Question about Polaroid i532 Digital Camera
Locked memory card
Well my little brothers were playing with my camera and some how by pressing buttons they locked my memory card and now i can only look at my pictures not take any or delet any!! i dont know how to unlock it either!!
  • prprincess83 Oct 15, 2008
    my memory card is locked it doesnt have a switch on the side?
Irt is not the problem with card reader side button. when i try to open memery card it is asking for password.
how to unlock the memery card in Motorola E6.
Posted on Mar 07, 2008
    Sergeant:
  • 201 Answers
Hey there ccmm1009, if you look on the side of the memory card, you should see a small brightly colored little tab. It should also have a small arrow with "lock" written next to it. Simply move it to the unlock position, and you are good to go. If this does not solve it, please respond with your exact model name and #, and I will attempt to help you further. Good Luck!
Posted on Feb 25, 2008
My camera says the my memory card is locked.?? i dont no how to unlock it My Ixus 70 says my card is locked, but the card is NOT locked (button on the side of the card is in unlock position). The came
Oops. The little latch on the side in the unlock position, should engage a switch in the camera, indicating the memory card is not writ protected. It is not an electrical switch doing something in the memory card. But is the switch in the camera is defect, you get the same result. If someone once tried to press in a memory card, the wrong way around, this could have been the cause of a damaged switch. Just check the memory card slot, of nothing is in the cardholder, blocking the little switch from working correct. Sure the switch is in the up position, like in the picture? 25288825-qj532vtjsqner5bmetfl14fj-5-0.png
Nov 18, 2014 | Sony Cyber-Shot DSC-W530 Digital Camera
Reset memory card
I think you mean you want to format the card. (wipe all the pictures and make it usable in the camera again)
First be sure your memory card is not locked. The little switch on the side of the card should not in the locked position, because then you can't change any thing. You can't write to or format the card. Only reading the card (viewing the pictures) is possible. You then could format the card in the computer, if you have a card reader. Format with FAT 32.
If you don't have a card reader you can use the menu in the camera.
Page 36 says. Press Menu push the arrow right till you see Format. Then press the up, down buttons, to access the setting and press ok.
After format, choose exit.
Dec 19, 2013 | Kodak EasyShare M530 Digital Camera
I pressed the "on" button
Move the slide switch on the side of the card.
Feb 01, 2011 | Cameras
How can I transfer photos from the camera memory to a SD memory card
Select the Play mode by pressing the play mode button (the right-pointing triangle). Press the MENU button. Use the left/right buttons to select [Copy to Card].
Jun 24, 2010 | Samsung Digimax S500 Digital Camera
I dont have my manual with me .Could you please tell me how I view the 'photo that I have just taken on my Samsung S630
■ If the memory card is inserted in the camera, all the camera functions apply only
to the memory card.
■ If the memory card is not inserted in the camera, all the camera functions apply
only to the internal memory.
■ If you have turned on the camera by pressing the POWER button, you can press
the PLAY MODE button once to switch to Play mode and press it again to switch
to Recording mode.
■ You can turn the power on with the play mode button. The camera is turned on in
play mode. Press the play mode button again and the camera will be turned off.
■ You can set up the PLAY mode function by using the camera buttons and LCD
monitor.
2. The last image stored on the memory is
displayed on the LCD monitor.
● Playing back a still image
1. Select the PLAY mode by pressing the
play mode button ( ).
100-0007
3. Select an image that you want to play back
by pressing the LEFT / RIGHT button.
※ Press and hold the Left or Right button to
fast forward the images played.
AND here is the manual in free downloadable form
http://www.fixyourownprinter.com/forums/inkjet/24191
Oct 09, 2009 | Samsung Digimax S630 Digital Camera
Cannot access pics
Once you took pictures without a memory card, all pictures taken will automatically be saved on the INTERNAL MEMORY of the camera.
When taking pictures with a memory card, all pictures are just saved on the memory card itself.
If you are seeing 100-757 on the LCD screen. It means that there are already 757 pictures taken from the first time you've used the camera.
It is possible that some of the pictures are in the internal memory and some are in the memory card.
STEPS to DOUBLE CHECK:
1) Remove memory card out of the camera
- Turn on camera
- View pictures on the internal memory
by just pressing on the PLAY mode button
(lowest of the 3 little buttons)
- Pictures seen are just the ones saved on the internal memory
2) Return memory card back in the camera
- Turn on camera
by just pressing on the PLAY mode button (
- Pictures seen are just the ones saved on the memory card itself
*** If you want to transfer pictures on the internal memory of the camera to your MEMORY CARD, you just have to follow the steps below:
- Make sure there is a memory card inside the camera
- Turn on camera
- Press on PLAY mode button to view pictures
- Press MENU/OK button
- Keep scrolling to the right until you see COPY TO CARD
- Select YES using the arrow keys
- Press MENU/OK to confirm
* When you've done these steps, all pictures from the INTERNAL MEMORY of the camera will be copied to your MEMORY CARD but it depends on the space left on your memory card
** If still, you could not view the pictures, it's possible that the pictures are really gone when you have transferred the previous pictures to your computer.
** Once you have transferred pictures to your PC, and you have deleted those on your camera, the FILE NAME of the pictures will not start from 100-001 again unless you have reset the file name on the settings of your camera.
In example, i already have 256 pictures on my camera so the filename reads 100-256 for the last picture taken. And then i decided to transfer those 256 pictures to my PC and i deleted those immediately after being transferred. So, as i took another picture, FILENAME will start with 100-257 if i have not reset
the FILE NAME settings to 100-001.
Hope i've helped you enough.
Jan 02, 2008 | Samsung Digimax S630 Digital Camera
Locked Memory card
If it's an SD card, there is a little switch on the side of the memory card. Hope this helps!
Nov 08, 2007 | Samsung Digimax D53 Digital Camera
Locked Card
Take the memory card out of the camera. Look at it carefully and you will seea small tab. Move the tab from the locked position to the unlocked position. Re-install the memory card into the camera and then you're done.
EEee
Nov 03, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Cameras Logo
95 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
