Question about HP Photosmart 2610 All-In-One InkJet Printer
Color printing from Windows XP Photoprinting Wizard
With Windows XP color management set to "Automatic" and using Windows XP Photoprinting Wizard, I get prints with brownish/palish flesh tones. If I set Windows XP color management to "Manual" (say sRGB), I get good colors. Any idea why? Thanks -- Fred J. color is distorted and pale
I have lost the orig. disk to install? have tried everything even talk to tech support which was no help
i am computer dummy can someone help step by step? to reinstall HP Photosmart 2610 all-in-oneprinter-fax-scanner-copier w/no disk ? THANKS ALLY
Posted on Oct 15, 2008
    President:
  • 2,072 Answers
Just dirrerent intrepertations by the driver.
Often times "auto" settings are not the best to use.
You can default it to the best management solution for your computer/printer matchup.
Sounds like a weasly answer I know, but it is amazing how much different those will operate one system to another.
Another suggestion, color normally prints better with a PS, Post Script, driver then a PCL , driver. You may want to go ont the website for your printer and see if there is more then one driver, and switch drivers to see what happens.
Subtle differences in drivers can make a difference how printers print also.
Most of the times it's finding where your printer works best.
It is not necessarly a problem if one setting works better for you over another. Just nuances on different systems.
Please don't take this as a wise comment, but that is why all those adjustments are on drivers and printers, sometimes you just have to modify to get what you really want quality wise.
Hope this helps.
Posted on Feb 25, 2008
  • Rick Kasper Feb 25, 2008
    Should have said different in the first line. Duhhhh
I have an HP officejet 4215 printer. I cannot get the cartridge (color) 57 to print color! It has been working fine with the smaller cartridge but due to high level of printing, I was told to get 57. I...
If all the the computers connected to this printer via network:
  • Shut them all down except for one.
  • Go to that computer and go to your printer and fax settings
  • Identify the Hp OfficeJet 4515 and right click on the icon and select properties
  • On the General Tab, click on the button that says, "Printing Preferences"
  • Select the "Features" tab and go down to Color Options and check to see that the radial button is green for Print in Color option
  • Underneath that, there is another setting thatsays, "Color Management".
  • Check to see that it is already selected with, "ColorSmart/sRGB or Adobe/rgb
  • Click Ok and return to the Properties
  • Go to Color Management Tab and check to see that it is set to Automatic.
  • Underneath that, you'll see "Color Profiles currently associated with this printer.
  • Look to see that the field is populated, if not click on ADD, and select each color profile that is available
  • Click apply, then OK
  • Shutdown Computer
Turn the printer off, unplug the power from it, wait a couple of minutes, then plug power back to printer, then power it up.
  • Restart the computer you were working with
  • Go to printers and fax options window
  • Select the HP OfficeJet 4515
  • Right click, select properties
  • On General tab, click on, Print Test Page
  • Go to printer to see if printing test page
  • Check to if the Microsoft Windows logo was printed in color
If it is in color, then print the color document you were previously attempting in color.
If it does not print in color, you will have to check your settings on the program that is being used for the document.
Jun 02, 2011 | HP Officejet 4215 All-in-One Color Photo...
My brother MFC 240C was set for printing only black and white, since I had only installed a black cartridge. Now I have installed the three color cartrdiges also. How do I change the settings to print...
You have to change the settings in your print driver. In Windows XP or Vista, go into the Control Panel and the Printers & Faxes applet. Right click on the Brother print driver and select Properties. In one of the tabs there should be an option for either Grayscale or Color printing (probably under Color Management) -- change this to Color and then click OK or Apply to save the changes.
By changing it in the print driver settings, the change should take effect for all programs that you print from.
Jan 02, 2010 | Brother Multi-Function Center MFC-240C...
HP LaserJet 1500... prints color yellow ONLY
It's possible that the toner in the cartridge is not evenly distributed. You can redistribute toner if you gently shake the cartridge from side to side, then reinstall it to see if this affects performance. Please also see this article.
You might wish to use the guided troubleshooting option available from HP support here. Or have a look at the troubleshooting section in the user manual here. Then clean the engine & calibrate the printer, as described pg. 88.
If that's no help, please see this forum post and the linked attachments within.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 01, 2009 | HP LaserJet 1500L Color Printer
Can't print in color on my Canon printer
If you go here you can download or view a manual for your printer, with detailed instructions on changing the print cartridge settings in windows or mac.
