Question about T-Mobile Sidekick ID Cellular Phone
Did not drop/but screen sticks
The mechanisim for rotating the screen on my sidekick has developed an intermittent problem. the screen will stop 1/2 open or it willnot close.
T-Mobile help automatically id's the problem as damage but I never dropped it. Is the screen a common failure mode for this model?
    President:
  • 625 Answers
It doesn usually happen when dropped. You may be able to fix it by removing the flip screen and rotating spring action fli[p piece.
The following instrutions are for a sidekick 3 lcd screen but it is the same for a sidekick id.
http://repairmysidekick.org/Remove-and-Replace-Sidekick-3-LCD-Flip-Screen
Posted on Feb 26, 2008
Speedo keeps dropping intermittently for long periods can anyone help
Peugeot 406 (1996 - 1998) - 98. Speedometer fault ' Technical ...
www.honestjohn.co.uk > Back Room > Technical matters
Sep 16, 2002 - My 406 2.1DT developed an intermittent speedo fault at about 44000 ...It tends to stick at 2000 or occasionally drops to zero for no apparent reason. ... helping me resolving my speedometer problem on my 406 3.0 v6 1999. Peugeot 406 (1999 - 2004) - 00 2.0 intermittant fault
Feb 10, 2010
Peugeot 106 (1991 - 2002) - 02 1.1 Speedo Problem
Feb 24, 2009
Peugeot 406 Speedo problem ' Technical matters ' Back Room ...
Oct 20, 2003
Ford Focus (1998 - 2004) - 1.8 petrol - Speedo drops to zero ...
Aug 6, 2003
More results from www.honestjohn.co.uk
Sep 29, 2015 | 1999 Peugeot 406
I have getting error code E000020.
E020 The path between the sub hopper and the developing assembly is clogged with toner.
0000 The developing assembly toner sensor
detects the absence of toner, while the
sub hopper toner sensor detects the
presence of toner. With the developing
clutch turned on, the hopper feedscrew
motor is rotated for 1 sec intermittently
194 times; still, the developing assembly
toner sensor does not detect the presence
of toner.
Replace the developing assembly toner
sensor. Replace the sub hopper toner sensor.
Replace the DC control PCB
Aug 17, 2015 | Canon imageRUNNER 2520 Laser Multifunction...
Why wont my backlight for my sidekick 2008 work?
go to t-mobile and tell them to fix the light i have the same problem but atleast my sidekick works
Jun 08, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Usb for sidekick id
Trackenerdzz-
The sidekick ID doesn't support USB. With the sidekicks, the only thing you see when you plug it in to the computer is the memory card. The Sidekick ID doesn't support memory cards so you will not see anything......Unless you get a developers license.
Dec 13, 2008 | T-Mobile Sidekick ID Cellular Phone
Sidekick 3 problems
Antonio-
You may be able to fix many of those things yourself. The trackball proabaly just needs to be clean. Does the LCD have a white screen when it is on? The Camera, well that may take some work.
For the white screen check out here: http://www.repairmysidekick.org/Fix-Sidekick-White-LCD-Screen
If it is not white, a new lcd can be had for 45 dollars on ebay.
they are easy to replace.
replacement of the Sidekick 3 LCD flip screen.
To clean your track ball, follow these instructions:
1: Take a deep breath and blow on the trackball area, rotate and do it again. This may blow any particles block the sensors.
2: This requires a Q-tip and some alcohol. Turn off your sidekick, wet the end of the q-tip, and gently clean the trackball while rotating. Be careful not to get the alcohol on anything but the trackball. Let dry for a minute and try it out. If this doesn’t work then try again.
Apr 14, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Buttons and Trackball not working.
Thanks so much "GrinningFool", your solution worked perfectly!!!
Jan 21, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 dropped in a cup of water. Water got into screen.
Is the screen blank all the time?
If you look really hard can you see the items on the screen but they are really dark? If so the back light for the lcd may have burned out.
Take a look at the following site for instructions on disassembly.
http://www.gsfx.org/disassembly/index.htm
If you feel comfortable with it, you can easily replace your own.
A new lcd runs about 50 dollars shipped. If you buy it from ebay, they will usually come with instructions and the screwdriver you need. A T6 torx driver is the type needed.
Sidekick LCD screens
Good job on drying it out and pulling the battery. Thats the best thing you can do when you get it wet!
Jan 14, 2008 | T-Mobile Sidekick® 3 Cellular Phone
MY sk3 track ball is no longer working.
I Can Sell you The Trackball Peice For $35 and if you live in nyc i can even install it for you for another $5, Just Drop a Line to Me 347.845.7151
Nov 27, 2007 | T-Mobile Sidekick® 3 Cellular Phone
White Screen Reset problem!!!
hi my dad gave me his side kick id but for some reason the screen is white and some times hard to see can u help me!
Jul 09, 2007 | T-Mobile Sidekick II
T-Mobile Sidekick ID Cellular Phone Logo
79 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
ismael castillo
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
