Question about SanDisk Sansa m230 MP3 Player
Player wont turn back on
I had a low battery signal and after I changed the battery I attempted to power it back on and it didnt come back on. HELP!!!
    Problem Solver:
  • 15 Answers
First make sure the hold button isn't in the on position.
Then try pressing the menu button and the play button together at the same time. If that doesn't work try pressing the menu button and other buttons (one at a time). Should nothing work it might be an internal issue. When this happened to mine i just left it for a few days without doing anything and it started playing on its own.
Posted on Feb 29, 2008
Why won't it start?
It sounds like your battery doesn't have enough of power to start your vehicle up. It will click like that when the battery power is extremely low. I would suggest taking the battery to be tested first before buying a new battery. Many times when you try jumping it off of another vehicle and the battery is extremely low, it wont put enough of power out from the other vehicle to start it up with. You can also try letting the car stay on to charge the other battery up for around an hour and see if it may turn the car on then. If that doesn't help. then your battery may have bad cells in it and may need replaced. Hope that helps ya.
Sep 02, 2015 | Cars & Trucks
Hi! i have a 2003 2.0L jetta. i was driving it everything was fine, i stopped the engine went for groceries when i wanted to start it the epc light when on and the car didnt start. we push it to start it...
I takes it your car is a manual shift and if so then you need to
Replace the starter switch that is on the clutch the winds the signal to the computer to start engine.
Oct 19, 2013 | Bosch 2003 Volkswagen Jetta GL 2.0L...
My huawei mercury phone wont power on or charge
y wont my mercury turn on it wont even showet chargeing how can i fix the problem.
May 20, 2012 | Huawei M886 Mercury CDMA Cell Phone
Mp3 wont turn on `
Hold the >! down and a light sould come on
Aug 09, 2009 | RCA Lyra RD1072 MP3 Player
Low battery light in 03 ford f150
charge it up .crank engine while its idling get a volt meter hook it to battery .volts should be 13.5 to 14.5 if its 12 to 10 or lower.alternator is not charging.if alternator is charging . turn engine off battery should stay 12.5 volts if it drops after engine is off to 11.0 or 10 volts battery weak replace it.
May 04, 2009 | 2003 Ford Expedition
Gogear
Battery is too low for player to charge. There is a firmware fix for this at www.p4c.philips.com
Fix cannot be applied until player is working again.
If you know someone who has the same player, put their battery in your unit to power up and apply firmware update to fix problem. Then swap batteries back again
Another way to get the player working is to remove the side panel to disconnect battery. Plug in the mains charger and reconnect the battery. You may need to do this several times before the player springs into life.
If this doesn't work try disconnecting the charger and battery alternately and wait 5 secs between attempts.
Feb 21, 2008 | Philips GoGear HDD075/17 MP3 Player
Gogear became dead suddenly
Dec 30, 2007 | Philips HDD070 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
42 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
