its mean absorber full..(i think) Check this steps :
1: Unplug power and USB 2: Open door and hold power button. 3: Connect power. 4: Close door, then release power button 5: Connect USB and an press power to use.
Press the power button to turn off the printer.
Hold the "Stop/Reset" button
while pushing the power button. While still holding down the power
button, release the "Stop/Reset" button and then push it twice in a row.
Wait approximately 20 to 30 seconds until the LED shows 0.
Push the "Stop/Reset" button four times in a row.
5
Push the power button twice.
6
Turn off the printer by pushing
the power button one more time. The printer is now reset. Next comes
resetting the counter on the cartridge.
7
Unplug the power and the USB cables from the printer.
8
Open the cartridge door and hold down the power button.
9
Reconnect the power cables while still holding down the power button.
10
Close the cartridge door and release the power button. The ink cartridge is now reset.
1. Turn off the printer ( "Power" button). 2. Hold the button "Resume" (red circle in the triangle) and push "Power" button. 3. When printer become ready hold the button "Power" and release button "Resume". 4. Push button "Resume" 2 times and then hold "Resume" and release "Power" button. 5. When I hold button "Resume" I push and hold "Power" button and release "Resume". 6. When I hold "Power" button, push button "Resume" 2 times and release both buttons. 7. When printer become ready on the display write "CANON Idle". 8. Push button "Resume" 4 times. 9. Then push "Power" button 3 times to turn off printer. All done. The printer is ready to print.
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button 4 times, the green (power) led should be lit to reset ink absorbers. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
5)At the end of the service mode, press the Power button
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.) 2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.) 3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.) 4) When the Power LED lights in green, press the Resume/Cancel button 4 of times. 5) Then press the Power button, then press it one more for turning off printer.Restart the printer and it will printing again.
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
Waste Ink Tank Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
6: Press Power to set data
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
1. power off Printer
2. Push and hold resume button and push power button
3. Hold Power button and release Resume button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and stop.
6. When green light on, push resume button 4 x
7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
