Question about Maytag MGR5770 Gas Kitchen Range
Clock display/oven control panel
I have a Maytag MGR5770ADB. The clock and oven/broiler control panel does not come on. It's as if the oven is unplugged. Therefore, I can't use the oven. Sometimes, if I give it a good bang the display will come on and I can use the oven. Is there a loose wire or a short in the oven? What should I do?
  • morgan19 Oct 13, 2008
    Does this range have a fuse?
    President:
  • Maytag Master
  • 2,651 Answers
A few screws will drop rear panel to check connections, , check your power supply as wellpossible bad connection at outlet
Posted on Feb 26, 2008
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
White maytag gas and broiler wall oven is flashing F 7, what does it mean?
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Mar 12, 2011 | Maytag 24" Built-In Single Gas Wall Oven -...
What does the F7 code mean on my Maytag 24 In Gas Wall Oven with Broiler''
The Function key is shorted or stuck. Replace the touch pad or if touch pad is part of the clock, replace the clock (ERC).
Jun 20, 2009 | Ovens
Maytag wall over MEW5530BCB
Usually this turns out to be a problem with the main clock/electronic control but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance. If possible use the meter and the wiring diagram to check input/output voltages looking for discrepancies between the diagram and the actual meter readings.
TheRepairGuru ----- www.repairclinic.com
http://www.repairclinic.com/Maytag-Range-Stove-Oven-Parts
Jan 26, 2009 | Maytag 30" Built-In Single Electric Wall...
Maytag CRE9500 electric range has no display. No fuses on this model. Everything else works fine. Just no clock, timer, oven temp, etc. Looked inside the panel and saw no obvious loose or burned wires....
Hi , Jorland...
I have a CRE9500ADE and has fuses way behind the drawer under the oven,
there is a 15 amp fuse for the clock and controles the way see it.
Hope this helps...
Sep 24, 2008 | Maytag Kitchen Ranges
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Aug 25, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
I was baking in my Maytag range when there was a loud popping noise and the oven stopped working. The broiler, clock and timer do not work either. The control panel will do nothing. The burners work and...
Well on most electronic controlled ranges with the problem your describing alot of time it is the clock that needs replaced. And yes most ovens have 2 ignitors.
Jul 11, 2008 | Maytag Kitchen Ranges
MAYTAG STOVE PROBLEM...NEED HELP
the broiler came on automatically??? not a sensor issue. sounds as if you have a broken wire perhaps, or a faulty control panel energizing the broil element w/o being prompted to. does it say its broiling when element comes on??
Mar 05, 2008 | Kitchen Ranges
Maytag MGR5770 Gas Kitchen Range Logo
191 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
