Question about Conexant (56KUSBMODEM)
Mentor adsl usb
Hello .on my computer i have windows xp . i have installed the mentor .conexant access runner usb adsl (wan) modem .
device type isdn server type ppp, transports tcp/ip
authentication md5 chap .
would the modem do to work my new comp which is vista
  • 97 Answers
I have compaq presario c700 note book with intel r celeron r m cpu 530 @ 1.73 GHz. I can not found the sound driver could pls help me. and also tell me how to install it.my OS is xp service pack 3.
hello, first u need three driver downloaded into your computer: - Microsoft Universal Audio Architecture (UAA) Bus Driver for High Definition Audio: http://rapidshare.com/files/375339812/uaa_sp32646.exe - Conexant CX20549-12 Audio Driver for Microsoft Windows XP: http://rapidshare.com/files/375299248/audio_sp36090.exe - Conexant CX20548 Modem Driver for Microsoft Windows XP HD Audio: http://rapidshare.com/files/375343127/modem_sp36089.exe
to install the audio and modem driver: 1. u have to install UAA Bus Driver first, double click 'uaa_sp32646.exe' then follow the installation 2. install Conexant CX20549-12, double click 'audio_sp36090.exe' then follow the installation 3. install Conexant CX20548, double click 'modem_sp36089.exe' then follow the installation
this will install the sound driver and modem on your computer
hope this useful, regards.
Aug 26, 2011 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Can I set this up this wireless router if I have cable internet and not DSL?
You CAN do this if you have access to the firmware of the ADSL gateway.
Connect cat5 cable from ethernet port on cable modem to ethernet port 1 on ADSL Gateway. (Must be port 1)
-Connect cat5 cable from computer NIC to other port on ADSL Gateway.
-(You may need to) Start->Run->cmd
ipconfig -release all
ipconfig -renew
Here's the trick...
-Open web browser, go to ADSL Gateway homepage (likely 192.168.0.1)
-Configuration tab, Advanced WAN->WAN
-Change WAN PORT drop down from DSL ATM PORT to ETHERNET PORT 1
-Click Edit button. Change Protocol from PPPoE to ROUTED.
-Radio button for DHCP Client to Enable.
-Click Set button.
-(You may need to) Power cycle both Cable Modem and ADSL Gateway device
Now this was done on a Westell ADSL gateway from verizon, yours may differ and you may need to look up the instructions for your specific gateway.
Aug 08, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
Shows error633
When you try to use your modem on a Windows computer, you may receive an error message similar to the following: Error 633 Modem is already in use, or is not configured for Remote Access dial out or The port is in use.
Try this one after the other
1. Verify no other applications that are using the modem. You can open Task Manager to check that by press CTRL+ALT+DEL. Another way to test it is reboot the computer.
2. This behavior may occur when another device with a driver, for example outdated Palm Pilot software, conflicts with the modem.
3. Telephone.ini or unimdm.tsp is missing or damaged.
4. Make sure the modem is setup correctly and may apply SP.
5. Removing and reinstalling it, or apply the new drive may fix the problem.
6. Make sure no two ISDN installed on the same machine and attempt to connect to the same server.
Apr 01, 2010 | Conexant All 56K Modems: Amigo V.92...
I hv a netgear wireless adsl modem and i m using bsnl broadband connection can send me the settings to configure the modem at my email id mehtaankur3@gmail.com
TYPE-I Modem Configuration - Huawei SmartAX MT880 Modem / SmartAx MT882 ADSL Modem Configuration
SmartAx MT880 ADSL Modem has One ethernet Port.
SmartAx MT882 ADSL Modem has One ethernet Port and one USB Port.
Set your computer IP address as 192.168.1.2
( If you are using USB port, install USB driver first)
Open Internet Explorer in the Address bar type the URL http://192.168.1.1
You will be propted for Username and Password.
Username: admin
Password: admin
Click on Home
Click on WAN setting
Your WAN Setting should be as follows:
PVC No.: PVC0
Wan type: PPP
Connection Type : PPPoE
VPI / VCI : 0/35
Default Route : Enabled
Username: yourusername@dataone
Password: yourpassword
Use DNS : Enabled
Click on Apply.
You will be asked to save and reboot.
Select Yes
Once your modem is rebooted , the summary page will be displayed .
