http://www.laptopking.com/lcdlist.asp
Apr 21, 2010 | Toshiba Satellite P35-S611 Notebook
Vertical multicolored lines appear. Sometimes there are couple of vertical white stips and vertical lines
Connect an external monitor to your laptop. If the problem appears only on the display of the laptop and not on the external monitor in the same time that means the video card is ok and the problem could be : the screen of the laptop or the invertor or the cable that attaches the screen to the mainboard. Have it checked by a professional.
Oct 05, 2009 | HP Pavilion zd8000 Notebook
Ps 27123 have sound, tuning etc only small horizontal color band
Hello bdedrick708,
If what you are trying to say is that you have a 1/4 inch horizontal line across your screen, this means that something in your vertical deflection circuit has failed. This could be the vertical oscillator, the vertical output processor, the vertical coupling capacitor, or the vertical section of the yoke transformer.
If what you are talking about is a vertical line from top to bottom then you are possibly talking about a failed horizontal section of the yoke transformer.
Why so little about the horizontal section of the yoke? That is because if the horizontal section fails completely then you would lose high voltage and no line would be present because you would not have raster (screen light).
In any even check the yoke transformer first. Then work back from there.
I hope this helps,
Thank you,
Shuttle83
llc.com/">http://www.electron-age-technologies-llc.com
Feb 07, 2009 | Proscan PS27123 TV
Vertical multicolored lines covering the whole screen
Just a shot in the dark, but if you are using component video cables, double check that they are in the correct inputs and outputs. If this doesn't work or you are not using component video cables then I don't have any other ideas as of now.
Oct 05, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Hitachi 51GWX Scrambled Picture
STK392-560 STKS convergence CHIPs Replace both of them.
Feb 24, 2008 | Hitachi 51GWX20B 51" Rear Projection...
Samsung SC-D363 Mini DV Digital Camcorder Logo
109 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
