Question about Motorola Mobility RAZR V3
Razr2 broken cracked screen
I just need to replace a cracked screen. I have the replacement screen, but while prying the old screen up, it looks as though it might pull the electronics up with the adhesive. I replace a v3 screen no problem. Do you know how to replace it without damaging the electronics of the phone?
  • AdamGom Feb 29, 2008
    Does anyone know how to adhere the replacement screen to the phone? I purchased a new glass lens, but it did not include any adhesive.
    Thank you.
I bought 2 glass screens backed with double sided tape for £1.79 on ebay from sandymobilephones.  http://myworld.ebay.co.uk/sandymobilephones. (Nothing to do with me but I'm pleased with the deal)
Posted on Mar 11, 2008
Ya, be careful. i read online use a razor blade, jewelers screwdriver, etc to pry up on it, then take a piece of paper and work it back and forth till the screen is completely removed.
remove any bits of glass, then carefully clean off the old adheasive with a cloth or your finger. this is just what i read online. i am going to try this myself when i get the new glass screen in.
Posted on Feb 27, 2008
How do I replace the screen for this exact phone. There was a crack that appeared and now below the crack will not respond while above the crack works just fine.
You can purchase a screen repair kit from Ebay or Amazon for that phone. Replacing it is kinda scary if you have never done it before but trust me it is no big deal. You simply use small screw driver to pry up the broken screen and gently remove the old broken one. Use the kit to replace it. Good Luck!
Jan 23, 2015 | Cell Phones
Cracked screen
If you look on your computer (usually on the bottom on laptops) you should be able to see a sticker with a specific model number for your computer. After you have your model number you should be able to find OEM replacement screens, just be careful and make sure the part matches up with your model number. The actual labor portion of replacing a screen is quite easy, but you will need some precision screwdrivers and something to pry the bezel off from around a screen (I used an old card from my wallet), from this point it's practically just unplugging the old screen and plugging the new one up, and then reassembly.
I've attached a video that shows the process, but it is really quite simple. Laptop screen replacement How to replace laptop screen HP Pavilion dv7
Feb 23, 2014 | Computers & Internet
Broken laptop screen
There is nothing more frustrating than a broken laptop screen. Whether you have dropped your laptop or stepped on it,once the screen is cracked it has to be replaced. Having the screen repaired may cost you almost as much as a new laptop. Purchasing a new screen from the manufacturer can also be expensive. Taking the time to look online at computer message boards or resellers can help you to find a reasonably priced screen. By following a few easy steps, you can replace your cracked screen and have a functioning laptop in an afternoon.
Determine what model laptop screen will fit your laptop. Ordering a screen directly from the manufacturer can be almost as expensive as buying a new laptop. Look at online computer message boards, auction sites and retailers to find less expensive options. Disconnect any power source, including the battery pack, from your laptop before you begin. Locate and remove the four to six screws that hold the bezel, or plastic frame cover, in place. The screws sometimes have small plastic or rubber covers over them. Pull the plastic bezel away from the screen cautiously, working around the edge. Some bezels snap in and out of place. A small flat-head screwdriver may be helpful in prying the edge of the bezel away from the screen. Pull the screen forward gently. You will find two main wires behind it. The ribbon-like wire, or video cable, is usually taped in place. Remove the tape and disconnect the video cable from your broken screen. Remove the broken screen from its metal frame. Connect the new screen to the video cable and pop it into the metal frame. Replace the tape, plastic frame and screws. Power up your computer and test your new screen. Hope this helps.
b>
Dec 10, 2012 | Computers & Internet
My phone was dropped and now I can't see anything on the screen.
If the screen of your phone is not crack, the problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying. But if the screen is crack, you will need to get a brand new screen to solve the problem.
Take care.
Jul 28, 2010 | Motorola Mobility RAZR2 v9 Cell Phone
Broken screen on Blackberry Curve needs to be
you can use warranty or send it to the company and they will charge you if you hadnt taooken the warranty
Sep 12, 2009 | RIM BlackBerry Curve 8310 Smartphone
Motorola razor v9 blank screen.
Friend, thats LCD problem.the flex connector is cut or interface is broken. you can replace that one. if not the LCD is damage or broken so you need to replace the LCD. thts the only problem nothing else for sure.good luck
Jun 26, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
LCD screen replacement
www.buy202.com they have them for under 40 with free shipping
Sep 08, 2008 | Kodak EasyShare M853 Digital Camera
Broken Screen
Ebay is your best bet,check in the faulty section.
Apr 20, 2008 | Televison & Video
Cracked screen
Take it to the cell phone provider. It may be worth it just to get a new one from the sound of this.
Mar 10, 2008 | Lands Phones
Nokia 6133 LCD Replacement Trouble
my guess is that you messed with something while you were prying it open.
I have the nokia 6126 (very similar) with a broken screen but i get it open, could you help me with that
Feb 14, 2008 | Nokia 6133 Cellular Phone
Motorola Mobility RAZR V3 Logo
338 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
