Question about Epson Stylus CX4200 All-In-One InkJet Printer
Prints grey not black
Ever since I connected my Epson Stylus cx4200 printer to my i book G5, my printer prints everything with a grey tinge. Blacks are not black but light gray and colors come out, but again they're gray-ish. Am I using the wrong driver? My ink cartridges are new, I replaced them when I connected the printer to my ibook. Any help would be great!!
I solved this problem but probably not what the printer manufacturer would recommend! The reason you are just getting grey is that the black ink cartridge is either empty or dried out from non use and only the color cartridge is working. I had the same problem after being away for 5 months. I put the printer cartridge in a bowl of warm water to disolve the dried out ink on the print pad. I dried off the cartridge with a soft cloth and then it worked perfectly.
Posted on Jul 05, 2010
If the printing preference is on "draft", it will print everything on light color or grey. check the printing preference, choose text or image instead of draft.
Posted on Mar 05, 2008
I have windows vista. epson stylus cx4200 will print but does not scan. installed windows 7 64 bit drivers but not successful. need help. thanks
Download & install the "Epson Stylus CX4200 All-in-One Printer" @ Drivers and Utilities Combo Package
Windows 7 64-bit compatible, Windows Vista 64-bit
epson13071.exe - 20.9MB
- posted on 07/07/09
This file contains everything you need to use your Epson Stylus CX4200 with Windows Vista 64-bit.
This package consists of the following items:
•Printer Driver v6.5
•Scanner Driver v3.04
•Epson Status Monitor 3
•Epson EasyPrint v3.10
Uninstall your previously installed AIO drivers before installing the downloaded installer.
Hope it helps.
Jun 02, 2011 | Epson Stylus CX4200 All-In-One InkJet...
My Epson 1400 is printing blacks green. After gray 40 % all my gray and black is coming out green. what can I do to solve that, and please don't tell me to chane my printer I just boughted it 4 months ago.
The printer is using your color cartridge to print black and greys.
The black cartridge must be empty and will need to be replaced.
The color cartridge has depleted one of the primary colors required
to print black.
Both cartridges will need to be replaced
Feb 14, 2011 | Epson Stylus 1400 InkJet Photo Printer
My Epson Stylus CX4200 will not print because my Cyan ink is out. I tried printing in black and white only but still won't print because of the one empty cartridge. Is there any way I can still print...
I have a CX4800 and after clicking Print, I click Properties, then check Black ink only (is this how you are printing black and white - or is your document black and white)
If you haven't tried this option - it is worth a shot.
Mar 01, 2010 | Epson Stylus CX4200 All-In-One InkJet...
My Epson R1800 prints grey and not black for text. It also prints pictures faded and not bright. I have adjusted the settings in printer set up to highest quality. I have changed the ink cartridges.
This isn't a solution, merely an echoing of the problem. I'm using it with a Mac and have had the problem since using it with a Mac as opposed to a PC. Did you or anyone ever get a definitive answer on this? It's driving me crazy!
Jan 23, 2010 | Epson Stylus CX4200 All-In-One InkJet...
Can i print without color catridges
you do need both cartridges in and with ink or the printer will not print to prevent damage to the print heads from running dry. The printer normally uses a small amount of coloured ink to "tone" blacks but if you leave it set to Black only it won't do this and in the future you should only have to replace the black cartridge.
Chris
May 21, 2009 | Canon PIXMA iP1600 Printer
Epson pro 4800 r prints grey not blank and says to set cartridge
I am having the same problem If anyone has an answer or whether judy you have found an answer.
If I do a greyscale strip to print my black is coming out as a dark grey. the bead off of the greyscale strip would appear that the pbk photo black is not actually printing.
This has been a problem for a few months but as I haven't been doing much printing didn't notice it just thought something was odd. Now I look at previous prints and the blacks are black I print it out now and it is a dark dark grey. Nothing has changed in my profiles or my workflow. I have tried hours of profile paper printing option changes and workflow adjustments but nothing changes, If I print 100 percent black from a file it comes out 95% grey I have tried it from three computers to clarify. It appears is a 4800 problem.
Perhaps it is not recognising that it is a PB catridge.
I have no idea.
I have tried adjusting the settings from the printer but there is no option to clarify catridge from the printer.
This is odd, if anyone has any idea.
Mar 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
I have a epson stylus photo r200 do i need all colors to print just black and white?
HI-
Yes you need all the ink cartridges filled or they should have ink in it. That's one feature of epson printer to prevent air to clog nozzles.
Hope this helps
Sep 21, 2008 | Epson Stylus CX4200 All-In-One InkJet...
My epsonstylus cx4200 wont print with black ink.
Please ensure that you have removed (Completely) all yellow tape on the top of the cartridge.If it is not completely removed a vacuum can form preventing the flow of ink.
Run a few cleaning cycles.
Try a local print test...
As for thr G4 sorry but I can help you except to power off all devices, power up and reboot.
Feb 09, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Epson Stylus CX4200 All-In-One InkJet Printer Logo
4,046 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
