Question about Harman Kardon AVR 125 Receiver
Front Display Dimming - Almost Totally Gone
I have an HK AVR 125 and I've had it for several years under normal use (4-5 hours per day). Two years ago I moved into a new house and relocated the receiver to my bedroom along with DVDplayer, VCR and Satellite box (all sitting on top of Receiver).
I have noticed that the Display window is now starting to dim to the point where it's almost totally out. What can be done to stop/ repair it so that I can see my display again?
  • chillimost Feb 26, 2008
    I tried the previous, and it didn't work. My Display lights are still Dim.
    Anyone else have a solutions? Any help is appreciated.
  • Anonymous Apr 15, 2009
    I have the same problem, annoying
Check and see if you don't have a auto dim setting on or you changed Display setting.
I have same Amp and this happened to me also.
Posted on Feb 25, 2008
HK AVR 125 display strobing and no sound, even in headphone jack
Hi...
Find someone that does TV or audio repair and have them open it up. A cable assembly may have loosened during the MOVE.
Cheers
Jan 30, 2014 | Harman Kardon AVR 125 Receiver
The heater shorted out, sparks, electrical smoke. Is it salvagable or should I replace?
Yes you could say it has died 18 years has been very good time to look for new . I don't think you will get parts for it now .
Feb 23, 2012 | Lakewood Oil-Filled Electric Radiator...
Harman/kardon avr 247 no audio or LED display on the reciever
I've had the exact problem. HK in the states is no help, you need to deal with a company in Montreal (Jan Industries). Regular techs are unable to fix it without schematics that only authorized dealers have and the manufacturer. This problem happened to me just after 2 years and outside warranty. I've bought a Yamaha today.
Apr 01, 2009 | Harman Multimedia AVR 247 7.1 Channels...
Static and popping from Harmon Kardon AVR 340
You seem have a problem with a component in that channel, the bad news is that it is hard to fix that type of problem (you would be better off if the channel died). All of the components in the final output section are part of the same audio loop (per channel), which makes it hard to find the faulty part.
Sounds to me like a bypass or coupling capacitor is faulty or need to be re-soldered, either way to fix this problem you should take it in to a repair shop.
I hope that helps and sorry for the bad news.
Jan 28, 2009 | Harman Kardon AVR 25 MKII
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
AVR 120 5.1 -dolby surround sound & logic 7.
The problem is fixed...
and every thing sounds great !!
Thanks for the premium assistance to help solve my problem...
Pierre
Dec 07, 2008 | Harman Kardon AVR 120 Receiver
MID-RANGE DISTORTION
hi it is an amp module failure inside £129.00 plus vat 4 hours to replace total strip out £380.00 total to do these are made by samsung and rebadged horrible things dump it thats my advice regards kirk
Oct 14, 2008 | Denon AVR-3806 Receiver
HK avr125 5.1, no display, no functions.
Same problem. C901 on the vertically-mounted input board next to the power supply transformer was burned. Replaced with ceramic cap from RS with same specs. Still did not work. Talked to Jeb, great guy at HK tech support. He suggested that R901 would probably be blown and maybe 902 also. These are flame-proof resistors and do not show damage. Tested with multimeter and Jeb was spot on. Replaced 1w resistors with 5w (all RS had) at same resistance. Works great.
Jun 20, 2008 | Harman Kardon AVR 125 Receiver
Was using the harmon kardon avr 225 receiver and the front panel went out. .... screen display of the channel number, volume, or menu item does not work. ...
Try hooking up a yellow video wire from the back of the AVR 225 Monitor out. Should be at the end of the 7 or 8 yellow video ports on the back of the stereo. Next plug the other end into a yellow video in on a t.v. Get your remote, (Harmon/Kardon) and make sure the t.v. is on the correct video input and hit the OSD(on screen display) button on your harmon remote. There should be a setting in there that says VFD under ADVANCED menu option that allows for turning the front of your stereo lights on and off and dimming them half way also. OFF/HALF/FULL are the 3 options I believe.
If this doesnt solve it your display may have crapped out on you.
Jan 22, 2008 | Harman Kardon AVR 225 Receiver
Harman Kardon AVR 125 Receiver Logo
443 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
