Question about Whirlpool Duet GHW9150P Front Load Washer
Close are Too Wet
My clothes are not finishing the normal wash cycle as dry as they used to. Any ideas?
  • danda10 May 24, 2008
    I have a duet washer that has a clogged drain. How do I get to the drain plug under the washer? Do I try and tip it?
    Problem Solver:
  • 17 Answers
Are you getting any type of error message on the display?
How long have you had the washer? Have you ever cleaned out the filter?
I also have a Duet (2 years old) and my clothes were not spinning out as well as they once did. I started getting a SUD error message with almost every load and then started getting a F5 message which the manual says it means it's not draining correctly. It never said how to fix it though. Went into the panel underneath washer, found the clean out plug for the drain...it was gross! Cleaned it out, washer works like new again.
Posted on Feb 25, 2008
I have a aeg washer/dryer- it washes fine but then I have problems drying Any idea how I can solve this? problem
Please start with your clothes after the washer finishes it's washing cycle.
Take them out and see how dry they are.
They should be nearly dry.
If not, perhaps the reason you are having problems is they are too wet to begin with for the dryer to properly do it's job..
This is not a rare problem.
One possible reason for the clothes not to be dry when the washer finishes is a loose or worn out belt under the washer.
Another problem some washers have, particularly washer/dryer combos, is that they are sometimes not very effective.
In that case, either smaller loads or rerunning the spin cycle at the end of the washing cycle might help you.
God bless your efforts.
Nov 30, 2015 | AEG Washing Machines
Doesn't dry clothes properly after spin cycle clothes are wet when cycle finishes It empties water
Bad belt will not allow drum to reach full rpm during spin cycle, not spinning all water out of clothes
Sep 15, 2015 | Washing Machines
How can I get less wrinkles in my clothes after wash cycle is finished?
I use the dryer to get the wrinkles out. If i have a wrinkled shirt that is already dry and I need to wear it, I put it in the dryer for a few minutes with a wet wash rag.
Oct 10, 2014 | Kenmore Washing Machines
Samsung WA422PRHDWR not filling with enough water
I find that some of my clothes don't seem to get wet enough to clean them properly. I like to use the pre-wash cycle to wet everything thoroughly then the machine goes through the normal wash cycle and it seems to do a better job. Just an idea.
Dec 08, 2012 | Samsung WA422PRHDWR
Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Aug 20, 2009 | Maytag Washing Machines
Some clothes not clean or even completely wet after wash cycle finished
Ebay item number 200262803398 is a cheap PDF service manual for this model.
prem
Oct 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Hotpoint wd440 heating but not drying
yes, the dryer is pants im afraid. weve had ours going on 4 years & it has broke down every 6-10months - seriously! the dryer will leave clothes hot & steamy but when hung up for 1/4hr they r dry! _ Hotpoint advised us that he machine is esigned his way - but dont believe a word from their corporate b***hit mouths!
Aug 11, 2008 | Hotpoint Aquarius WD640 Front Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
249 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
