Question about Indesit W 123 Front Load Washer
Wil133 indesit 1300 washer dryer
Do not dry, clothes comes out wet, plz help , wh ?
    Genius:
  • 1,554 Answers
Look for debris in the filter,
remove the bottom front panel ( 3 screws on bottom)
Unplug washer ,
open the large access filter screw on in center , be ready for excess water to spill on floor, clean filter and be sure the pump impellers spin freely.
Posted on Feb 25, 2008
What to do with F13 error indicator on my indesit washing machine please.
Dryer temperature sensing fault (washer dryers only)
Issue: Washer dryer is not drying clothes.
Advice: We recommend you call our customer service centre to book an engineer on: 0344 822 4224
Mar 31, 2017 | Indesit Washing Machines
Indesit widl126 does not dry
Had the same problem, very hot but wet clothes. This is a condensor drier. The fack that the clothes are hot rules out the heater or its control. If yoy hear the fan running and there is no blockage the fault is caused by the 3 stage water valve. During drying a small amount of water is passed through a condensor chamber, the cold water causes steam the condense backi into water then is pumped out through the drain. If the water valve fails no condensing takes place and the clothes remain wet. The valve is easy to change and costs about 15 pounds.
Dec 04, 2012 | Dryers
I have an indesit widxl146 washer drier and the machine takes an age to dry clothes, 9 hours as oppose to 2 hours when new
9 Hours!!! I hope it isn't because the clothes are too wet because if it is I wouldn't like your electricity bill!!
There are a number of things you need to check.
I assume that you are not overloading the machine, and that you are using the correct spin cycle
Don't start the drying cycle directly after the wash, take out the clothes and see how dry they are after the wash, you need to ascertain if it is spinning the load sufficiently fast to dry them. How dry are they directly after the spin? If they are not wetter than they should be then the dryer is not getting hot enough during the drying cycle, this could be due to a faulty thermostat or element.
Make sure all the filters are clean including the pre chamber down below so that it can pump out the water (I guess it must be clear if it is washing ok? but check anyway.
The principal parts involved, assuming that
Also check that you haven't got a delay set for the dryer (unlikely I know but I thought I would mention it anyway)
I hope that helps.
Jan 26, 2011 | Indesit Dryers
My Indesit WIDL126 washer/dryer doesn't dry clothes
You have an air flow problem. This usually happens when the exhaust pipe/vent gets clogged. Clean/inspect the vent outlet, the pipe, the inlet, and the filter/lint catcher area.
Improper air flow prevents the moisture from being vented out of the dryer.
Sep 26, 2009 | Washing Machines
Ive got a Indesit WIDL102 washer dryer and it will wash but will not dry any longer. It goes through the cycle but the clothes come out wet. Any suggestions???
This problem is normally caused by either the thermostats not working properly or the heating element is the problem.
Both are normally located in the air tube of the dryer down stream of the blower.
Sep 25, 2009 | Dryers
Flashing lights
Turne off at the wall Hold the power on button then turne it on at the wall that should reset the system
Jan 09, 2009 | Indesit W 123 Front Load Washer
How do you DRY with the Haier washer/dryer
Have you tried lengthening the dryer cycle or running it at a higher temp? The usual culprit for wet clothes is not running a dryer long enough or hot enough. (I remember some stand-alone dryers (coin-operated with a fixed drying time per coin) that needed two cycles to dry stuff.
Jul 12, 2008 | Haier 14.3 lb. Washer/Dryer Combo
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Indesit W 123 Front Load Washer Logo
351 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
