Question about Roper RAS8445KQ Top Load Washer
Roper top load rax4232kq0
When i start the washer it does not fill up with water but starts the agitate cycle,no water comes out at all just goes right to agitating
  • 185 Answers
Is the water valves turned on
Posted on Mar 26, 2008
Why does my maytag yop loading centennial washer sometimes spin and sometimes not?I can move the washer cycle knob to different cycles and I will still have the same problem
I had the same problem kinda. Does it start to agitate before it fills with water? Its supposed to fill with water, agitate, sense the amount of the load, then fill with the correct amount of water. If it agitates right away then you need a water level/ temperature control sensor. I replaced mine and no longer have the problem of wet clothes at the end of the cycle. The part number is w10248240. Look on you tube for a video on how to replace. The one I saw showed how to diagnose the sensor. The part cost about $90 and it took longer for me to get out my tools than replacing the part. This part goes bad by starting the machine then adding more clothes after it starts. You can also try blowing air down the tube from the back of the sensor. It didn't work for me but was suggested and blowing the air didn't cost anything.
Apr 23, 2014 | Maytag Centennial 3.2 cu. ft. SuperSize...
The washer starts in agitation mode. Will not do anything but agitate. Is it Water Level switch that needs to be replaced?
Washers start in fill mode as it requires the level of water set to start the agitator mode.. If your machine goes immediately to agitate then I would think that the agitator control module is failed and needs replacement. have an appliance electrician check it out.
Aug 17, 2013 | GE WDSR2080D Top Load Washer
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
I have a Roper top load washer. when i start it, it automatically starts on agitiate. It skips the filling cycle. model# RTW4100SQ1
It sounds like you have a bad water level switch.The switch is the one you turn to set the water level.
Jun 24, 2011 | Roper RTW4100SQ Top Load Washer
Kenmore top load washer 29822800 - washer-selector is set on one rinse- when machine starts the agitator starts immediately as water fills - then when machine stops after spin cycle in off position water...
if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
Aug 14, 2010 | Kenmore 24032\24036 Top Load Washer
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Starts to agitate as soon as cover closes, will not spin
Bad timer. It has welded points making it imposiable to change anything on time. Needs replaced.
Please rate solution
Aug 28, 2009 | GE WBSR3140DW Top Load Washer
Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
124 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