The "Green" status of PVC0 status indicated that you are now connected. (in Summary page)
SmartAx MT882 ADSL Modem ADSL LED will turn 'Orange' from 'green' when succesfully connected
Sep 15, 2009 | NetGear WGR614 Wireless Router
Intelligent ISDN USB WAN Driver
in the device manager right clik the modem to update driver
Jun 09, 2008 | Computers & Internet
No Line on US Robotics ADSL Wireless Gateway
Initially what I suspect is that your USR's connection to your ISP is intermittent but with that of the USB modem is consistent. This is clearly an ISP issue and should be resolved by them.
One thing you can try is to verify the integrity of the line splitter that is commonly used to split the 2-wire signal to the telephone and to the modem/router. You can actually remove the splitter and connect the telephone line straight to the WAN/ADSL input of the USR 9106 Wireless Gateway and check if their is an improvement or if your ADSL and WAN IP will light up consistently.
Alternately, if your ISP is too busy to attend to your concern, you can try mimicking the USR's WAN settings to that of the USB modem's. While still using the USB (provided by your ISP) determine its WAN IP settings. This would be IP address, Subnet Mask, Default Gateway and DNS. You need to access the USB modem to get this data. Should you need detailed instructions, pls post back the make/model of the ISP provided USB modem. If you were able to gather the information. Connect your USR 9106 Wireless Gateway (Ethernet 1~4) to your PC using a LAN cable and enter its configuration page. In its WAN/ADSL settings, use the numbers gathered from the USB modem. You may need to do a full hard reset on the router (rear panel) prior to putting in the numbers.
Hope this be of initial help/idea. If problem persists, pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 06, 2008 | Computers & Internet
ISDN - usb adapter
remove the adapter from your computer and look at the chip for the serial # or product #, or look on the original packaging. once you have located your pruduct # do a google search for "_______ drivers" or go to www.driverguide.com and seach for it. If you reply back with the pruduct # of your adapter i'd be happy to search the web for a driver and give you the link.
Jan 13, 2008 | Computers & Internet
Installing wireless modem
To download the most appropriate modem driver for your Windows XP computer, a few steps is indispensible to finish the whole process.
Step 1
Look at the modem. Write down the make and model. If you have a dial-up modem in your computer, take the panel on the tower off. Shine the flashlight on the device. On the circuit board, the manufacturer and/or model number is present.
Step 2
Locate an Internet connection. To download Windows XP modem drivers, go to the library or someone's home where the Internet is able to connect. If you have another working modem in your house, you can download them directly to your computer.
Step 3
Go to the manufacturer's official website or a Windows XP modem driver's web page. Windows XP Drivers, Drivers Kit and Driver Support Registry have modem drivers for the Windows XP operating system.
Step 4
Click on the modem device. Select the manufacturer of the modem. Some of the driver sites are XP only, while others are all drivers. You will have the chance to choose your operating system before downloading. Click on the "Download" tab. Wait approximately 10 minutes, depending on the speed of the PC and Internet connection.
Step 5
Burn it to a disk. If you are at another location, you need to burn to CD/DVD for transportation.
Dec 22, 2007 | Belkin (A3X1627-06KIT-M) Modem
Setting up linksys adsl2 modem
The ADSL, Ethernet, and USB ports are located at the back of a Linksys modem. These ports are where the phone cable and computer will be connected. The ADSL Line should be connected to the ADSL port and the computer either be connected to Ethernet or the USB port., If u r using a ethernet cable no need to run the setup cd just connect the ethernet cable and contact ur isp..
do not worry about ur sagem modem, let it be inside.. just connect ethernet cables alone..
To setup a Linksys ADSL Modem with usb cable you need to perform two steps:
  1. Connecting the Devices Together
  2. Installing the USB Driver
Step 1:
Connect the phone cable to the wall jack with ADSL service and then connect the other end to the ADSL port of the modem.
Step 2:
Make sure the power adapter is plugged to an available power outlet.
Step 3:
Connect the USB to the USB port on the back of the modem and then connect the other end top the USB port of the computer.
Step 4:
Power on the modem. After connecting the device together, install the USB driver. For instructions, follow the steps below.
Step 1:
Power on the computer.
Step 2:
When the Hardware Update Wizard window appears. Click Install the software automatically (Recommended).
NOTE: Windows XP has pre-installed drivers for the ADSL2MUE and will automatically install the USB driver for the modem.
Step 3:
Click Finish.
Nov 06, 2007 | Computers & Internet
Conexant (56KUSBMODEM) Logo
402 people viewed this question
Top Conexant Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jessi Singh
Level 1 Expert
Are you a Conexant Computer and Internet Expert? Answer questions, earn points and help others
