Question about EliteGroup P4VMM2 Motherboard
Pc won't display but it switch on
Ecs p4vmm2, via chipset, 686 amibios, my problem is when u turn on it runs but wont display and u will only hear the error beeps( 8short successive beeps).. VIDEOCARD is GOOD, i have tried to used it in other computer and it is working properly...
I already done clear cmos then transfer the monitors cable into the vga port but stil the error beep is there and the monitor will display "frequenzy out of range....try other resolution""
begging ANSWERs....pls
is any one out there with a good and friendly hart can help me answer my QUESTIONS???
1. what is the cause of the problem?
2. what is my solution for this problem?
thanking in advance for the help...Godbless
  • 2 more comments
  • jay-r trinidad
    jay-r trinidad Feb 25, 2008
    yeah it is a AGP card but how can i disable the onboard video chip in the bios when my PC is not displaying either??...i already done clerCMOS but when i transfer the monitor cable to the onboard video it will just display in black and in center it says frequenzy is out of range??.pls help me again fren...i needed it badly...
  • jay-r trinidad
    jay-r trinidad Feb 27, 2008
    is that a pci chip frend??? can u please elaborate more on what u mean maam?? i mean, i am bit confused of ur answers u will always tell me to go to the bios then change some settings there........BUT HOW???? my computer wont even display the post message and it only gives the error beeps....
  • VladimirCo Sep 29, 2008
    I have the same problem. I tried PCI, AGP cards without result. 8 beeps is there and the monitor will display "frequenzy out of range".
  • runlegs Nov 16, 2008
    yes,ihave the same problem when Iturn it on a few seconds theres nothing to display only a continous beeping sounds,cannot find the set up display at all.Thank you very much in advance,for helpin us.may God Bless you more wisdom and knowledge.
  • 97 Answers
8short Display memory read/write error The system video adapter is missing or defective
1 if it is an AGP card could be the slot for it is defective
2 Disable the onboard video chip in the bios try it again
3 If you have an old PCI videocard try that
4 if ou have 2 slots of ram chips try without one in then take it out and try the other
Posted on Feb 25, 2008
  • MR R
    MR R Feb 26, 2008
    You have an Integrated ProSavage8 2D/3D graphic engine, and in the bios on one of the settings more than lilely Integrated Peripherals you will be able to disable this on-board graphics chip
  • MR R
    MR R Feb 28, 2008
    Bin the board it has failed on the graphics chips set if you have no dispay even at POST then you will not be able to fix it
Soyo Tech aid response 2A: "different BUSes" on 1999 AMI Bios on ECS P4800 Pro-M VI.0A pc motherboard.Won't boot but stops. How to fix?
and compare that is your BIOS updated ? If not, I suggest first update your BIOS to the latest version and see if error is removed ? Try Load Optimal Settings of BIOS. If fail, then try resetting the BIOS. If you have install anything new, try to boot by removing the new device. I suggest from the above URL, you can download the manual of the mother board. I hope trying these steps will remove your problem.
Feb 11, 2016 | Intel PENTIUM-4 FSB800 Mother Board with...
I need motherboard driver and setup spec for VER:5. The board does not boot to BIOS or provide video via AGP or PCI. BIOS chip label stamped BK40 3457 (686 AMIBIOS). I DO NOT KNOW HOW TO CONFIGURE THIS...
Simple test: disconnect all disks, remove the BIOS battery for 10 minutes, put it back (this resets everything to default factory settings) then try to boot in the BIOS - if it fails then the motherboard is defective - no BIOS update can fix that.
The board is dead, time for a new pc.
May 02, 2011 | Computers & Internet
Can you please help me find drivers for my motherboard p4vm2...
You can find your drivers here:
You also need to know what rev. number it has to get the right driver.
It should be typed in on the mainboard.
Keyword:p4m266a Total:3 1. P4VMM2(V3.1)
BIOS - 1. Support VIA P4M266A chipset...
2. P4VMM2(V7.3)
BIOS - check sum:9B87 h 1.Support P4M266a CE...
3. P4VMM2(V7.1)
Good luck.
Feb 25, 2011 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
Hi can any one help me please
Leave it alone. Reflashing a bios is serious business and never, never guaranteed. Very often the process does not work or goes bad and then you wind up with a piece of junk due to a corrupted bios.
Mar 03, 2017 | Abit AV8 Motherboard
Sound card drivers on bord need AMIBIOS Motherboard Manufacturer Identification Version 1.4 (01/12/2004) Copyright 2003 American Megatrends, Inc. This file has recorded information useful in identifying...
look et...According to the numbers you provided you have Elitegroup Computer motherboard. So for any possible BIOS upgrade, drivers or any other technical support you will need to visit => or call them at 510-226-7333. Suc6
Jan 07, 2009 | Computers & Internet
I cant find which typ of mainboard do I have to preform an update
There is a little program called CPUz.
Download it here:
Extract the exe and ini files and run the exe.
When the program comes up, click the Mainboard tab and your manufacturer and model are right there.
Dec 17, 2008 | Computers & Internet
I want my display drver
thats the driver for the intergraded video on a ecs P4VMM2 motherboard
Driver Name : S3 ProSavage Display Driver P4M266_KM266-P
Nov 27, 2008 | Computers & Internet
P4mmv2 motherboard
If its a P4mmv2 motherboard with AMIBIOS 686 and a VIA VT8233 chipset then the jumper setting are printed on the motherboard, but they have labeled the power switch wrong, I believe th reset switch is the power switch. This is the type of mother board that I have and I have learned this from experience. Also I read in somewhere on the internet about the problems with these types of motherboards.
Jun 04, 2007 | EliteGroup P4VMM2 Motherboard
EliteGroup P4VMM2 Motherboard Logo
536 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
