Question about IBM ThinkPad T30 2366 Notebook
No vedeo on T30 LCD
I bought a IBM T30 from e-bay which has no video on the LCD. I hooked a external monitor which works fine. I switched the LCD, Video cable, Inverter board from my other working T30 to make sure all these parts are good but still can not get video on the LCD. I have also changed narrow circuit board with the close lid switch and still no luck. what else can be wrong except to change the motherboard? any help, thanks.
Albert
Hi, everybody!
I'm albertsai from Myanmar,Asia. http://www.albertsai.co.cc
Posted on Oct 07, 2008
Hello Sellar,
Am tony Auditch from uk i need your items for my Wife in west African so i want you to send me the total cost of the item+ the shipping cost. here is my Email tony_auditch@yahoo.com yy_auditch@live.co.uk
tThinks
Posted on Sep 04, 2008
That has happened to each of my T30s, 3 times altogether. Drop or jolt damages the mobo. I've tried swapping parts (incl. LCD) between machines to no avail. The only fix was to replace the mobo, and that worked every time. BTW, shining a flashlight at the LCD, you can barely see an image, but it's there. But the problem is the mobo, not LCD, not inverter card, not LCD ribbon cable.
...I
Posted on Feb 27, 2008
  • 97 Answers
Could be the back light
http://www.fonerbooks.com/laptop_5.htm
Posted on Feb 25, 2008
My ibm T30 thinkpad screen is not working
It's hard to say, but if I understood correctly, your screen still functions as long as it does not stay on for a long time.
There are three possibilities
1- Video card (If you have an external monitor, plug it in and see if the same issue occurs. If so, the video card is the issue)
2- The flat cable which carries the signal from the video card to the LCD screen. (Does moving lid only (screen) causes it to behave differently? (If so, it may be the flat cable)
3- The LCD itself (In case none of the above apply)
Mar 04, 2013 | IBM ThinkPad T30 2366 Notebook
Laptop broken screen... plugged in Dell monitor,still doesnt work
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 03, 2012 | Computers & Internet
How to display on lcd
The bottom left key is labeled in blue, Fn. Hold down this key and press the F7 key at the same time. Repeating this will toggle between an external monitor and the LCD. If this does not work, try connecting an external monitor to the blue 15 pin VGA connector on the rear panel of your T30 and try this again. If you get external video you will know your video chip is working properly, but your LCD may not.
You didn't provide enough description of your problem to help you further.
Jul 06, 2012 | IBM ThinkPad T30 2366 Notebook
Hey I got an IBM T42. It boots fine when its clear but after that it horizontal lines being to appear througout the scree.
Either you can hook up an external monitor or access BIOS setup (Basic Input/Output System) to replicate if the horizontal line appears. This step will check if the problem is with the video card or the LCD.
If you get the horizontal line on the BIOS or never get it on the external monitor, then surely the LCD screen is beginning to fail. You need to reinsert and/or replace the LCD inverter or LCD itself.
However, if you see the horizontal lines on the external monitor but not on the BIOS, try to update the video driver. If this will not resolve the issue, you need to replace the video card or the motherboard of your laptop.
Hope this helps.
Jun 06, 2011 | IBM ThinkPad T30 2366 Notebook
My ibm thinkpad t30 boots up but my monitor is blank
Do you hear any startup sound when you turn it on? If there is, try hooking an external monitor. If it has good display, replace LCD, if not then it may be a videocard problem. possible motherboard replacement will resolve this issue.
May 25, 2010 | IBM ThinkPad T30 2366 Notebook
My T30 turns on but the screen doesnt work?
Try to attach EXTERNAL MONITOR to check if you have display from External Display and to confirm that your Laptop System is still working. If you got display from external monitor, therefore you have a faulty LCD / Inverter (gives your LCD a back-light)
Apr 06, 2010 | IBM ThinkPad T30 2366 Notebook
I have a problem with my ibm thinkpad notebook i want to connect my notebook hp projector how can i
When you connect a data projector or a monitor to the video output connector on the laptop you can toggle the display in various configuration by press and hold the blue Fn key and then press the F7 key (once or a couple of times as required) this key has a blue symbol of a pair of monitors.
Press it once the LCD will switch off and the display will switch to the external video output.
Press it again and the display will be on both the LCD and the external video output.
Press it again and the display will be only on the LCD.
Jan 17, 2009 | IBM ThinkPad T30 2366 Notebook
IBM T30 won't boot with LCD, but will boot OK with external eonitor
It means computer developed oxide on some contact, and this is causing a short that forces unit to shut down, laptop must be taken apart, dried properly, and eventually cleaned with circuit cleaning solution.
If problem stops when you turn to external display, then probably it is water or oxide in LCD ribbon cable connectors.
Aug 10, 2008 | IBM ThinkPad T30 2366 Notebook
IBM T30 LCD replaced - now LCD display not right resolution
Yes you can do that by trying to set the sesolution settting.
Step for setting up screen resolution
1.Click start-->Settings-->Conteol Panel-->Display
2.Under Display Properties window click the last tab name settings
3.Below you should be able to see Screen Resolution
4.Try to adjust the resolution here.
** Please try to reduce the resolution ...or sometime add more resolution
takecare.
Apr 29, 2008 | IBM ThinkPad T30 2366 Notebook
Iseries thinkpad
try hooking it to an external monitor and see if it works.If it does then you need to check which part is bad.Possible defective parts in order of the cheapest is :inverter card,then LCD Cable,then LCD Display,then system board.If it does not work with external monitor then try drivers or system board because the video is built into the board.If all else fails I will buy it from you if the price is right.
Mar 21, 2008 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
200 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
