Question about Zanussi IZ12 Front Load Washer
Zanussi IZ12 part identification
My IZ12 is now working but whilst looking for the fault I took apart the black round packaging which is clipped on just behind the LCD under the hood. Inside the plastic package there is a small PCB with a chip or controller of some sort. There is also a rubber disc and spring with what looks to me like a magnetic switch or valve above it(?) A pipe comes out of the bottom of the lot.
I'm wondering if someone can tell me what this part does and if it needs calibrating of sort as there is a large adjustment screw on top of it.
Thanks.
  • Select Feb 25, 2008
    Owners/user manual there only, thanks anyway.
The part you refer to is called a pressure switch, as water enters the drum it forces air up the tube at the bottom of the switch whitch controls the amount of water the machine takes in depending on the wash cycle selected. As long as you put it back together properly it will work fine. They are factory set and can not be calibrated. (if faulty it must be replaced)
Posted on Dec 06, 2008
  • 552 Answers
Http://www.manualscenter.com/advanced_search_result.php?keywords=Zanussi+IZ12&currency=USD
Go here for a service or repair manual.
Posted on Feb 25, 2008
Zanussi IZ12. How do I use it?
Check the user manual or go online to Zanussi website. Look for manual.
Jan 01, 2016 | Zanussi Washing Machines
Hi, good evening. I have a zanussi iz12 washing machine that stops during rinse node and gives e20 fault (wont drain). I checked the pump - working fine. I've found that if i blow into the waste pipe the...
Hi there
I have an IZ12 jetsystem which sometimes works and other times it starts and then clicks and stops just before the water starts to run in. I usually turn it off and try it again a few hours later and then it starts to work again. Sometimes it is the next day before it will work again. Would anyone know the problem?
Jan 11, 2010 | Zanussi IZ12 Front Load Washer
Error e51 on zanussi iz12
I've had the same problem. I removed the top lit and found some pressure transmitter and a pressure switch. I suspect that the pressure transmitter is use for measuring the waterlevel in the machine. I think the membrane loses its flexibility over the years.
I pulled of the hose from the transmitter and blowed and sucked a few times on the transmitter. After doing this the machine washes without a problem since then.
Hope it helps for you.
Dec 07, 2009 | Zanussi IZ12 Front Load Washer
Zanussi IZ12 bearings gone & plastic fragments in drum
Probably all parts inside drum is ok.Heating element is the only damageable item and a sensor.Changing bearings you must separate the drum, all screws in middle of drum must out and then bearing and zimmerring can be changed.Jan
Feb 15, 2009 | Zanussi IZ12 Front Load Washer
E40 fault code zannusi washing machine.
You could look here:
RepairClinic.com (good)
espares.co.uk
AppliancePartsPros.com
Jan 31, 2009 | Zanussi IZ12 Front Load Washer
Where can I order a new belt for my Zanussi IZ12 wasmachine?
bit of a nuisance doing it from afar but i have used currys masterpart ( a uk site) for ordering spares now i'm retired
Nov 12, 2008 | Zanussi IZ12 Front Load Washer
Zanussi IZ12 Pumps, then Pause LED is flashing.
hi i had the same fault, the machine would go onto pause after a couple of seconds.. after nearly a full strip down of the machine and checking the obvious i found there was carbon dust on the pcb which was causing tracking (the circuit board at the top of the machine). The pcb looked like it was burnt out, but after a quick dust down to remove the carbon and refitted back into the machine it worked fine. HTH
Jul 30, 2007 | Zanussi IZ12 Front Load Washer
Zanussi FLE 1015W
Any solution yet ? same problem here Zanussi IZ12
Zanussi IZ12 Washer won't spin.
check the motor carbons they r mounted on either side of the armiture you will find they r held on the motor with 2 screws or 2 5.5mm nuts make sure you unplug the machine before u start working on it good luck
Jul 24, 2007 | Zanussi IZ12 Front Load Washer
Zanussi IZ12 Front Load Washer Logo
222 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
