Question about Acer Aspire 5050-3242 Notebook
Low volume The volume is very low even in max vol. I tried adjusting both from the volume Icon and ythe keyboard. I have the same problem and it's driving me crazy! The loudest it ever gets is about 5-10% of the max. I have checked all of the solutions listed here and nothing has helped. I've had this problem ever since I bought my laptop. Any help is appreciated!
  • 28 Answers
There could be one of three problems here.
1) You need new sound drivers. You can get them from your laptop's distributor's website.
2) Your speaker or head phones that you are using are either blown or do not support the amount of watts the sound chip produces.
3) The sound chip on your laptop is bad and you are going to either have to take it to a computer repair shop or send it out to a repair service to replace it.
Posted on Feb 25, 2008
  • 97 Answers
Vista updates cause problems like this you may have to download the latest Vista driver for your sound card from the Acer site
Also
1. Click Start, click Run, type regedit, and then click OK. 2. Locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\Software\Microsoft\Scrunch\CodecPack\MSDVDNote If you cannot locate the registry subkey, go to step 3 to create the registry subkey. If you can locate the registry subkey, go to step 6. 3. Right-click the Microsoft registry subkey, point to New, click Key, type Scrunch, and then press ENTER. 4. Right-click the Scrunch registry subkey, point to New, click Key, type CodecPack, and then press ENTER. 5. Right-click the CodecPack registry subkey, point to New, click Key, type MSDVD, and then press ENTER. 6. On the Edit menu, point to New, and then click DWORD Value. 7. In the details pane, type the following new value, dolby_rf_on, and then press ENTER. 8. Right-click dolby_rf_on, and then click Modify. 9. In the Edit DWORD Value dialog box, under Base, click Decimal. 10. In the Value data box, type the value 1, and then click OK.
Max volume to low
Check the settings of the monitor for audio volume. Also check the individual volume control setting for the applications and system sounds. Or call ViewSonic technical support for assistance.
Jun 15, 2014 | ViewSonic Computers & Internet
Volume keyboard
Go into function and look for the volume setting for your main voice - could be R1. This will give a numeric value of 127 or less. It sounds like you need to increase it, try 100 as that is usually sufficient.
Dec 27, 2013 | Yamaha DGX230 - Digital Piano
The volume on one of my Gigaset 8825 mobile handsets is very low. I have adjusted the handset volume to the max setting but still can barely hear the ringer. Is there another way to adjust the handset...
Hi, you can try to change the profile settings of the phone, because sometimes even if the volume is full but if the profile settings is on low, the sound will still be low.
Thank you for using Fixya.
Jul 15, 2011 | Computers & Internet
Why does the audio out is so low???
check whether the volume is low...
double click on the speaker icon on the system tray and then check if all the options has the volume set to max..
Mar 14, 2011 | Toshiba Computers & Internet
Sound output is low nowadays even at full volume whereas before it was ok. I didn't change anything with my computer nor did I change my speakers.
Two possible causes.1) Vol Settings changed in windows2) Bad hardware
1) Check your system's sound settings:
For Xp
  • Goto Control Panel
  • Double Click Sound and Audio devices / Sound, Speech, and Audio Devices
  • In device Volume Click Advance
  • Master Volume Control Window will open
  • Increase all the volumes to max, also make sure that Mute us UNCHECKED.
OR
  • From the bottom right corner of your screen in system tray, double click a small speaker icon and open Master Volume Control.
For Vista and Windows 7
  • From system tray (its at bottom right corner of your screen) double click on small speaker icon, it will open Volume mixer
  • Increase the volume to max.
2) If this does not work, then test your speakers by connecting it to some other system and vice versa.
If you get desired sound volume when you connect some other speakers to your system, then you have to change your speakers. And if your speakers are working fine on other system then you may have to purchase a new sound card.
May 17, 2010 | Computers & Internet
Can the audible volume be turned up louder on a
I think the only solution for you my friend will be too invest in a headset of some kind which should plug into your unit which will help you to hear better.
May 03, 2010 | Garmin nuvi 650 GPS Receiver
Sound is low
try to see if the wave volume is on and maximum on the volume panel ( double click on vol icon on tray system (right low) ) ...also see if your speakers are plugged into the proper place ...and are not in the auxiliary out or something like this ...they should be plugged into the green middle out ...if they are simple stereo 3,2 jack ...so ..if the problem its still on ..its probably the sound card...(actually the pre-amplifier on it ..)
Aug 03, 2009 | Dell Dimension 3000 PC Desktop
Low Sound on a dell latitude D600 (PLEASE HELP)
check the sound devices selected and the volume level is proper.
Jul 09, 2009 | Dell Latitude D600 Notebook PC
Volume settings at max but sound very low
If you're playing a prepacked CD or DVD and the sound is below normal then there's something wrong with the computer. I would let the manufacturer take a look at it. If these are CD's or DVD's you made, then I'd try them in another CPU first.
Apr 04, 2009 | Acer Aspire 5100 Notebook
Low volume
> Open Control Panel
> Sound Properties
> Speaker Properties
> Enhancements
Loudness Equalization : on
Equalizer: Choose one (Jazz seems to be loudest setting but sounds of hallway effect so I use powerful for clarity.)
This has more than doubled the level of volume on my acer 5570.
- verc
Jul 16, 2006 | HP Compaq nc6320 Notebook
Acer Aspire 5050-3242 Notebook Logo
303 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
