Question about Epson LQ-2180 Dot Matrix Printer
How to set tear off?
Hello sir? I want to ask how to set my printer to set to automatic tear off. I want to set to three parts the A4 size paper, so I want to tear it off 2 times for one A4 size paper... please help...
  • Anonymous May 31, 2008
    Hi Sir,
    I have a similar problem.
    My printer does not stop running continouesly. And the Tear Off light is blinking or the light does not go to off status. Pleae help.
    Thank you.
  • 97 Answers
Usually the setting to arrive at the tear off is to allow the tracter paper to arrive at the correct spot using the Top of Form using the buttons on the front
Posted on Feb 25, 2008
Load A4 paper in the multi-purpose tray again,and then press [paper] to print. error shown in LBP2900B
If you normally print on letter sized paper, then some program you are using is trying to print on A4 paper (PDF files often the culprit) and the default on most printers is that if they do not have the paper loaded it will ask for it from the MP tray. You can check your printer settings as you may be able to tell the printer to automatically sub letter paper when A4 is requested.
Sep 20, 2015 | Canon LBP2900
Always showing the manual feed option when we printing. We would like to set it as automatic printing. How can we do that in default. Please help. We checked all the menus. example: in system set up paper...
If you are in Canada or US then you need to set the default paper size to Letter not A4. Most if not all software you use likely sends the print job in letter format. Because the printer is set in A4 it stops and waits for that size.
Mar 11, 2011 | HP LaserJet 3050 All-In-One Printer
Hello sir, how to take print on A4 page? please help me
Hi The A4 paper size is an internationally used paper format. Although not often used in America, it is by far the most commonly and widely circulated paper size. At 8 1/4 inches by 11 3/4 inches, it is similar though not quite identical to the American standard U.S. letter size, which is 8 1/2 inches by 11 inches. Because of its ubiquity, all printers and programs have the ability to handle the size, and getting a printer to print to it is a matter of adjusting the settings.Put the A4 sized paper into the automatic feeder in the printer. You may have to adjust the tray guides to fit the paper in snugly. Close the tray firmly when finished.
  • Step 2.Set the printer to register the A4 sized paper inside the the tray. This varies from printer to printer but generally involves going into the print menu, scrolling to the automatic feeder and designating the tray as an A4 tray.Step 3.Select "File" and then "Page setup" in the program you are using.Step 4.lick on the drop down menumag-glass_10x10.gif next to paper size and choose "A4.Step 5.Select "File" and then "Print." Click the "Print Summary" button to ensure the file is set to print to the A4 size.
  • Step 6.Press "Print" to print the photograph.
  • Jul 31, 2010 | Toshiba e-Studio163 Copier
    Wrong size paper error Dell 1320C
    if you are printing letter size then setting the tray to a4 will produce an error... if you really need to print a4 then go into the driver and set it to print a4 and in print options set it for a4...and set the tray for a4
    Dec 20, 2009 | Dell 1320c Laser Printer
    How to set half half size paper
    Look for a latch on the right side tractor drive. This will unlock it so you can slide it sideways on its rail. Set it approximately where it should be, load the paper, then adjust it so you have a slight amount of tension across the paper. I think the rest is software.
    Jun 25, 2009 | Epson LX-300+ II Matrix Printer
    Pc load letter
    Hi there this issue is caused by your driver defaulting to letter and a4 paper being used set your default paper size to a4 in the driver and also set tray to a4 this should cure the problem Regards AL "alstech"
    May 28, 2009 | HP LaserJet 4 plus Printer
    Lexmark T632 says "Load MP Feeder Letter
    Hi Pqpoppa,
    Check the paper size setting in the printer. Set it to the paper size you normally use such as A4 and the default tray. Check the default paper size in the printer driver in your computer and the default tray. Finally, check the paper size of the document you are printing. If all these match, it should not try to be smart and ask you to feed paper.
    Rgds
    S88
    Nov 03, 2008 | Lexmark T632 Laser Printer
    IR 5000-6000 LGL TO A4 PROBLEM
    What country are you from ???? here in the US we do not use A4.
    Only Legal Letter, check the size of the paper you are using and check the trays to make sure it is set correctly.
    Oct 11, 2008 | Office Equipment & Supplies
    Asking to change paper size.
    yo tengo el mismo problema
    y cada ves que cargo papel en el caset, sale una impresión de prueba
    Jun 03, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
    Only wants to print out of tray 1
    paper size or paper type is incorrectly set on trays (check settings via printers keyboard menu) or and settings in print driver are incorrect (control panel/printers and faxs right click hp icon properties
    Nov 30, 2007 | HP LaserJet 4350 Printer
    Epson LQ-2180 Dot Matrix Printer Logo
    875 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
