Question about Intel D865GBF Motherboard
Same problem MY HDD IS IDE HDD. AS YOUR ADVICE I SET THE JUMPER CORRECTLY, BUT REMAINS THE SAME PROBLEM. THEN I REPLACE ANOTHER IDE HDD. BUT IT HAS SAME PROBLEM. THEN I REMOVE THE IDE HDD AND JOIN A SATA HDD(COLLECT FROM A FRIEND). NOW THERE IS NO SUCH PROBLEM. BUT I WANT TO USE IDE HDD.PLEASE SOLVE MY PROBLEM. THANKS IN ADVANCE. BYE....
  • RIPAN Feb 26, 2008
    YES FRIEND, I CHANGE THE HDD(IDE), BUT THE PROBLEM REMAINS, A SOUND OCCURS AND THEN AUTOMATICALLY SWITCH OFF.I CHANGE IDE CABLE AND JUMPER TO 1ST, THEN 2ND , THEN 3RD. THEN 4TH.THEN I REMOVE THE IDE HDD AND JOIN A SATA HDD. NOW THERE IS NO SUCH PROBLEM. PLEASE ANSWER.I AM WAITING.
Try changing the IDE cable, if this does not work enter BIOS setup utilityand ensure HDD detection mode is either aouto select or IDE depending on your BIOS you may have to look for a setting that allows you to use IDE not SATA or both.
Posted on Feb 26, 2008
  • 37 Answers
You didn't tell what happen to your HDD after you set the jumper?...what to your HDD?..is it not detect?..Have you tried to change your IDE CABLE, instead changing the jumper settings to you HDD?..
Dell Gx60 doesnt recorgnize hdd and cd rom
If both the HDD and CDRom are on the same cable, try replacing the cable. Check the jumpers to make sure they are set correctly as well. If neither of these work, it's likely your IDE controller (that is where you plug the ribbon cable into your motherboard) is defective. You can try to move it to the other IDE controller to see if that works. If not, you may have to replace the motherboard.... assuming you know the HDD and CDRom drives are good. I hope this helps!
Sep 23, 2011 | Dell Optiplex GX60 PC Desktop
I have a 250gb seagate sata but when i put my 80gb IDE hdd it only detects in booting and in bios but after that if i open my computer i cant see my 80gb IDE Hdd and even in device manager my hard disk was...
there was wrong in the set up of jumper in your 80gb hdd. Look closely to the 80gb harddrive, in between the ide cable terminal and the power supply connector you will see 8pin terminals paired together and a jumper use to short the paired terminals. It is most likely that the jumper was configure to detect your hdd as master. If the ide cable you use for the 80gb hdd was also use for the dvd/cdrom drive then it will conflict with it if both jumper setting was set to master. See the description of jumper settings in the sticker of the hdd. Position the jumper to slave.
Reboot your system again and see if the 80gb finally appear in your system. When system boot upon detection of hdd, the primary master should be 250gb while your primary/secondary slave will be read your 80gb hard disk.
Jan 24, 2011 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
My Dell vostro 1510 starts bt the hard drive is nt detected.......I hav tested the hard drive, it's all right....plzz help!!
make sure hdd is set "master". make sure ide cable is connected correctly to hdd and mb. may have to change jumper setting on hdd either to "master" or "cable select". in bios, make sure ide control is set to "both".
Oct 23, 2010 | Dell Vostro 1510 Motherboard System Board...
"no valid device!" message
Did you connect your HDD correctly?
If so have a look at the back of your HDD, next to the IDE port you will find a small jumper, make sure that jumper is set to master.
Enter your Bios and check that your boot priority is set to boot from the HDD first.
Also make sure that your IDE cables are firmly connected on the motherboard as well as the HDD.
Keep me posted
Aug 16, 2009 | Computers & Internet
Setint the jamper as a 2nd drive and Do i need to farmat it frist
If I recall right this HDD is a PATA (IDE) type. As for the Jumpers please check the following link. The jumper should be as Slave drive.
http://www.helpwithpcs.com/upgrading/install-hard-drive.htm
May 15, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Hard disk not dectecting
Is your Hard disk running at all ?
Can you hear some spinning noise and vibrations when it starts running?
Check the jumper settings (Master/Slave/Single).
If you have another device connected on the same cable (HDD/CD), check jumper settings on that device too.
You may first try to disconnect other device (if connected).
It is a very old PC, try replacing the data cable of your HDD, and pay attention of the correct connection of cable to the motherboard and HDD, too !
Check BIOS settings if both IDE channels are enabled.
Regards.
Mar 28, 2009 | Intel Motherboard
Jumpers
You can only have TWO (2) Devices in IDE - Master and Slave.
For example
Cable 1 (ide channel 1)
Master - HDD
Slave - Tape Drive
Cable 2(ide channel 2)
Master - CD/DVD drive
Slave - HDD
Do you have a diffrent type of cable?
Oct 08, 2008 | HP DDS-4 20/40GB (c5683-00255) DAT Tape...
Connecting an IDE HDD to a SATA port using an IDE to SATA converter
Not complete product...need to buy additional adapter for IDE to SATA power source.
IDE drive will have to have the power source hooked up as well as the adaptor hooked up.
Installing the adaptor only will not work. Your computer should have the 4 pin plug for the power to the IDE drive, other wise you will have to buy another adaptor.
Mar 23, 2008 | Intel Motherboard
INTEL 865 GBF TURN ON PROBLEM
You know the problem HDD. Why not try another HDD?
Good luck
Feb 23, 2008 | Intel D865GBF Motherboard
Msi p4m800pro ide issues
No Boot (system does post) - Hard drives not detected • Check jumper settings on all IDE devices • Verify that IDE controller is configured correctly in the BIOS • Check to make sure that the drive is connected to the correct controller • Make sure drives are configured correctly for RAID • Verify Onchip IDE configuration for ICH5 SATA operation is set correctly • Test drives with different IDE/SATA cables
Dec 19, 2007 | Intel Motherboard
Intel D865GBF Motherboard Logo
229 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
