If the water overfills only when the ice maker cycles you probably have a bad ice maker.
If the water comes in when you turn on the line to the unit from the house line you have a bad water valve assembly in the back(dual valve) The only thing you can do is leave the water off until you replace the dual water valve.
Water valves work on a hydraulic principle, the water pressure acting on the inlet surface area closes the valve. It takes the electric solenoid to overcome this. You can also unplug fridge and see if water is still coming in to ice maker, then you are sure it is a bad valve.
Replace ice maker
