Question about Lite On LVW-5005 DVD Recorder
Lvw5005 recorder I contacted the support unit , they seem to think that the lazer is burnt out; they don't want to fix it;I contacted an electronics expert he cannot get the part to fix it . Nice , HUH ?? If you leave the unit ON the lazer will burn out quickly. I am really pissed off at Liteon , they are ALLOWED to sell something , BUT you cannot get it FIXED !!! ??That is BS !! You buy a car: the shock fails , Do you buy a NEW CAR ?? I just want it fixed ..
  • mmillerpro Mar 05, 2008
    Same problem with FAIL indicator no matter what disks I try to record. Also, will only playback PRERECORDED disks. I can't believe there is NO WAY to fix it.....
The part required ***IS*** available duckie125!!!!!
I fixed my LiteOn LVW5005 by going to the local computer shop and buying a LiteOn 20x DVD Writer (the price tag on the box says AUD$33 but it's probably cheaper now).
I opened the DVD Recorder case, removed the old drive assembly and spent a little time figuring out how to clip the dvd recorder drive face onto the new drive assembly. The new drive assembly comes with a black, white and a silver face to suit your computer. Examine all these bits close up and you'll get the idea!!!
I also had to use long-ish M3 bolts (and nuts and washers, from my local hobby electronics outlet but any good bolt supplier or hardware outlet will do) to replace the mounts to the old drive assembly.
The key to getting a good life out of the dvd drive in this recorder is probably to keep the unit cool when it operates. I have it in a well ventilated rack unit with an extra box fan on the back of it. Also I put some small wooden blocks under the rubber feet to keep the air flowing underneath it too.
If you had been operating one for a while at an elevated temperature then I would be worried about the SM power supply going noisy. That would probably generate the peculiar behaviour cited by mmillerpro.
This machine has a well designed user interface, but its long term stability is questionable I think. Still, it wasn't bad value for money cos I got it so cheap. With the measures listed above and the standby of cheap replacement drives and the fall-back of firmware updates, I think I'll be using this dvd recorder for a while yet.......
Posted on Oct 06, 2008
  • 31 Answers
This is a common problem with the Lite-on LVW range of DVD recorders due to changes in the construction of more recent DVD R media. It can be solved with a relatively simple firmware upgrade.
Goto : http://r00.liteonit.com.tw/DC/english/download/index.asp
You'll need to have a blank CD and a CD/DVD writer in the PC you use to download the file.
Follow the instructions on the website to upgrade your firmware, this should then allow you to write to DVD's once again.
Posted on Mar 06, 2008
What is the settings for playback?
There are no specific settings for playback on this machine?
If the lazer does not read discs and the display shows NO DISC or UNKNOWN DISC then the lazer pick-up needs replacing.
I believe that the lazer pick-up for this LG recorder has been discontinued?
Jun 22, 2016 | LG RH1999H DVD Recorder/HDD Recorder
Lvw5005 recorder
Go to www.local.com and search for a repair service.
Dec 22, 2007 | Lite On LVW-5005 DVD Recorder
Have pioneer pdr w839 needs new lazer where do i get one
Hello
Just contact the authorised service center for Pioneer at your town. You can buy it locally too, form any of electronic spare part selling shops at your town.
Feb 29, 2012 | Audio Players & Recorders
I have a 5 yr old liteon LVW5005 dvd recorder.I am a light user and this unit did recorder around 100 dvds. Now the recorder wont read any discs I have been using -r have tried +r no good as well the...
Hello
According to your description, it seems that the disc tray is not loading into it porperly i thinks. Just do one thing. Without any disc in tray, close the tray either by using remote control or the front panel opn/close button of the system. If the tray closes first, and then reopens again without any command, make sure that the disc tray mechanism does not working properly, and the disc is not loading into it in place.
If this is alright, place a disc in the tray, set close, and push the tray with your finger slightly as it closes, and see whether it loads properly and play the disc. If so, loading belt inside the loading mechanism is worn out, ans should be replaced. In most cases, this may be the fault. Check it.
You can do the repair work, if you have some knoledge in electroncis, and its mechanical function. If not, get it repaired by an experienced service technican. Most of them can do this work, as it is simply a mechanical one. OK.
Mar 31, 2011 | Lite On LVW-5005 DVD Recorder
I have a xbox360 game and does not read as a game it read as dvd
This can be caused by a dirty laser in the drive. Try cleaning the laser with a Q-tip and alcohol. If this does not fix the problem then the laser may need to be replaced. Contact Microsoft to see if the unit is still under warranty.
If the unit is not under warranty, visit www.wiredextreme.com or call toll free 1-888-389-3038. We are a console repair company based in Texas, and can get your console up and running in no time. All of our repairs come with a standard 90 day warranty that covers the entire console, not only our repairs. Extended warranties are also available at additional cost
Jun 21, 2010 | Microsoft Xbox 360 Console
My protron dvd recorder is saying disc error, when
Hi
This could a dirty lazer bulb try cleaning with a damp shammy leather allow to dry for a few min's . if this does not clear fauly lazer unit will need replacing
regards windyhouse
Mar 29, 2010 | Protron PD-DVR100 DVD Recorder
Where i can buy lvw5005 dvd recorder,i leave in CA orange county
You may have better luck buying one online. Maybe Ebay, the LVW 5005 is discontinued so you will probably not find it in any store
Nov 29, 2008 | Lite On Computers & Internet
Won't play recorded cd's
Try this link. It offers resistor changes which are designed to fix your problem of inability to play any CD R. on that model Nakamichi. jacknz0 http://home.cogeco.ca/~niteowl/Nak_MF51.jpg
Dec 31, 2007 | Nakamichi MF-51 5-Disc CD Changer
Lite On LVW-5005 DVD Recorder Logo
248 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
jason
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
