Cars & Trucks Logo
Posted on Apr 22, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My OnStar navigation no longer gives voice prompts for turns and such. Was working fine, radio mutes down but then no voice prompts play. Just started in middle of a drive. How do I get the audio voice prompt back. Onstar has reset and still doesn't work. Noticed it happened after making a call via bluetooth with cell. The audio system then linked to the phone (volume was only 1-6 levels like the phone). Turned the car off and the radio was fine but the onstar navigation no longer gave voice prompts. The bluetooth is completely off but the voice prompts didn't reset.
Jerry Ross
Level 3:
  • Chevrolet Master 1,121 Answers
  • Posted on Apr 22, 2017
Jerry Ross
Chevrolet Master
Level 3:
Answers
1121
Questions
7
Helped
355320
Points
2563
I was told by on star that if you leave the drivers door open for 90 seconds and then lock all of the doors and wait until the next day the system will reset itself. I know this sounds like smoke and mirrors but it does work. Please let me know. Hope this helps.
5 Related Answers
Anonymous
  • 32 Answers
  • Posted on Oct 13, 2008
SOURCE: 2007 cadillac escalade... Onstar disable
you can remove the fuse however you will get a call asking if everything is okay.
Anonymous
  • Posted on Feb 14, 2009
SOURCE: Turning off the OnStar in a 2005 TrailBlazer
The OnStar module is under the rear seat, passenger side. You should be able to just pull the connectors out of the module. Just the rectangular ones.
The dealer is thinking about the power amplifier for the Bose radio system. That's in the fender at the right rear of the car, but that's not the issue here.
GM Elec
Bruce Bracey
  • 1000 Answers
  • Posted on Mar 15, 2009
SOURCE: how can i find my car from my home computer using onstar
I believe you will have to call onstar and request the location information. They will be able to tell you the address or general location of the vehicle.
I am unaware of any other means to track the vehicle unless you report it stolen.
Good luck.
Regards,
Molson02536
Harvey N Tawatao
  • 3854 Answers
  • Posted on Apr 08, 2009
SOURCE: how do i disable onstar gps in 2003 chevrolet 2500 series crewcab
Unplugging the Onstar unit should deactivate it and if you can get to it. I haven’t yet taken the time to locate the Onstar unit in my Yukon. In older Yukons, Tahoes, and Suburbans the Onstar was in the cargo area, above and behind the right rear wheel well. However, it’s my understanding that when they redesigned the Onstar unit for smaller size, they started putting it behind the instrument cluster in the dashboard. Good luck
Anonymous
  • Posted on Nov 30, 2010
SOURCE: 2008 saturn vue- onstar button is red..it will
The battery is in the ON_STAR module which is located in the left rear aft corner. It is accessible by removing the left bin. The battery retails for $95.00 at the dealer and $85.00 install fee.
2answers
I have an 04 Saturn Vue. My radio turns has power, CD player works but I cannot get any sound. Other day when I was driving the speakers got all staticky and then sound went out. I check the 3 fuses and...
What system does it have ? Base or up level ,does it have a amp ? Do you know what a RPO code is ? Without testing no one could say for sure what the issue is . First off would need to know what system we are dealing with .
RPO Options
The entertainment system on this vehicle is configured with either a base or uplevel audio system. Both the base and uplevel audio systems contain a radio, antenna, and speakers.
The following shows the Enteratinment RPOs that are available for this vehicle:
• (UM7) AM/FM Stereo
• (U1C) AM/FM Stereo CD
• (US8) AM/FM Stereo, CD, MP3, RDS, EQ
• (US9) AM/FM Stereo, 6-Disc CD, MP3, RDS, EQ
• (UXQ4) Base Four Speaker
• (U79) Uplevel Four Speaker
• (WBM) Premium Audio
• (U2K) Digital Radio
Circuit Operation
Radio Power: The main radio power is supplied by the 10A RADIO (BATT1) fuse in the body control module (BCM). Radio switch-on power, 12 volts in ACC, RUN or RAP, is supplied by the 10A RADIO (ACC.) in the BCM.
Radio Grounds: The main radio ground provides a ground for the radio circuits. An additional braided ground strap provides a shielding radio case ground to reduce EMI noise. Both grounds are connected together inside the radio.
Radio Speaker Outputs: At zero volume, the plus (+) and minus (-) speaker outputs are both approximately 5-6 volts, measured to vehicle ground. If a plus or minus for any speaker output is shorted to ground or voltage, the radio circuitry will turn OFF all 4 speaker outputs for component protection. Above zero volume, the plus and minus change to create a voltage difference between each other, to drive the voice coil of the speaker.
Radio Park Lamp Input: The radio park lamp input allows the radio to sense when the vehicle parking lamps are ON. When the parking lamps are ON, this circuit goes to battery voltage, and the radio display back-lighting switches from full bright to the brightness level determined by the I/P illumination input.
