Question about Copystar CS-2030 Copier
Copystar CS2050 Trying to set date/time and cannot find option nor a manual. HELP!
  • theprecious Feb 25, 2008
    Copystar CS2050 need assistance in setting date/time.
    Sniper:
  • 56 Answers
You have System settings button on the copier control panel,Press it. Navigate through menu and find date and time settings. if password is requested, try code 2000.
Regards.
Posted on Mar 21, 2008
Manual for Alta Fitbit How do I set the time and date for my fitbit
You set the date and time from the Fitbit App or Fitbit Connect when you setup or sync the fitness band with the computer/tablet. Open the Fitbit Dashboard and then tap (or click) the Account icon. Enter the Advanced Settings menu and check the Time Zone section. If needed, turn off the Automatic option and manually set the current time zone. The Alta will display the date and time based on the time on your computer/tablet when you synced the devices. See https://help.fitbit.com/articles/en_US/Help_article/1176/?q=set+date+amd+time&l=en_US&fs=Search&pn=2 . This is the "How do I change the time on my Fitbit device" FAQ.
Alta has the manual for the Fitbit on the product support page: https://help.fitbit.com/?p=alta . The direct link to the manual is https://staticcs.fitbit.com/content/assets/help/manuals/manual_alta_en_US.pdf . Additional device help is available at the help page: https://help.fitbit.com/ .
I hope this helps.
May 02, 2018 | Exercise & Fitness
HOW TO CHANGE LASER UNIT COPYSTAR CS2050
laser unit is under cover where copies exit, remove cover unplug laser unit and then remove 4 screws holding it down. replace unit
and scerws and plug in unit and replace cover and all is well
Oct 12, 2012 | Copystar CS-2050 All-In-One Printer
How do I change the time on my CopyStar CS-1820
Setting the Time Zone
1 Access Time Zone.
If you are unsure how to use this route map refer to Accessing Menu Items on
page 3-3.
2 Press arrow keys to select the time zone that you are in.
3 Press Enter. The message display shows Completed and returns to the Date/
Timer Set. screen.
4 Press right Select. The message display returns to the basic screen.
NOTE: Periodically check the time that is shown in the message display and adjust
as necessary to match the current time.
1 Access Year/Time.
page 3-3.
2 To set the date, for each field press arrow keys as many times as necessary to
display the correct value then press arrow keys to move to the next field.
3 When the date is correct, press Enter. The time setting screen
(hour:minute:second) is displayed.
4 To set the time, for each field press arrow keys as many times as necessary to
5 Press Enter. The message display shows Completed and returns to the Date/
Timer Set. screen.
6 Press right Select. The message display returns to the basic screen.
Mar 17, 2011 | Copystar CS-1820 Copier
Error code C4000 For a Copystar CS2050
it's mean's laser problem need to change it
May 07, 2010 | Copystar CS-2050 All-In-One Printer
Large document stuck in memory CS2050 - I just need to clear the memory - is there a sequence of keys to push
you can rest your machine to deffault sitting by using u020 or u021 but in my opinion i dont like do run those programs
Apr 01, 2010 | Copystar CS-2050 All-In-One Printer
How to set date stamp for canon ixus 860is
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
dsc_include_date01_tcm13-520510.jpgTo set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
dsc_include_date02_tcm13-520511.jpgBe aware that if you take pictures with this option enabled, the Date and Time cannot be removed from the pictures at a further time. It will permanently appear on the picture.
Please rate my help++++Thanks for using FIXYA
Feb 28, 2010 | Canon IXUS 860 IS Digital Camera
Wrong time
To set the time do the following:
Setting the date and time
Press the Back/Options button ((the left pointing green arrow)).
You may need to do this more than once until the main menu appears.
Select Extras Date & Time. The current date and time are displayed.
Press and hold the Back/Options button.
Select Set Time or Set Date to change the time or date settings.
Select Date Separator, Date Format and Time Format to adjust how the date and time are displayed.
Select the options you want.
Mar 27, 2009 | Creative Labs ZEN V Plus MP3 Player
Power Shot SD550 Date Stamp
Dear BethSmith,
I have had the same problem for a long time.  It has nothing to do with the battery, etc..  It has to do with the software of the camera.
You are only able to have time stamps on the photos when you are in the postcard mode.  (resolution will be set to 1600x1200, at fine setting)  Check out page 29 and 39 of Advance user manual!
Good luck,
Shah
Oct 11, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Copystar CS-2030 Copier Logo
138 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
