Question about Whirlpool GGW3878J Dryer
LG tromm electric dryer not heating up
My dryer is not heating up so I moved another dryer in as a spare til I fixed the LG and now this one is not heating up so I am guessing it is something with not a high enough voltage but they both worked before last Thursday. I have checked cords and circuit box and checked for any tripped breakers...Nothing what can I do?
  • Karn71 Feb 27, 2008
    I do not think it is a heating element on dryer Because I have tried two dryers on the same outlet and neither are heating up... something electrical I am thinking?
Check the heating element. That is the part that warms the dryer up to dry ther clothes
Posted on Feb 25, 2008
2 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: LG tromm electric dryer not heating up
Most likely you have a bad electrical connection, resulting in only 120 volts to dryer. (enough to run the 120 volt motor, but not enough to power the 240 volt heating elements) Turn off breaker. Make sure wires on breaker are tight. Make sure nutral wire is tight in breaker box. Take cover off dryer recepticle and check the wires in it to make sure they are all tight. Check that the connections of the cord at the dryer are tight.
Posted on Nov 04, 2008
Lg tromm electric heater has no heat
check ur heater element, the hi limit and the thermal cut off fuse.
Aug 27, 2014 | LG Tromm Electric Dryer
My LG Tromm DLE 5977W will tumble but won't heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Aug 03, 2011 | LG DLE5977 Electric Dryer
My LG Tromm DLE2532W dryer is not producing any heat
heatman101./,'
May 15, 2011 | LG DLE2532W Electric Dryer
My dryer doesn't heat.. How can I fix thus
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 03, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg dryer stop heating after i stuffed it witha blanket front load gas dryer Tromm 3 years old. I completely cleaned it, but still won't heat I can fix it with your help
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 23, 2010 | LG DLE2514 Electric Dryer
My LG tromm dryer wont heat and i don't know how ignite the pilot
heatman101
Aug 02, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
Nov 04, 2008 | Whirlpool GGW3878J Dryer
Lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Mar 01, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Dryers Logo
205 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
