Question about Emerson Em1200 Answering Machine
My em1200 does not work
Since i got this thing i have had problems now it freezes up i tryed
to unplug it and plug it back in the line moves around to a
certain point then it freezes again it is only 1 month old,
i am not happy with this product and will try what you say
to do and if i still have problems i will trash it
I am having trouble setting the date and time. More important is I can't record nor hear the default greeting. Can anyone help me?
Posted on Sep 03, 2008
Are ice maker stopped working, so we need to reprogram it
*Check your warranty. You should call vendor for service.
*** The following is for information only.***
* I've had this problem a lot with my old fridge. Water line works but no ice.
* Check if the "Ice Full" leaver is in the down (no ice) position. Some ice makers will lock the leaver (a stiff wire) in the full position to manually shut off ice maker. Make sure it swings up and down when ice tray is empty.
* Sometimes when the tray is left full of ice for a week or more then the tube feeding water will freeze up. Defrosting the freezer on a regular basis will help. A quick fix is to pour warm water in the ice maker section (where the ice is formed). This will help melt the clogged pipe and also make some ice while your waiting. You may have to do this several times. But at least you have ice.
* This (freezing up) may also be caused by the freezer set too cold. The temperature dial should be in the middle. But turning it colder and colder over time will cause ice to build up and prevent foods from freezing properly (thus turning the dial down colder.) Once your maxed out on the dial. You will find the freezer gets warm and things get covered in frost crystals.
* Transfer food to another refrigerator and perform a complete defrost by leaving it unplugged and the door open (freezer section).
* Frequently check and dump water at bottom of fridge. Clean the dust on coils while down there.
* A fan blowing into the freezer section helps. (Do NOT use a heated fan as it will warp the plastic and overpressure the refrigerate.)
* Once defrosted (+4 hours). Power up the freezer and set the temperature dial to mid point and the freezer diverter to middle or normal setting. Don't put the food back in yet. Wait till the freezer gets down to normal freeze temp (about 0 to 10F)
* Move freezer back in place (if you moved it to access plug) then slowly put back the food. Try not to cram stuff in. Leave space for air to flow freely around items.
* Final, Call for service anyway and have them perform yearly service. Check your warranty.
Aloha, ukeboy57
Mar 12, 2018 | Refrigerators
Hi i have a fridgemaster fridge freezer and it was moved from mil house on Wednesday. It now will not freeze although it does get some ice at the back of freezer but then defrosts itself. The fridge will...
Have you made sure that that the water connection to the ice-maker is secure and without leaks or stopped up (kinks) in some way? I would suggest that you unplug it for bout 30 min., then plug it back in. See what happens about after 45 minutes. If it was moved, you want to make sure you have tapped into the main water line. It doesn't just magically happen. Sometimes the simplest things can cause immedite problems.
Jan 18, 2018 | Siemens Bosch Neff Integrated Fridge...
My system is plugged in, however, the display screen is blank
Try seeing if all the cables are plugged into the right places properly. Ive noticed that sometimes when I move my screen around the plug comes out the socket just enough to stop the connection. If its none of these then it could be something more serious.
Jun 08, 2011 | Computers & Internet
Maytag Performa fridge has stopped making ice -- I changed the water filter to make sure that wasn't the problem. The water in the door works fine and there is plenty of pressure in the water line but the...
First, I'm not a Maytag tech.
Check your warranty. You should call Maytag/Sears for service.
Aloha, ukeboy57
Feb 20, 2018 | Maytag MTB1504A Top Freezer Refrigerator
Good Morning! I work for a small business that has 5 of the GE 2-9451 4 line phones with intercom. We were actually running two businesses out of the same office originally. Line 1 would ring in to...
Since you said line 3 was working for #2 company, i will suggest you put the line 3 back from where you removed it from. From the look of things the line might be the only line connected to be functioning. When ever you want to switch line since it is with intercom you will need to switch both side from where it is connected to where it is connected to, so that network connection can be achieved.
And on the other hand, the other line might not be working properly, that is why it was not connected or used.