Radio I/P Illumination Input: A pulse width modulated (PWM) voltage for instrument panel (I/P) illumination is provided to the radio I/P illumination input. The Radio uses this input to directly illuminate the radio buttons and adjust the radio display back-lighting when the park lamp input is ON.
Amplifier Power: The main amplifier power is provided by the 20A PREM AUDIO fuse in the instrument panel fuse block..
Amplifier Radio Speaker Inputs (WBM only): The radio speaker outputs, at a reduced output level for amplified systems, are the amplifier inputs. The amplifier boosts these inputs and outputs them to the vehicle speakers. Speaker plus and minus circuits from the radio change to create a voltage difference between each other. If one speaker plus or minus is open between the radio and the amplifier, the input to the amplifier is approximately half because only one of the circuits is changing. The speaker for that channel then operates at approximately only half the normal volume.
Amplifier Speaker Outputs (WBM only): At zero volume, the plus (+) and minus (-) speaker outputs are both approximately 5-6 volts, measured to vehicle ground. If a plus or minus for any speaker output is shorted to ground or voltage, the amplifier circuitry will turn OFF either the front outputs or rear outputs for component protection. Above zero volume, the plus and minus change to create a voltage difference between each other, to drive the voice coil of the speaker.
Amplifier Radio-On (WBM only): When the radio is ON, this circuit is pulled to 12 volts by the radio. The amplifier switches ON when this circuit is 12 volts and switches OFF when this signal is 0 volts.
Remote Radio Audio Signal Inputs (UE1 only): Audio output from the OnStar® communications module connects to the remote audio signal inputs of the radio. When the cellular telephone mute signal goes to 0 volts, the radio over-rides any other audio signal and uses these inputs as the source for output to the speakers.
Cellular Telephone Mute (UE1 only): The OnStar® communications module uses the cellular telephone mute signal circuit to over-ride the radio for OnStar® communication. When cellular telephone mute is not active, this circuit is held at 2 volts by the radio. When the cellular telephone mute signal is pulled to ground, the radio over-rides any other audio signal and uses the remote audio signals as the source for output to the speakers. If the radio was OFF when this circuit is pulled low, the radio will turn ON. Additionally, the radio fades the speakers to full front, adjusts the volume to an initial audible level, and sets an AutoTone designed for optimal use with OnStar®. When the mute signal is no longer pulled to ground, the radio returns to the mode it was in previously.
Hooking up a professional or factory scan tool that can read radio codes would be one of the first test's to do .
DTC B1025, B1035, B1045, or B1055 (w/out RPO WBM)
DTC B1025, B1035, B1045, or B1055 (w/ RPO WBM)
DTC B1030, B1040, B1050, or B1060 (w/ out RPO WBM)
DTC B1030, B1040, B1050, or B1060 (w/ RPO WBM)
DTC B1259
The following conditions are present for 250 ms or longer:
B1025 - B1055 01
One of the speaker positive output circuits is shorted to battery.
B1025 - B1055 02
The speaker positive output circuit is shorted to ground.
B1025 - B1055 04
The speaker positive output circuit is open.
Your best bet , take it to a qualified repair shop .
Avhw4400nex shuts off when onstar answers a call or onstar comes on. Whats wrong or do i need to do.
if you read or played disc for onstar would know it turns off /mutes radio
2answers
Why does radio volume sometimes have low volume even when turned up
Could be that the potentiometer is not tracking properly. If that is not it, then it is the chip that controls the volume at fault.
How can I get the voice prompts to work on my 2012 Crysler 300 navigation system? The voice prompts are turned on.
check the manual. if that does not work google the problem. if that does not work go to a dealer and ask a salesman.
1helpful
THX navigation system in 2007 Lincoln MKX
Could be mute controls for the telephone. The voice for the Navigation is adjusted separately from the radio volume. If any work was done on the vehicle, like a battery disconnect, then radio controls may need to be reset.
You need to toggle through the Menu to things like screen brightness for the Navigation.
You also have a speed sensitive radio and the volume controls could be affected by these settings.
Our 2010 Buick Enclave has all the audio muted. The radio, the turn signal sounds when they blink, the onstar system. All sounds are muted. What is causing this?
first check ur fuses if their is any bad ones replace them and check and see if everythings working.if not disconnect ur battery for about 15 min then reconnect and then check everthing
1helpful
The light display for the radio no longer lights up. Radio still works.
This is an Internal problem in the radio. and the radio will need to be repaired Or have an aftermarket radio installed.Installing an aftermarket radio is usually the least expensive way to go unless you have onstar. than have the radio repaired since onstar works through the factory radio.
2answers
4helpful
Radio speakers seem to be muted. I pushed INFO button, did this cause something to mute ??
Some radios have phone buttons that mute the speakers so you can talk on the phone. If you have Onstar and no active subscription it can also mute the radio thinking you are trying to talk to Onstar.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
