Question about Durabrand DVD-1002 DVD Player
DVD/CD will not load and ejects
When I place a dvd or cd in the player, all it does is display 'load' then the counter on the player reads 000000, the it ejects the disk. I load the Durabrand DVD player with the DVD, it says that it's loading, then the message "No Disk" appears.
  • 99 Answers
Junk it and buy a better player...cheap dvd players fail quickly..
Posted on Mar 31, 2008
Dvd player won't close
In some cases the DVD alignment with the Laser heads are not true and correct causing this problem. This happens a lot with a Copy of a CD/DVD and especially if it was made on another computer. Use original DV/CDs if you can.
Dec 29, 2013 | Polaroid Dvd Player Dvp-1000
2008 cadillac 6 disk dolby dvd/cd sound system will not play or eject disk
Alien is right, pull the Radio Fuse, then put it back in and eject the CD/DVD. Happens to me sometimes with burned DVDs, seems like the player is picky on the CD/DVD media. Rebooting the device (by pulling the fuse) is the only way to eject it.
Dixit
Dec 02, 2012 | Televison & Video
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
I have a Samsung DVD R160 recorder. A few days ago the recorder was not on and it was making a noise like it was trying to read a disk. This went on for quite a while. I then turned it on and it would...
Try this, look for a small hole on the front of the unit.Use a pin and press in to see if it opens,ejects the disk .If no hole try seeing if you can press ,lift,pull at the door/slot while pressing the open door/eject either on the unit or with the remote control.It sounds like you may have a bad CD/DVD (copy) that the unit is trying to read/load but can't. keep trying to eject CD/DVD if this doesn't work unplug unit for 5 minutes,try open door again do press and hold open repeatedly I know it's frustrating but it just may eject.Don't use this recorder for playback of DVD buy a $30 DVD player the cheaper the better they play anything.GOOD LUCK
Jan 04, 2011 | Samsung DVD-R160 DVD Recorder
It will not load cd or dvd it keeps coming up
The loading mech or poss. the read portion of the disc player is out of whac. In other words the cd dvd portion of your deck is defective and short of having it repaired by a techinition there isnt much you can do. Its a **** shoot but you may be able to unplug the unit let it set for a few minutes and plug it back in may rest the mech., but like I say its a **** shoot. Sounds like its time for a new deck or a trip to the repair center.
Jul 30, 2010 | Dual Electronics XDVD710 Car DVD Player
Won't read Dvd/Cd as loaded
It is a problem of the optical head being covered up by foreign particles obscuring the optical lens. Try using a CD/DVD cleaner disc which has double brushes and one add some solvent which comes along with the pack.Simply play it & keep ejecting and inserting the disc makes the disc to spin, till your player starts reading it..............................sodeep
Oct 06, 2009 | Coby DVD-224 Player
Dvd in in player and won't eject. screen reads "loading".
Try unplugging the unit and plugging it back in after a couple of minutes, if cd still won't come out you can unplug the unit and manually remove the cd by taking the outer casing off.
Sep 07, 2009 | Alpine DHA-S680 6-Disc CD/DVD Changer
Loads dvd tries reading ejects dvd
Run DVD/CD cleaner CD using 2 drops of solvent on the brushes and run the cleaner CD twice, the last one being a dry one. If the DVD's are not scratched they will definitely play....sodeep
Jun 15, 2009 | RCA DRS720N DVD Player
Jvc dvd XV-N322S REGION CODE-2 is showing 'NO FILE'
It's a software problem pls upgrade ur dvd player.ur problem will be solved
May 11, 2009 | JVC XV-N322 DVD Player
Durabrand DVD-1002 DVD Player Logo
641 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
