All of a sudden the sound on our LCD tv has gone. We've checked all the cables are in correctly and even though the picture is perfect we have no sound. SAMSUNG SYNCMASTER 741MP
  • andycanman Feb 25, 2008
    monitor resets itself after being turned off at the mains for over 30 mins and sound is ok after that
  • Marky4 Mar 30, 2008
    Just bought a Viewsonic N3240wb widescreen TV. Has been working fine for the last 2 days however today the sound completely went dead. I cannot change the sound from mono to stereo from the remote either! All cables are working fine. I tried another antenna for the hell of it and could not obtain sound either. Picture is 100%.
    HeLP!
    Genius:
  • 1,554 Answers
Connect the cable directly (bypassing the cablebox)and
set menu to cable channels ,
tune to channel 3 or such and do you have sound now.
if not the amp is out , you might just consider using external speakers as they will sound better anyway.
Posted on Feb 25, 2008
  • Karl Whisenand
    Karl Whisenand Feb 25, 2008
    It might be the output sound chip is going bad and that cooling it down fixes it temporally .
Tv has picture, no sound, just popping/clicking
Probably the internal power supply has failed. It can happen even though your TV was stored and covered.
Dec 06, 2013 | Haier HL32R 32 in. LCD TV
32 inch LCD TV samsung series 5
If there is sound, no doubt, its signal input is OK. The problem must be to your Tv itself. If the LVDS cable, the cable that connects between the T'Con board and LCD panel have a loose contact, this type of faultcan occur. Re-seat this cable once, and check. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Hundred Thousand viewers cannot be wrong.
May 05, 2013 | Televison & Video
Plasma screen suddenly went out
its a lcd ? replace the lcd lamps or the inverter
May 04, 2012 | Panasonic Televison & Video
My Sony Trinatron has suddenly displayed a dark screen on all channels. You can see the picture but looks like it's nightime. I've tried ajusting the brightness but no result.
does the TV bring out sound even as the screen display is dark?
Problem should be from the TV lamp/bulb. When a TV bulb/lamp is dying, it makes the pictire on the screen become dark and very hard to see.
Have the lamp replaced and hopefully, your screen should be perfect as before.
Let me know if you need directions in replacing the lamp, even though it is very simple replace.
Yours sincerely.
Elect_Comp.
May 14, 2011 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Picture blank
Maybe it needs to be replaced with something more up-to-date.
Jun 26, 2017 | Sharp LC32D62U 32 in. LCD HDTV
My sound as gone on my toshiba regza tv
Does the sound icon move up like it should on the screen when you increase the volume?
Dec 09, 2017 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Samsung LCD -no picture/sound from any input source-Cable,DVD,PS3
Use the menu button in the front screen of your tv.Maybe your remote control need a battery.
Jul 24, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
LCD TV no pictures but sounds
cheak cables try other cables old style yellow to see the pic then go in box tell it hdmi output or coumpunt whatever uuse try differnt ports
Jun 08, 2008 | Televison & Video
Samsung Syncmaster 741MP
Similar problem was solved by transporting the wrong TV some tens of kilemeters by a car :-) Maybe there was some junction error inside, or a longer power-off state was needed to fix the problem?!
Sep 07, 2007 | Philips 20MF605T Television
No sound dell 32in tv
These are the answers straight from the dell manual. Ensure that the audio cables are firmly connected to both the audio input connectors on your LCD TV and audio output connectors on your PC or Video player. If on certain TV channels you receive a picture but no sound, this means that you do not have the correct TV system. Modify the SYSTEM setting. Check if TV volume is turn off of muted Connect the audio cable securely Audio cable is connected incorrectly Verify that the audio source is selected correctly in the OSD
Jul 31, 2007 | Dell W1700 17 in. HD-Ready LCD Television
Televison & Video Logo
247 people viewed this question
Top Televison & Video Experts
