Question about Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint bf162 seems to be stuck in middle of dishwashing cycle
  • Anonymous Mar 03, 2008
    I start the dishwasher on heavy wash, everything seems to be normal then it stops after 20 seconds. any ideas?
  • 185 Answers
After the 20 seconds does it restart
Posted on Mar 28, 2008
My BF162 runs with the door open. I also cannot
Yup, could be that pesky door latch, or even the control panel board. This could be a case for a repair man or replacement, depending on the cost.
Sep 25, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
The program light goes off and the BF162 doesn't start...
When you keep the button pressed for a few seconds the lights go off, this resets the dishwasher. Then press the p button again to the program you want 1st light is heavy soil 2nd light is normal soil, 3rd light is eco wash, 4th light is rinse. At the end of the cycle the program light you have selected will flash.
Apr 24, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
My BF162 dishwasher won't start
it might be flooded in the tray underneath due to a blockage, try loosening the bottom panel (3 screws) and emptying it of water and re setting. Clean out all the traps etc in the dishwaser to make sure nothing is blocked
Mar 15, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint BF162............. Water left, not draining
Open the bottom panel of the washer and see if it is full of water, if it is drain it away and clean all of the filters inside the washer and reset.
Mar 04, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint bf162 built-in dishwasher error codes
take out diswasher, tip it backwards and drain out water. make sure that salt resovoir is on tight and there are no leaks from the arms
Jan 11, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint DF23: Wont go through full cycle
Sounds like you may have to replace the cycle timer.
Oct 28, 2008 | Kenmore 24 in. 16539 Built-in Dishwasher
Dishwasher drain issue
check to see if there is anything stuck in the drain pump. it not, replace the drain pump, as it's malfunctioning.
Sep 13, 2008 | Dishwashers
2+4 - Heating circuit not working. Possible causes - Heating element, connections, timer relay.
Maybe too late a response.
Ian
Feb 10, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
BF162 DISHWASHER HOTPOINT
I think if you push the heated wash and heated dry button several times until all the buttoms light up this will fix your problem.
 A clean light that flashed repeatedly 7 times then off. Reset as above with the heated wash and heated dry buttons. You may then noticed a reduced flow from the pump so dissasemble the lower arm and water inlet assy.You may find it mostly plugged with foregin matter and some othe junk. Upon removal of that stuff and reassembly,It may work as new!
Feb 09, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
BF162 Hotpoint intergrated dishwasher
consult manual under troubleshooting.
if no manual, or if it does not address this, consult service center.
one likely cause you can try first is to disconnect it from power via the cord or a breaker. after a brief period, it may reset itself.
otherwise you likely have a logic board issue.
logic boards seem to be very vulnerable in dishwasher environments. the type of issue you have is very common among most brands. don't feel alone.
good luck
mark
Dec 28, 2007 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint 23 in. BFI62 Built-in Dishwasher Logo
242 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
