Question about Dirt Devil M084600 Dynamite Bagless Upright Vacuum
I have only had my dirt devil for 2 months. I was sweeping my rugs. It was working perfectly. Then I turned the sweeper off for 2 minutes. Went back to finish sweeping and the sweeper wouldn't work. I emptied the dirt container and cleaned the filter. It still won't work.
  • 1 more comment
  • Anonymous Mar 13, 2014
    How do I clean the clear dirt canister on my Shark Rocket sweeper?
  • Anonymous Mar 21, 2014
    stopped while sweeping
  • Anonymous Mar 24, 2014
    Dirt Devil vacuum 6 months old and had no sucking power for cleaning. Nothing was plugged, took filter out to test, worked fine. Bought new filter, works like new! How do you clean old filter, only six minths old! I'll use as spare. Already tried running clean water through it from faucet.
    President:
  • 1,673 Answers
If it is only 2 months old, then it is under warranty, take it in for warranty repair. There may be a circuit breaker on it, usually on the back at the bottom, it there is, push it to see if it has tripped.
Posted on Feb 28, 2008
How do I keep the rear wheels from coming off my dynamite upright dirt devil
Plastic to plastic wears fast. I have repaired this problem by inserting small wooden dowels between the splits in the axles.( I have one of these machines in my home) Lubricate the axles with a non-petroleum grease afterward. I use Superlube available in most auto parts stores.
Nov 21, 2014 | Dirt Devil M084600 Dynamite Bagless...
My sd40025 dirt devil ..it is not a upright. it is the follow along, bagless vacuum. has wonderful pick-up but the brush stopped spinning when i was vacumming my rug..i love this vacumm but it is only the...
That's because you got something caught in the brush and it tore the belt (likely) or slipped off the drive portion of the motor (unlikely).
If you look at the bottom where the brush is, there are a bunch of screws to remove the bottom cover usually and can access the belt and motor to run the brush. \
belts are usually 5 to 10.00 get a pack of 2 if possible and don't do heavy rugs or get material caught in the brush lest it will happen again.. typically you can find vacuums in the trash and remove their belts, usually is only 2 or 3 types of belts so get one for free perhaps from trash.
Nov 23, 2017 | Dirt Devil SD40020 Bagged Canister Vacuum
I have a dirt devil upright vision and when I am sweeping it will shut off like it had overheated or something. I will unplug it and let it sit for a few minutes and it will start back up and then after a...
Hi Cassidy. You are probably right about the motor overheating. The usual cause for overheating is a clog some where on the bottom of the machine. Check for anything that could be blocking the dirt fro going into the bag. Hope this helps Chris
Feb 20, 2011 | Dirt Devil Vacuums
My vacuum is not sucking up that good and none of the dirt is revolving in the clear part of the vacuum like it normally does
The normal air flow has decreased considerably. Look for a clog inside the sweeper head and for a plugged HEPA filter (remove it to test) on the outlet. Hope this helps!
Nov 19, 2010 | Dirt Devil M084600 Dynamite Bagless...
Charge doesn't last 2 minutes and what it starts with is weak. the vacuum is 7 years old.
batteries do have a life. its probably reached its end, sad to say. if the battery can be removed, i would attempt to find a replacement.
Apr 26, 2010 | Dirt Devil Royal Cordless Rechargeable...
Dirt Devil M084600 Dynamite Bagless Upright Vacuum Logo
298 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
