Press the combination keys Fn+F... key that switches on LCD or external monitor. If that solution does not work...it means that your video card chip is dead.
Testimonial: "Thank you! Yes! Video card is dead."
Try this first, after you plug in that external monitor, press Fn key and F8, That should transfer the image to the external monitor, to double check the LCD,
try to run the diagnostics by pressing FN key + POWER button while the computer is off, that will
display colors on the screen and your will hear a single beep. If you see that then your LCD is good.
And for the external monitor if it really doesn't work
and the monitor is working with other source,
Then you'll end up replacing the video card.
What can you do if the laptop LCD screen turned completely white?
1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
Here's an example of a laptop with white screen.
When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning.
Most likely you still can use the laptop with an external monitor.
Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It's possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop.
In some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen.
If you want to check this connection, you'll have to take apart the display panel because the connector is located on the back side of the LCD screen.
These laptop service manuals and disassembly instructions may be useful.
Always check the video cable connection first. Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn't help, most likely you have a problem either with the LCD screen or with the motherboard.
The best way to find out witch one is causing the problem is testing the laptop with another working LCD screen.
you will need to connect to another monitor or your television to your computer with the vga lead monitor connection
click start control panel display change display settings adjust resolution this may vary depending on your operating system
you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system
when you select the no 2 tab this should be the extended desktop always click apply after making any changes
or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
if you can get an extended desktop your monitor is faulty
if you cant get an exended desktop
hope it helps
