Question about HP Photosmart 3310 Printer
Hp 3310 I have this error 0xc05d1281 on the hp 3310 I tried to reset it by holding down the ok, cancel, color and the black copy button but it did not work, is there any other thing that I can do. Thans!
    President:
  • 2,072 Answers
You can go onto www.hp.com and go to online technical support. See what they have to say.
You have done the correct step in the reset.
You need further information from them. You have done what the initial corrections would tell you to do.
Posted on Feb 25, 2008
Printing problem hp D7160 error 0xc18a0001 please help
Hi,problem can be solved .Please check out this link for the Ink System Failure problem.
fixyourownprinter.com/forums/printer/39471
These are from the link above:
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and then turn it back on. You will have to turn the printer off twice and then it will recalibrate.
Our HP 3310 was having the same ink system failure. Tried everything I could find, and had just about given up when I found this forum. I didn't quite get the reset right the first time, but on the second try it worked. After holding down OK, Cancel, Black and Color buttons while turning it off, I turned it back on, it turned itself off and I turned it back on again, it started off doing the calibration and it took about 5 minutes, but when it was finished I had a working printer again.
Also
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
Hope this works for you. Please let me know.
Oct 28, 2010 | Office Equipment & Supplies
Ink system failure
Please Try This, I am sure it is going to workout.
Resetting the All-in-One
Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Jul 30, 2008 | HP Photosmart C5180 All-In-One InkJet...
Ink failure error OXc05d1281
Reset the system by holding down the OK, Cancel, Black, and Color buttons at the same time and turn the 3310 off. You should keep holding the buttons down until the printer shuts off and then turns itself back on. Turn the printer off twice for the printer to recalibrate. Make sure you have new cartridges in the printer so that it can reset.
May 12, 2010 | HP Photosmart C8180 InkJet Printer
Error code oxc18a0001 on an HP 3210 HELP
this is an ink error code:
try the following;
Jul 31, 2009 | HP Photosmart 3210 All-In-One InkJet...
What means INK SYSTEM FAILURE? Error: 0xc18a0101
There is small patch that needs to be updated
Download & Install the patch from from here.
http://h10025.www1.hp.com
And the issue will be resolved for sure
if it doesnt try this:
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and the turn it back on. You will have to turn the printer off twice and then it will recalibrate. Make sure you have new cartiges in the printer so that it can reset
Jul 10, 2009 | HP Photosmart C7250 All-In-One Thermal...
Error message shows up on printer screen oxc18a0101
Found this link that tells you how to reset the printer.
http://www.fixyourownprinter.com/forums/printer/39471
Excerpt on resetting the printer from the post linked to above:
Apr 05, 2009 | HP Photosmart 3310 All-In-One InkJet...
Getting error 0xc18a0206
Try holding down the OK, Cancel, Black, and Color buttons all at once. While holding them down, press the On button to power it off (You may need another person if you lack large, coordinated hands). Turn it back on while still holding the other buttons down. You will notice it turn itself off before "booting" fully. After it turns itself off, you can finally let go of those buttons and turn it back on normally. This will force a reset and system maintenance. Worked for me and others.
Feb 16, 2009 | HP Photosmart 3310 Printer
HP Photosmart C5180 Ink System has Failed Error:0xc18a0306
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and the turn it back on. You will have to turn the printer off twice and then it will recalibrate. Make sure you have new cartiges in the printer so that it can reset.
Oct 17, 2008 | HP Photosmart C5180 All-In-One InkJet...
Error HP Photosmart 3310. No strart print, no scanning...
I have a Photosmart C6180 all in one and get an error message 0xc18a0101 Ink System has failed. Unable to copy, receive faxes or print. Refer to printer documentation. Error: 0xc18a101.
I put new cartridges in and tried to recalibrate as mentioned by someone on the board. Can anyone help, please?
Nov 16, 2007 | HP Photosmart 3310 Printer
HP 3310 All In One Error
Try to reset the system by holding down the OK, Cancel, Black, and Color buttons at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and then turns itself back on. You will have to turn the printer off twice and then it will recalibrate. Make sure you have new cartridges in the printer so that it can reset.
Oct 31, 2007 | HP Photosmart 3310 Printer
HP Photosmart 3310 Printer Logo
793 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
