Brother intellifax 770
Had to change ink cartridge can't get new one in and working Help!
Is there any step by step instructions or diagrams you could send me
  • Pinkston6 Apr 16, 2008
    I haven't used this printer in a while. Just got it out. Changed both the black and all color cartridges and tried to print. Prints fine in color but the black looks grey and blurry. Can't find my book. What do I do?
    Scholar:
  • 78 Answers
Winding technique:
To wind a new ribbon, take the cartridge housing apart and remove the old ribbon and two cardboard cores. The new ribbon is fitted with the larger roll (the ink ribbon supply spool) at the rear side of the cartridge (as the housing is viewed when it is normally installed into the machine). The ribbon winds over the topside of the rear spool (the supply side) and feeds into the underside of the front spool (the take-up side). Make sure the ribbon is wound neatly, evenly and is tight. If the ink film has become detached or is too loose on the front spool it will not wind on and cause a machine error. If required, use a small amount of sticky tape to secure the ink film to the front cardboard spool and then neatly wind it on to the take-up spool a minimum of five turns, making sure the film does not overhang at the edges. Now reassemble the housing and refit into the machine.
If it’s still not fixed:
If problems persist after fitting a new ribbon, try replacing the entire ink ribbon unit (cartridge housing + a new ink ribbon) using a new, genuine Brother unit before requesting a service; this will be less expensive as the actual housing may have been damaged and is causing the problem and this unit is readily available as a consumable item through sales outlets. If the machine still has problems, book your machine in to be repaired with an authorised Brother Service Centre.
Posted on Feb 25, 2008
Which ink cartrage fits Brother Fax 770?
PC301 is the complete replacement cartridge. Lift out the old, drop in the new.
PC302 is a box of two refill rolls to fit into the PC301. Lift out the old, lay it upside down on the table, flip a few small latches to open both sides of the cartridge. Look carefully at how the old rolls are placed in there. Lift them out and put in the new rolls the same way, except that, of course, the full roll will be on the opposite side. Snap it closed, drop it into the machine and close it up.
Save the second roll for later.
May 21, 2012 | Brother IntelliFAX 770 Plain Paper Thermal...
I have a brother intellifax 1840c (which is great, by the way). I need to change the ink cartridge & have no idea how to get into it. Is there a latch or button to help open it? Please help.
1 Close the document support and the document tray.
2 Lift the top cover to the open position until it locks securely into
place. If one or more ink cartridges are empty, for example Black, the
LCD shows Ink Empty Black and Open Cover.
3 Pull the ink cartridge hook toward you and remove the ink
cartridge for the color shown on the LCD.
You can find the procedure on changing the ink cartridges in the user manual, page 12-25.
User Manual can be downloaded:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000335/MFC-3240C_UsaEngUsr_C.pdf
May 25, 2011 | Brother IntelliFAX 1840C Plain Paper...
We are trying to replace the black ink cartridge on our brother intellifax 2480C printer but even after loading the new cartridge the printer is indicating that there is no cartridge and the black ink...
Did you have the no cartridge prompt on before you changed the cartridge? If no, then did you remove all packing material. Is this the first time you have changed the cartridge?
Let me know
Jan 09, 2011 | Brother IntelliFax-2480C Fax
Brother 1840c -problems after changing cartridges
If you are using new cartridges, the problem is in the sensors. The ink sensors get dirty and malfunction. Remove the ink cartridges and thoroughly clean all the surfaces, Allow to completely dry and replace the cartridges. This should cure your problem.
p.s. I usually use alcohol on a Q-Tip to clean
Jul 02, 2009 | Brother IntelliFAX 1840C Plain Paper...
Black Smudge of ink along top edge paper Brother Intelifax 2800
try cleaning the grid on the drum unit otherwise there could be some thing on the fuser preasure roller.
Jan 16, 2009 | Brother IntelliFAX 2800 Laser Fax
Ink cartridge was changed, but machine won't work
There are lots of NEW dried up ink cartridges out there.
Nov 10, 2008 | Brother IntelliFAX 1840C Plain Paper...
181 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
