Xerox Phaser 7750 faulty door sensor
Xerox Phaser 7750 - Has faulty door sensor - $ at shop to replace?
    Genius:
  • 1,019 Answers
it,s all $$ wherever you go ?
If you can find which wires contact ( Make/Break ) possibly with a multimeter. Remove the sensor, join the wires. tuck it into the inside of the printer.
tape it up to avoid any shorts.
Mike @ compurepair.
Posted on Feb 25, 2008
Phaser 7750 Not Printing, No Error codes, Fuser Wont Warm Up, Wont Detect Open Trays or Doors
It sounds like one of the cover or tray sensors is not working correctly. Check the actuator on the fuser cover, sometimes these break off so the printer thinks the cover is still open. If that seems ok and you have a lower tray deck unplug it to eliminate them as the cause.
Apr 07, 2017 | Xerox Phaser 7750 Laser Printer
Tip
XEROX PHASER 7750 7760 FAN ERROR.
Hey guys this is a Xerox Phaser 7750 and 7760 fan error video tutorial.
In this video you will learn how to fix the error code 48 on the Xerox phaser 7750.
Also you will learn how to fix the error codes 010-391,010-392,010-398 that are related to the Xerox Phaser 7760.
This video shows how to remove covers.
All the wires that you need to disconnect from the machine to fix these errors.
There is also another video part two that shows you how to reinstall everything back
in it’s place. Step by step tutorial hope you enjoy.
http://www.youtube.com/watch?v=yMud-Md2xpc
on Dec 30, 2009 | Office Equipment & Supplies
I have xerox phaser 7750 by mistake i bought 7760 yellow toner shall install it to 7750
Not yet, check with the supplier and ask if it is compatible with the 7750, if not then exchange the 7760 for a 7750 yellow toner cartridge. Once you open the cartridge the supplier will not exchange.
Apr 22, 2013 | Xerox Phaser 7750DN Laser Printer
How do you reset toner counter on phaser 7750? Thanks
On the back of the 7750 toner there is a metal piece you can push in near the end that goes in to the machine first, this will tell the printer that the toner you put in has not been installed until now. I would not suggest doing this unless the toner is full and is using geniune xerox 7750 toner.. If you refill it with generic or non-7750 toner it can damage the machine and will void any warrenty you may have left on the machine.
If you switch machines with the 7750 toner the machine will not know how much toner is remaining in that toner. Xerox changed this method on the 7760 to use a toner chip to fix this.
Hope this helps, thanks
Apr 01, 2011 | Xerox Phaser 7750DN Laser Printer
Error code 14 ; says cyan sensor malfunction. Where is sensor and how might I clean it?
E-mail me at rak458@aol.com.
I can't post all of it on here.
Just put Phaser 7750 in the subject line.
Jan 15, 2010 | Xerox Phaser 7750DN Laser Printer
Xerox Phaser 7750 error code 14 & 15.
try to hold down the on/reset button a few seconds when you power it up ...on most printers this resets them ..about 10 sec it is enough ...
Nov 26, 2009 | Office Equipment & Supplies
Xerox Phaser 7750 Imaging Unit Percentage Question?
turn macine off wait 5 min repower and run recheck
Apr 06, 2009 | Xerox Phaser 7750GX Laser Printer
Xerox Phaser 7750 parts
Google " the parts drop" . Call Britt and see what he has. He should have one of those.
I don't work there but you will never find anyone better to deal with.
Ahh here is his phone number 201-387-7776. Tell them Rick said Hi.....
Jan 06, 2009 | Xerox Phaser 7750DN Laser Printer
Xerox Phaser 7750 code 35
Somehow you jarred the fuser. Turn the machine off and reseat the fuser. Open the left side door, there will be 2 thumb screws.
Remove and reseat the fuser, if that doesnt work you have to replace the fuser.
Apr 05, 2008 | Xerox Phaser 7750DN Laser Printer
Phaser 7700 Accumulator Belt Replaced, upon startup there is an error
POSSIBILITIES
Problem:
1st BTR Contact Failure or 1st BTR Retract Failure Message is displayed after replacing the Accumulator Belt Cause:
A Phaser 7700 Accumulator Belt was installed in a Phaser 7750. The Phaser 7700 Accumulator Belt does not have retractable 1st Bias Transfer Rollers; so these errors will be reported if one is installed in a Phaser 7750 printer. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Remove the Phaser 7700 Accumulator Belt and install a Phaser 7750 Accumulator Belt. TRY FIRST (Solutions without parts):
1. Check that all shipping restraits have been removed.
TROUBLESHOOTING TIPS AND HINTS:
1. Test the 1st BTR motor in diagnostics to verify proper operation. 2. Test the 1st BTR sensor in diagnostics, then run the 1st BTR motor test and recheck the 1st BTR sensor. Sensor state should alternate between L and H. The sensor is part of the accumulator belt.
PARTS:Parts are listed in the order of highest probability for repair.
NUMBER QTY DESCRIPTION
116177400 1 *KIT IBT - UNIT
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers, exit rollers and guides; replace if
necessary.
2. Clean feed rollers and exit rollers only when dust or
debris is visible.
3. Remove and clean all paper trays.
4. Clean the Laser Scanner Unit window.
5. Inspect the image density sensors; clean if necessary.
6. Inspect the accumulator belt home sensor; clean if
necessary.
7. Inspect the fuser assembly; clean if necessary.
8. Print the Error Log, diagnose and repair any problems as
indicated.
9. Print the Usage Profile, diagnose and repair any
problems as indicated.
10. Check version of all installed firmware; as
appropriate, install the latest version of firmware.
11. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
Problem:
Jan 25, 2008 | Tektronix Phaser 860DP Thermal Printer
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