If you go here, you'll be taken to the home support page for your printer, where you can enter a search for "print in color", and detailed instructions will follow.
You go to control panel>printers>print preferences> and uncheck the grayscale printing and set the color to auto.
Issue: Image prints black and white instead of color....See below.
Solution: Uncheck Grayscale Printing checkbox (Windows)
Unchecking Grayscale Printing Follow the steps below to change the Grayscale Printing option:
  1. On the Windows desktop, click 'Start', point to 'Settings', then click 'Printers' (Windows XP: On the Start menu, click 'Printers and Faxes').
    For Windows Vista: Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
  2. Windows 2000/XP/Vista: Right-click the printer icon, then click 'Printing Preferences'. Windows 98/Me: Right-click the printer icon, then click 'Properties'.
  3. On the Main tab, click on the 'Grayscale Printing' check-box to remove the check-mark.
  4. Click the 'OK' button to save the setting.
Jul 28, 2009 | Canon PIXMA MP460 All-In-One InkJet...
In my Paint Shop Pro 7 program, my photos show in color. However, when I go to print preview, they are shown in grayscale. If I print them on either of my two printers, they come out in grayscale. I do...
its possible that in your printing preferences you have black and white selected. you can also try reinstalling the drivers for your printers, first uninstall them and then install the drivers again preferably newest drivers from the makers website.
Oct 20, 2008 | Computers & Internet
Color printing negative
Hi, check your printers preference settings that they are set to normal printing and colour printing. Post back if this is no help. cheers lilacgerry xxx
Jan 27, 2008 | Office Equipment & Supplies
Prints black page
Click Start - All programs - HP - HP Director/Solution center
Click Settings - Print settings - Printer settings
Click on the Colors. In Color Management select "Managed by Application". Click Apply and OK. Close HP Director/Solution center.
Try printing.
Jan 09, 2008 | HP PSC 1315 All-In-One InkJet Printer
Color printing problem~only green, yellow, blue
The TekColor correction options provide simulations of different color devices. Automatic is the default correction for general image processing. Use the following table to determine what option you want to use.
TekColor
Description
Automatic Applies the best color correction to each graphic element: text, artwork, and photographs Office Color sRGB Display: Approximates the colors on a computer display.
sRGB Vivid: Produces brighter, more saturated colors than sRGB Display. Press Match SWOP Press: Matches specifications for Web Offset Publications.
Euroscale: Matches Fogra glossy paper specification.
Commercial: Approximates U.S. commercial press target.
SNAP Press: Matches specifications for Newsprint Advertising Production. None Applies no color correction. Use with other color management tools, such as International Color Consortium (ICC) profiles, ColorSync, or the PANTONE Color Chart for the printer. Black & White Converts all colors to shades of gray
From the workstation, select the color correction in a supported driver.
Microsoft Windows 98 SE / ME / 2000 / XP/ Server 2003 / NT 4.x Operating Systems (OS):
NOTE: Some of the color corrections are grouped under Office Color or Press Match.
  1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed.
  2. Click on the [Properties] button located on the top, right of the window. The Properties window will be displayed.
  3. Click on the [TekColor] tab.
  4. Select the required color correction.
Apple Macintosh OS 9.x:
  2. Click on [General], and then select [TekColor] from the pull-down menu.
  3. Select the required color correction.
Apple Macintosh OS X, (version 10.2 and higher):
  2. Click on [Copies and Pages], and then select [Image Quality] from the pull-down menu.
Dec 05, 2007 | Xerox Phaser 8500/DN Printer
Color printing
Solution: Manually adjust color from the driver (Windows)
Manual Color Adjustment Follow the steps below to make fine adjustments to the color hue for the printed output. These settings will only make minor color adjustments. If more drastic color adjustment is necessary, use an image editing application.
  1. On the Windows desktop, click 'Start', point to 'Settings', then click 'Printers' (Windows XP: On the Start menu, click 'Printers and Faxes', Windows Vista Click / Select Start from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'.).
  3. On the Main tab, select 'Manual' for 'Color Adjustment.'
  4. On the Manual Color Adjustment screen, adjust each color individually to achieve the desired effect.
    Note: This screen may vary depending on model.
Nov 16, 2007 | Canon Pixma iP6000D InkJet Photo Printer
HP Photosmart 2610 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
