Air Purifiers
Problem for Air Purifiers
Generic problem for all Air Purifiers
Ionic Breeze Quadra Electrostatic Air Cle...
By RonnyD on Feb 25, 2008
The unit abruptly stopped. Unit does not operate/turn on. Indicator light does not operate, neither green (on) or red (off).
Unit was cleaned. Still does not operate. Is there a simple fuse that "blew" and can be changed? Cannot locate a manual or operating instructions.
Same Problem
Dec 07, 2008
-   Same problem, light comes on only for a few seconds then unit turns off. Cleaned well and bulb has been checked as i have several units, 2 have same problem.-   bill355gts
Nov 18, 2008
-   Will not come on, stopped completely, bulb has been changed, cleaned well all the time.-   Guest
Aug 16, 2008
-   Same problem here, I noticed an arc flash at the time it stopped. -   btollenaar
Jun 30, 2008
-   I have the same problem. Dennis.-   Guest
Mar 10, 2008
-   I have two units that have just stopped working...-   Guest
Solution #1
posted on Feb 25, 2008
Somewhat Helpful)
yalmer
Rank: Wiz
Rating: 82%, 337 votes
http://www.allergybegone.com/ionbreezquad1.html
There is a manual for your purifier at this website.
It is in pdf form, free to download.
look for the sentence on the page.
it will take you to the download.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #2
posted on May 25, 2009
Not Rated)
ltscoach
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem with mine and found the on/off switch to be broken. replaced switch and now works fine.
Was this helpful?
Yes
No
Popular Solutions for Air Purifiers
Questions and Unsolved Problems for Air Purifiers
Answer
i have misplaced my manual and need to clean filter'(s )can some one help me out please
Answer
i have the fresh aire model just replaced rci cell cleaned filter and cleaned the ozone plate. the... (More)
Answer
doesn't run at all, replaced filter, cleaned, checked wiring outlet
Answer
my sharper image ouadra air cleaner has a flasing blue light on the size setting what does this mean
Answer
side by side refrigerator....need to take out top inside of refrigerator to replace part. How do I... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Air Purifiers:
Top Air Purifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Air Purifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