Take care.
Apr 08, 2010 | GE RCA 4-Line Speakerphone
I'm looking to rotate phones around the office so that they can remain with their employee. Basically, I want to plug in the original phones to another line and reprogram for the original extension with...
In my workplace, when you move the Nortel M7100 phone, the programmed info (extension number, etc) moves along, just like if I was rewiring all phones. Have you tried just to unplug the phone and plug it on the new location? Here the extension number moves along with the equipment... (Nortel Norstar M7208 and M7100). Good Luck!
Jul 02, 2009 | NorStar M7310 Corded Phone
Fridge quit cooling after i moved it
did you tilt it when you moved it and then when u got it in place plug it in? if so youve got compressor problems, anytime you tilt a fridge you have to let it set for several hours to allow the oil to get back to the compressor or you ruin the compressor
Jan 01, 2009 | Refrigerators
My memorex mltd3222 will turn on for a split second and when the memorex logo comes up, the screen goes out
I don't have a permanent fix, but I do have a work around:
The problem appears to be some sort of "loose connection" associated with either the power plug or how the back of the TV is mounted to the front. Try the power plug first: we unplugged/plugged the plug from the back of the TV (i.e. not the wall) multiple times, jiggling it around a bit each time we plugged it in, and did so until we didn't hear the "pop/click" (i.e. the sound we've come to associate with the problem)... Voila! It started working again.
If that doesn't work, try removing all the screws from the entire back panel, moving the back panel up/off a bit (but completely removing, and being careful not to disturb any of the connections to the DVD player, etc.), and then do the unplug/plug thing. We're guessing that moving the back panel around is essentially facilitating the unplug/plug thing.
Our repairman discovered this when he tried to fix it the first time. He removed the back panel but then the TV immediately started working, so he couldn't determine what the actual problem was. He gave it back to us, and it worked for a few months and then the problem came back. We did the panel/unplug/plug thing and it started working again.
Hope this helps!!
Oct 18, 2008 | Televison & Video
HP Officejet 7410 All-in-one No Power Light
Turn the printer upside down right underneath where the cartridge station is you will find a small white gear...sometime it may be covered with a blue rubber cover.
when you turn the gear ..the barrier in front of the cartridge will go down.
Then do a rest on the printer and then install it.
Jun 08, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Ref non-freezing
Is the compressor running? Is the coils near the compressor clean and is the fan that blows on the coils running? Does it get cold at all or is it room temp? One thing to do is to turn it on after leaving it unplugged for and hour. First access the compressor and make sure you can feel the copper lines coming out of it. Some have 4 plus a service pigtail. On the ones with 4 will have two lines the same size that circulate oil for cooling the compressor running to a small set of coils. Pay attention to the larger and smaller lines and notice what temperature they feel like before you plug it back in. Once it is plugged in and if the compressor is running less than a minute the small line should get hot, up to 140 degrees F. Check it soon as after a few minutes it can burn you...The largest of the lines is the low side or suction side and it should be very noticeably cooler than room temp and continue to get colder the longer it has been running. If both these things happen, the charge should be adequate, and the compressor is working. I would then check to see if air is circulating in the unit..Are all the fans running when the unit is on? Most common is for the defrost circuit to fail causing the unit to build up ice behind the liner blocking air flow. Unplugging the unit and leaving the doors open over night will let it thaw. Put several towels around the unit incase this is the problem as there will probably have more water come out than the small pan under neath the unit can handle. Once all the water stops dripping out, plug it back in and see if it works correctly. If so it will probably freeze up again and need to be defrosted again. If so the defrost circuit has failed....either the thermostat in that circuit, the heater coils or the defrost timer switch. Switch very common, coils next and the high temp sensor last.... let me know what you find...
Feb 15, 2008 | Refrigerators
Emerson Em1200 Answering Machine Logo
148 people viewed this question
Top Emerson Lands Phones Experts
David Burbee
David Burbee
Are you an Emerson Lands Phone Expert? Answer questions, earn points and help others
