Question about Yamaha RX-V1900 Receiver
Rx-v1900 hdmi hdtv problem
HDMI cable connected to the tv wont send signal to the tv. its not the cable we tried others that work, it transmits hdmi between the bluray & receiver just fine. its still under warranty - any ideas?
    Novelist:
  • 128 Answers
On most modern receivers you must select which signal type you want it to process.
for example on my Denon, I have to go into the on screen menu and select the input I want ie: video 1.Then tell it which signal I want it to use ie: s-video, component or HDMI input for video and then which input corresponds to the audio signal for that component ie: analog, digital, optical or hdmi.
Its complicated and a pain in the ****
Hopefully that helps call Yamaha they will usually walk you through the process while on the phone.
Posted on Feb 19, 2010
SOURCE:
My Iomega mx mobile mass storage player has stopped sending signal through HDMI cable to TV all other functions are ok. HDMI cable changed still no picture
You need to try some tests.
  • Does the same cable work with any other TVs
  • Do any other devices work on your existing TV ?
You also need to check that you have set the output of your device to HDMI and the input of the TV to HDMI. In the past the TV may have automatically selected HDMI when the device is turned on but sometimes that does not work.
Mar 23, 2014 | Iomega Computers & Internet
Have blue screen from HDMI inputs other inputs OK
The first thing to check is the cable, have you tried it on any other HDMI device (if you have one)? The cables are durable but not indestructible and even brand new it could be a bad unit.
On a less likely consideration: Since HDMI is a digital format (as opposed to RCA, S-video and VGA which are all analog) it requires certain compatibility. While ALMOST all HDMI device (DVD players, computers, game systems) use a pretty universal language for HDMI there are occasions where that they are not compatible, this also applies to the cable itself since it does minor translation in the process of transmitting the signal. Again, this would be a rare occurrence.
The third option is that the HDMI ports on either the device sending to the TV or on the TV itself are not working.
Oct 22, 2013 | Sony KDS-R50XBR1 50" HDTV
What is HDMI
Its a vidio/audio input which looks like this. If you have an hdmi port on a laptop you can connect it to a TV and have the audio and video transfer to the TV.
Mar 16, 2011 | Computers & Internet
Through Sky+ HD when selecting the HDMI connection I get the following statement through Sky "This diplay does not support HDCP....." Any help please Rob
hi,
try to connect the set top box in any other HDMI input of ur tv. reason is bellow read it carefully.
p { margin-bottom: 0.21cm; } HDCP stands for High-Bandwidth Digital Content Protection and was developed by ----------. It's nothing more than a security feature requiring compatibility between the sender and receiver, like HD cable set-top box and the TV. By compatibility, mean HDCP technology built into both devices.
Think of HDCP as a security license key like you would input when installing a computer program. Only this security key is invisible to you and me but not your TV.
It works by encrypting a digital signal with a key that requires authentication from the transmitting and receiving product. If authentication fails then the signal fails, which means no picture on the TV screen.
Buy a HDTV that has HDCP capabilities. Most will have this in at least one HDMI input but be sure to verify this before buying the TV.
Notice that "in at least one port." Not every HDMI port on the TV will be HDCP compliant so be sure to read your TV user manual if you plan on connecting a HDMI cable to your TV.
ok
Jan 13, 2011 | Toshiba 32WL56 32 in. HDTV-Ready LCD...
Hdmi Port wont work on PS3
you need to go into your console video settings and setup for hdtv to use hdmi.
May 21, 2010 | Sony Playstation 3 (PS3) Console
HDMI out jack physically broken on my rx-v1900. Fixable?
An audio repair shop should be able to get a replacement connector and swap it for you. I doubt that the part is available from Yamaha (and it would be pricy if it was). The connector shouldbe available generically. Digikey or Mouser should be a good source.
Dan
Nov 18, 2009 | Yamaha RX-V1900 Receiver
Bad picture
  1. Hello boss, here is d way to make best use of it.
    step 1.Make sure ur LCD or Plasma HDTV has an HDMI port. Hopfuly u bought 1 with it, if not, you may be stuck using component cables. Not bad, but not he best. Component cables change d digital signal frm the cable box into an analog signal. This conversion allows for signal degradation. U want to keep the digital signal transmitted frm the cable company 2 go directly into ur HDTV. An HDMI cable will provide u wid this capability n with d clearest picture.
    2. Make sure ur cable box has an HDMI port. Most cable companies do not offer a cable box with an HDMI port on the initial install. You may need to upgrade by calling your cable company and asking if they have a cable box wid HDMI capability. Ask them 2 send u 1.
    3.Purchase an HDMI cable. TIP - The longer d distance between the cable box n d HDTV, the better d quality HDMI cable. This is due to degradation of d digital signal over long distances, wiz could result in a poor quality picture. ne distance over sixteen feet should be compensated 4 by using a heavier gauge HDMI cable. Oh yea, don't get taken by buying the most expensive cables. From what I have read, companies are cashing in on this relatively new technologymag-glass_10x10.gif. I bought my "gold-plated" HDMI cables from an Ebay Store, "eforcity" for about a quarter of the price found at the local electronic store. Connect one end of your HDMI cable into the HDMI (out) port on the back of your cable box and connect the other end to the HDMI (in) port on the back of your HDTV.55
    Read the instructions that came with ur new HDMI compatible cable box. These instructions will explain the download process the cable box needs to go through before use and the Setup Wizard that will program the cable box to send the correct picture format to your HDTV. If u did not get instructions, u can get them at the cable box manufacturers website. Scientific Atlanta's website: http://www.scientificatlanta.com/products/consumers/new_cableboxes.ht64. Adjust video, audio, and screen settings to ur liking. The explanation for these settings can be found in ur HDTV's user's manual.75.Push ur "source" button on ur remote control or HDTV n select HDMI. Tune to a Hi-Def channel. Most Hi-Def channels r in the 700 channel range. Check cable company listings 4 d specific channels.
  2. Have a nice time!!
Aug 19, 2009 | Sharp LC46SB54U 46 in. LCD TV
Unable to play DTS-HD & True-HD
What do you hear? Do all other modes work ok?
If Audio Select (Page 44 and 98) is set to HDMI you will hear silence if no HDMI signal is present. I think AUTO is the best choice here.
On Page 98 of the manual it says a bunch of things concerning automatic signal detection and input selection.
Initial configuration D) INIT. CONFIG
Use this feature to select the settings of the audio input jack select, active decoders and extended surround when you tum on this unit.
Audio select AUDIO SELECT
Use this feature to designate the default audio input jack select setting (see page 44) for the input sources connected to the DIGITAL INPUT jacks when you tum on the power of this unit.
HDMI set E)HDMI SET
Use this feature to select the component to play back HDMI audio signals.
Support audio S. Audio
Use this feature to select whether to play back HDMI audio signals on this unit or on another HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = RX-V663
FUNCTION
Plays back HDMI audio signals on this unit. The HDMI audio signals input at the HDMI input jacks of this unit are not output to the HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = OTHER
HDMI component connected to the HDMI OUT jack.
NOTES
This unit transmits audio and video signals input at the HDMI input jacks to the HDMI out jack only when this unit is turned on even if "S.AUDIO" is set to "OTHER".
I'd look in these areas for specific guidance.
Apr 22, 2009 | Yamaha RX-V663 Receiver
Yamaha RX-V1900 Receiver Logo
897 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
